Dear fellow simulation enthusiasts,
The 2018 edition of my ANSYS-based simulations course is now available at edX.org. You can enroll here. Learners can work through the course at their own pace and have until mid-December to complete the course and earn a Verified Certificate. Please spread the word to those who might be interested.
This edition has updates to ANSYS 18.2, the latest release. A major change in this release is that SpaceClaim Direct Modeler, a powerful and easy-to-use CAD application, is the default geometry engine in place of DesignModeler. I have updated the geometry steps of 2D Conduction and Laminar Pipe Flow modules to SpaceClaim. I’ll be adding new content to this edition. I have added modules on Truss and Cantilever Beam FEA since the original run. All new content will use SpaceClaim for CAD.
Happy simulating!
Rajesh Bhaskaran
Изменено пользователем piden
  • 1 год спустя...
Дополню. Сам не проходил, но судя по всему не плохо.
This course is an introduction to the finite element method as applicable to a range of problems in physics and engineering sciences. The treatment is mathematical, but only for the purpose of clarifying the formulation. The emphasis is on coding up the formulations in a modern, open-source environment that can be expanded to other applications, subsequently.
--> Enroll : https://www.coursera.org/learn/finite-element-method?action=enroll
      Ладдер пришлите. Будем принудительно пробовать поднимать и опускать
    • streamdown
      SP9047 SSPA:47 ILLEGAL SIGNAL OF POSITION CODER "The relationship between the A/B phase and 1-rotation signal is incorrect (Pulse interval mismatch)." "Неправильное значение счетчика импульсов сигнала на энкодере ALPHAi. На фазах A и B энкодера за один оборот шпинделя насчитывается 4096 импульсов обратной связи. Программное обеспечение по управлению шпинделем проверяет количество импульсов на фазах A и B, соответствующее энкодеру, при каждой генерации сигнала одного оборота. Данный аварийный сигнал срабатывает, если регистрируется число импульсов, нарушающее заданный диапазон."
    • vs3dpro
      Добрый день! У нас на есть SLA принтер 600х600х400мм. Можно напечатать мастер- модели, и можно приехать посмотреть. mail@iges.space
      после ввода 789 в edit mod надо перейти в режим ручное упр. нажать mod а потом помощь и откроется wzw.hlp  с возможностью выполнения команд управления atc. если не появляется содержимое wzw.hlp то возможно что у вас другой код хотя 789 'это стандарт для dmg в этом случае надо смотреть ваш plc раздел у меня пароль прописан в файле wzw_rett.mod
      SERVO TURRET AMP ALARM - переводить не пробовали, учитывая, что AMP - это и есть сервопривод? Что тут не ясного, язык не знаком?
      я бы попробовал позиционировать шпиндель сигналом G70.6 Ответный сигнал, шпиндель сориентирован F45.7
      Здравствуйте уважаемые участники форума попрошу вас поделится мнениями. Имеется фрезерный шпиндель с позиционным кодером (зубчатое колесо и считывающая головка). Ошибку 9047 выдает после того отрабатывает M19 c последующим включением оборотов Sxxx M3 причем обороты могут быть любыми от 100-макс. Если задавать обороты без предварительной ориентации то 9047 не возникает и шпиндель нормально вращается на любой скорости при этом обороты не гуляют точность поддержания +-1 об\мин. Кабель заменен заменить сам датчик нет возможности. Мой вопрос в следующем почему шпиндель после M19 и включении управления скоростью Sxxx M3 остается в режиме позиционирования а не сразу переходит врежим управления скоростью и даже явная отмена ориентации кодом M20 ничего не меняет ведь режим позиционного управления должен быть отменен или он остается и отменяется не сразу после подачи команды M3 и кода скорости? Станок достаточно старый 2009 года плату управления шпинделем меняли на соседний ничего не изменилось. Это может быть логика PMC или скорее всего это датчик?   PMC-SB.001
      А мы-то думали, что пропорциональный гидравлический.....
