Копия сервера Intralink
У меня довольно странный вопрос.... Возникла необходимость создать копию сервера Intralink. Как переместить данные на другой компьютер и импортировать базу?
Solution Details - TPI
Number 33081
Type TPI
Created Date 03-May-1999
Last Updated 23-Apr-2003
Title Moving the Data Server and/or File Server to a New Machine
Details Additional Information
Description
Suggested Procedure for Moving the Pro/INTRALINK Data Server and/or File Server to a New Machine.
Alternate Technique
See Resolution below.
Resolution
To move the Data Server to a new machine or set up a copy of a Data Server on a separate machine, the
following procedure should be executed (Unix users must be logged on as the oracle user and NTusers must
be logged in with administrative privileges):
1. Create a .dmp file of the Oracle Metadata for the original (old) Data Server. There are two methods.
1.1. Method 1: Use the Data Server Management Utility
1.1.1. Start the Data Server Management Utility (execute <Data Server loadpoint>\intralink\bin\proimgr)
1.1.2. Select #Server, #Connect Data Server, Enter the "system" user password (default password is manager)
1.1.3. Select #Export, #Export Dump File <path to dumpfile>\<dumpfile_name.dmp>
1.2. Method 2: Use the ilink_export script in the <Data Server loadpoint>\intralink\export directory
1.2.1. Execute: ilink_export <system user's password> <path to dumpfile>\<dumpfile_name.dmp>
(example: ilink_export manager d:\folder1\may7.dmp)
*NT users must execute ilink_export from a DOS prompt.
2. Install a new Data Server of the same build as the original Data Server on the new machine. If a file vault
on the new machine will be used, install a File Server on this machine first. Otherwise, enter the old File
Server machine name when installing the Data Server.
2.1 Size the new dataserver appropriately SMALL/MEDIUM/LARGE and then use the DSMU to resize beyond large if
necessary. Compare the file sizes of the individual datafiles 'ilnk*.dbf' as listed in the Backup Report. Use the
Windows Explorer to find the Properties or command line listing to find the actual size. Ensure the new
datafiles are the same size or larger than the current server. This will ensure the dump file imported in the next
step will not fail due to space constraints.
3. Import the .dmp file (created in step 1) on the new machine using the ilink_import script in the
<Data Server loadpoint>\intralink\export directory.
3.1. Execute: ilink_import <system user password> <full path to dumpfile>
(example: ilink_import manager d:\disk1\may7.dmp)
*NT users must execute ilink_import from a DOS prompt.
4. The new Data Server's metadata still references the original File Server machine and file vault from the old
Data Server. To move the file vault to a new machine or update a copied Data Server to look at a new File
Server and File Vault:
4.1. Start the Data Server Management Utility (execute <Data Server loadpoint>\intralink\bin\proimgr)
4.1.1. Select #Server, #Connect Data Server (default password is manager)
4.1.2. Select #Server, #Connect Intralink Admin (using an Intralink Administrator's username and password)
4.2. Register the File Server on the new machine with the Data Server.
4.2.1. #Vault, #Create File Server
4.2.2. Hostname (enter the hostname of the new File Server machine), Port number (default is 7777)
4.3. Move the File Vault to the new machine and unregister the old File Server. If making a copy of the Data
Server, choose to manually move the vault and then copy the files in the file vault to the new location.
This will leave the files for the original Data Server to access.
4.3.1. #Vault, #Move File Vault
4.3.1.1. Enter Name of File Vault to move (example: SYSPOOL)
4.3.1.2. Enter New Host name
4.3.1.3. Enter New Path to File Vault *Path to File Vault must not exist
4.3.1.4. Enter Password for File Server (default is fschangeme)
4.3.1.5. Enter Password for File Server on New Host (default is fschangeme)
4.4. Unregister the old File Server.
4.4.1. #Vault, #Remove File Server
Note: All file vaults must be moved off original File Server machine before the File Server can be
unregistered.
4.4.2. File Server Name to Remove <File Server name>, Password <default is fschangeme>
5. If the old File Server is no longer being used, the File Server process on the old machine can be shut down
and its loadpoint deleted (UNIX) or if running NT, use #Control Panel, #Add Remove Programs to remove
Pro/INTRALINK File Server.
Note: If objects have been checked out to a WORKSPACE as a link rather than local copy, the user will need to
check-out the objects again after the File Vault has been moved. This TPI applies to all versions of
Pro/INTRALINK.
