greshnov
Варнинг при инициализации
Pinned posts
После гибридной инициализации вылез варнинг, запустил на расчет - выдает ошибку. Что проверять и где может быть ошибка?
k-e, energy + и В ГУ: pressure-inlet, mass-flow-inlet, mass-flow-outlet, symmetry
Пробовал измельчить сетку, поменять метод симпл/куплед
iter scalar-0
1 1.000000e+00
2 2.932377e-04
3 7.967090e-05
4 3.773384e-05
5 1.638342e-05
6 8.934103e-06
7 5.847838e-06
8 6.430244e-06
9 7.217154e-06
10 1.305204e-05
11 1.631302e-05
12 3.244332e-05
13 3.988119e-05
14 8.472806e-05
15 9.941143e-05
16 2.251033e-04
17 2.570013e-04
18 6.087709e-04
19 6.956111e-04
20 1.659021e-03
21 1.906632e-03
22 4.575917e-03
23 5.074597e-03
24 1.244924e-02
25 1.365369e-02
26 3.403635e-02
27 3.824203e-02
28 9.342378e-02
29 9.136562e-02
30 2.240822e-01
31 2.869713e-01
32 5.659684e-01
33 3.068105e-01
34 7.069897e-01
35 3.706655e-01
36 8.110773e-01
37 3.624737e-01
38 5.445173e-01
39 7.102276e-01
40 5.722097e-01
41 5.995557e-01
42 5.982909e-01
43 6.358657e-01
44 6.045992e-01
45 6.424110e-01
46 6.173069e-01
47 6.619951e-01
48 6.259815e-01
49 6.820730e-01
50 6.353868e-01
hybrid initialization is done.
Warning: convergence tolerance of 1.000000e-06 not reached
during Hybrid Initialization.
Writing Settings file "C:\Users\User\AppData\Local\Temp\WB_JARVIS_User_3680_2\unsaved_project_files\dp0\FFF\Fluent\FFF.set"...
writing rp variables ... Done.
writing domain variables ... Done.
writing fff_solid (type fluid) (mixture) ... Done.
writing outlet (type mass-flow-outlet) (mixture) ... Done.
writing inlet2 (type mass-flow-inlet) (mixture) ... Done.
writing inlet1 (type pressure-inlet) (mixture) ... Done.
writing interior-fff_solid (type interior) (mixture) ... Done.
writing symmetry (type symmetry) (mixture) ... Done.
writing wall (type wall) (mixture) ... Done.
writing zones map name-id ... Done.
Writing "| gzip -2cf > FFF-Setup-Output.cas.gz"...
Writing temporary file C:\Users\User\AppData\Local\Temp\flntgz-62562 ...
1157746 tetrahedral cells, zone 2, binary.
2269498 triangular interior faces, zone 1, binary.
276 triangular mass-flow-inlet faces, zone 5, binary.
3463 triangular symmetry faces, zone 6, binary.
68 triangular mass-flow-inlet faces, zone 7, binary.
4078 triangular pressure-inlet faces, zone 8, binary.
84103 triangular wall faces, zone 9, binary.
215809 nodes, binary.
215809 node flags, binary.
Done.
iter continuity x-velocity y-velocity z-velocity energy k epsilon time/iter
reversed flow in 2034 faces on pressure-inlet 8.
# Divergence detected in AMG for epsilon: protective actions enabled!
# Divergence detected in AMG for epsilon, temporarily solve with BCGSTAB!
Error: Divergence detected in AMG solver: epsilon
Error Object: #f
Поделиться сообщением
На какие-нибудь мысли наводит?
8 часов назад, piden сказал:
Пробовал менять граничку - вышла такая ошибка
# Divergence detected in AMG for temperature: protective actions enabled!
# Divergence detected in AMG for temperature, temporarily solve with BCGSTAB!
Error: Divergence detected in AMG solver: temperature
Error Object: #f
@greshnov , как думаешь, что следует сделать, чтобы другим на форуме было легче ответить на твой вопрос?
21 час назад, piden сказал:
нуууууууу, я бы не стал жестко утверждать, что это и есть корень зла :)
Давайте погадаем. Как вы предпочитаете: на гуще, на зеркале, на яйце?..
22 часа назад, greshnov сказал:
дорогой автор, я имел больше слез, чем счастья с гибридной инициализацией. прежде всего, мне неясно, что "текучий" делает за кулисами видимого.
советую:
- запустить гибрид
- переключить кнопку на стандарт
- подкорректировать стоящие в полях значения до разумных, согласно заданию, значений
- еще раз инициализировать через стандарт и попробовать решать
в случае неудачи после поиграем с настройками "продвинутых" настроек :)
2 минуты назад, piden сказал:
если удача улыбнется, то на загруженном CAS :)
Спасибо, попробую!
Создать аккаунт
Зарегистрировать аккаунт
Войти
Войти сейчас
    • СергейРу
      Наука, копаю тему об обечайках и технологии их обработки, не праздное любопытство. Базовое расположение - вырез вертикально, а станок должен устанавливаться сверху на отверстие. Ось угловой фрезы параллельна оси отверстия Ось цилиндрической фрезы расположена по касательной  к любому сечению через ось отверстия.
    • karachun
      Ступени турбин, компрессоров и прочих лопаточных машин разрезают не по плоскости а по некоторой эквидистанте, примерно по середине одного межлопаточного канала, и задают ГУ периодичность на поверхностях раздела.
    • bard
      Я не знаю кто такой космополит.  Страны есть, национальности есть, границы есть, спрашивать об очевидных вещах разве не демагоги? Вы не ответили на мои вопросы, что Вам не понравилось в Крыму? Не так давно был на площади Регистан,  поразился работой инженера Шухова. Он там минареты после землетрясения выправлял.
    • дмитрий32
      Кто должен дать разрешение?  Давайте я попрошу. Нашел не дорого РСМ-9375 F, что означает буква F не знаю еще не разбирался, еще есть РСМ-5824 (не 25, а 24), также есть 4823 L, но тоже непонятно что за L (на вид тоже самое только не хватает пары разъемов, сравнивал свою фото и фото платы с L обозначением). Вот думаю может действительно прикупить РСМ-9375 F под модернизацию ПРЦ-6 в "далеком" будущем. Можете по подробней написать что для этого нужно, только комп поменять и СF с образом? Или там еще какие танцы с бубном, просто если еще что то менять в настройках и т.п, боюсь не справлюсь, тогда лучше отговорите меня на стадии губозакатывания, а то и в правду куплю РСМ-9375 F.
    • tm-ares
      @kino51 Мысли вслух   Hide   Иллюстрация   Hide   Токарно-фрезерная.7z
    • chatjokey
      между прочим, смех смехом, а вот что https://meduza.io/shapito/2018/11/06/bill-geyts-pokazal-unitaz-buduschego-takomu-tualetu-ne-nuzhna-voda-a-on-prevraschaet-v-udobrenie
    • Kukuev
      С большим интересом прочитал дискуссию о возможностях построения ленты Мебиуса, но вот ее, как таковой, задачи строить не было. Она была лишь примером сложной поверхности, которую трудно представить набором конусов. Можно ли использовать такую же последовательность в SW? Если нет, то что за ПО использовалось?   Множество конусов не пугает совсем, так как поверхность потом будет разбита на грани. Поделитесь, пожалуйста, технологией :)
          Наиболее заинтересовавший меня метод, я явно не знаю всего функционала SW. Что это за стрелки слева и снизу? Сохраняет ли поверхность свою развертку после такой деформации?
      @Атан очередная демагогия. Нарисовал целых четыре картинки, и ни одного мебиуса.
    • SeVa304
    • GS