Есть подробная инструкция с картинками. Но увы на итальянском языке. Выслать ?
To Half:
За инструкцию спасибо конечно, но она у меня есть...
Мне кажется она мне немного не подходит. Данные будут перемещены со старой машины на новую (На сколько я понимаю). А мне нужно, чтоб они остались на старой, т.е. сделать копию.. :wallbash:
To Finist:
С удовольствием посмотрю, только итальянского не знаю. :blink:
мыло: rifrag@rambler.ru
<{POST_SNAPBACK}>
Правильно понимаете. Но Вас никто не заставляет удалять сервера (дата и файл) и ваулт со старой машины. Вы просто делаете дамп и копию ваулта, затем подгружаете на новую машину. Прочитал пост Half'а и понял что инструкция на итальянском Вам вряд ли нужна. Это тоже самое но со скриншотами.
To Finist:
Спасибо за пояснение. Примерно такиеже мысли у меня тоже были, я просто думал может всё можно сделать проще. :doh: Попробую сделать так. :smile:
Даже если просто захотите сменить имя компьютера (не меняя ничего физически) - все равно придется по этому алгоритму действовать
    • Artas28
      Syntec 220MA Во время смены инструмента, шпиндель по Z уехал выше. После нажатия паузы. Всё встало. Станок находится выше машинного нуля и не опускается. Кто сталкивался? Как опустить?  Ошибка MLCHint R590.7 Plc hint
      @Alexey0336  Да, всё работает: https://cloud.mail.ru/public/NGNq/Ft8UAJtf3
      Так оно и есть, китайский клон Сименс-808.
      Что Вы подразумеваете под словом "Конфликтовать"? Мпроп и мой макрос делают одно и тоже действие, создают и заносят свойства в файл солида. Если свойства с одинаковым именем (например Обозначение и Наименование), то Да, свойство перезапишется тем макросом, которой отработал последним. Щас проверю, отпишусь. Изначально Наименование и Обозначение берутся из имени файла, но его всегда можно перезаписать... Если что, это всегда можно переписать под Ваши требования.
      Если у вас SW не выше 18й версии, могу проверить у себя.
    • Orchestra2603
      Ну, есть же, например QZ алгоритм (обобщение QR разложения, для слуая когда матрица масс не равна I). Отлично работает, когда одна из матриц вырожденная. Вот статься:  https://deepblue.lib.umich.edu/bitstream/handle/2027.42/6667/bac9269.0001.001.pdf?sequence=5   вот коротко в Вики     Раскопал это вообще, глядя в справку от матлаба: https://www.mathworks.com/help/matlab/ref/eig.html.   Это все нюансы....  И все эти алгоритмы сущетсвуют уже кучу лет во всяких библиотеках типа LAPACK. Вы думаете, что в Dassault Systemes или Ansys про это не знают, и их модальник - лажа?
    • karlf
      Сегодня не было времени, завтра посмотрю и пришлю фото как выглядит
      АСКОН выпустил новый релиз среды общих данных Pilot. В нем получили развитие инструменты строительного контроля и авторского надзора, появилась возможность вручную координировать модель объекта капитального строительства. Стройконтроль Вести стройконтроль на площадке, а также авторский надзор за деятельностью арендаторов и собственников поможет привязка панорамных фото объекта к чертежам и документам. Для съемки панорамных фото используется мобильное приложение Pilot-Photo360, доступное для Android. С помощью приложения специалисты строительных организаций, компаний-застройщиков, девелоперов смогут: Находясь на объекте строительства или эксплуатации, фотографировать объект на специализированную панорамную камеру и сразу прикреплять снимки к точкам на чертежах и документах в Pilot-BIM или Pilot-ICE Enterprise. Группировать панорамные снимки по альбомам. Просматривать фото помещения с разных ракурсов, при этом видеть направление взгляда относительно [...] View the full article
    • wega7777
      Судя по формату ошибки похоже на Систему ЧПУ от HCNC — аналог Siemens и Fanuc. ЧПУ HNC808DiT, но могу ошибаться.
    • Alexey0336
      Похоже на то, что мне нужно) Пара вопросов: 1. Будет ли макрос конфликтовать с Mprop? 2. Если я каждой сборке/детали заранее пропишу в обозначение: $PRP:"Порядковый номер" ХХ.YY.ZZZ, подхватит ли формула свойство "порядковый номер" после всех действий?
