Какие ISO соответствуют нашим ЕСКД? Или наоборот?
Всем привет. Возникла необходимость отправить чертежи за рубеж. По каком стандарту оформлять чертежи? У нас по ЕСКД. А у них?
Так спросите у них.
А то не особо понятно за какой рубеж отправляете: в Белоруссию, в Польшу, в Германию или в США с Великобританией.
если только отправить, то отправляйте так. Или разберутся, или попросят разъяснить. Если проектирование для них, то попросите примеры оформления. Этого достаточно.
GD&T
Это не название стандарта, а общий термин для "оформления конструкторской документации".
В Европе - ISO и DIN. Вообще же верный ответ дан во втором посте.
for consideration:
I've worked in Europe. Most companies use a mix of ISO and national standards. The Germans use DIN. I believe most Japanese use JIS. As long as your drawings clearly state what standards they adhere to it should not be a problem. You have to be careful with ISO standards because they are written as lots of separate little standards, not big all encompassing standards. Some of them are mutually exclusive. It is necessary to get very specific about which ISO standards you use.
Lots of American companies (and non-American) do not specify drawing standards in their title block which can lead to major problems. When I worked in France they did not specify any standards on their drawings. I asked how they could interpret their drawings and was told "We all go to the same schools and they all teach us the same way". So I gave them a little (tricky) test and got a different answer every time!
In particular, beware ISO 8015:1985 Fundamental tolerancing principal. It directly contravenes the ANSI/ASME Y14.5M envelope requirement. You can get around this evil spec by invoking national standards.
Also beware of ISO 4288:1996 Rules and procedures for the assessment of surface texture. This is the biggest piece of horse hockey ever written. It includes the "16% rule" which states that a surface is considered acceptable if not more than 16% of the measured values exceed the specification. I think not! Under ANSI you would reject for a single measurement outside the specification.
So in summary, it is OK to use national standards for international business but be very carful to specify which standards you use.
http://www.mcadcentral.com/creo-drawing/10550-comm-n-drawing-standards-europe-asia.html
Человек легко поймёт по запросу GD&T какие стандарты ИСО включаются в общую картину, ибо единой системы конструкторской документации там нет, есть правила выполнения и те имеют достаточно вольностей, начиная с рамки чертежа.
Изменено пользователем Ljo
Совершенно верно. Как и в случае с ЕСКД. ЕСКД включает ГОСТы в себя, a GD&T - ISO
Шлите как есть.
Допуски формы там такие-же, размеров - тоже .. Ну и обязательно указать  систему проекций, ибо у американов другая. Маленькая трехмерка в углу желательна.
Все остальные типа угла наклона шрифта или толщина линий, или форматка  - им пофигу, они не парятся. Советский нормоконтроль они бы там прибили на третий день  за назойливость.
Слать надо в том виде, в котором прописано в договоре. Зачастую там оговаривается даже название папок и их структура помимо стандартов. Если такого нет, реально париться не стоит, укажите вид проекций (по первому углу или по третьему), а так же единицы измерения - мм. Остальное переведут и т.п.
Или наоборот просто быть в принципе не может  :no:
Изменено пользователем niksasa
    • denel
      Добрый день! А как произвести репозиционирование зажимов? Пишут g85… а как её использовать?
      если конус хороший в том числе и на оправке и усилие зажима соответствует норме то ничего там болтаться не будет это что касается оправки а инструмент все равно может отгибать
    • Gorich
      @gudstartup Большое спасибо...что уделили мне время...решил проблему...нашел там  вот такое: Ввел команду m22...и магазин уехал на свое место...и дальше все аработало!
    • Gorich
      это усилие зажима пружин. А как при вращении там болтается конус чем померить?
      при помощи тестера  например такого это самый простой по простому попытайтесь выдрать оправку ломиком!
    • TVM
      Для общего развития интересовался. И на предложение, спроектировать крышечку - там все просто, не ведусь.
    • Gorich
    • Нанософт разработка
      Одним из эффективных способов осуществления строительного надзора является использование результатов лазерного сканирования с построением 3D-моделей, что дает наиболее полную информацию о строительных объектах с привязкой к пространственным, инфраструктурным и центральным инженерным коммуникациям. Институт «Сибгипробум», активно работающий над совершенствованием мониторинга и созданием цифровых двойников, использует комбинацию технологий «Платформа nanoCAD + ReClouds» как бесшовную инженерную среду для проектирования и для работы с облаками точек. Комплексную поддержку при внедрении программных решений предоставила компания «Бюро САПР» – премьер- и фокус-партнер компании «Нанософт» по направлениям «Конструкции», «Инженерия» и «Землеустройство».   О компании АО «Сибгипробум» – институт, на протяжении 65 лет специализирующийся в области проектирования предприятий лесной и целлюлозно-бумажной промышленности, объектов глубокой химико-механической переработки древесины, а также разрабатывающий проекты экологических и энергетических объектов. В проектной деятельности институт активно использует технологии лазерного сканирования и информационного моделирования. Исходная ситуация ·        Отсутствие возможности оперативного повсеместного контроля строительства на промплощадке. ·        Отсутствие актуальной трехмерной модели объекта, которую в дальнейшем можно было бы сопоставить с облаком точек. ·        Сжатые сроки, которые не позволяли создать трехмерную модель. Задачи цифрового мониторинга ·        Поиск изменений между отчетными периодами. ·        Подсчет объемов монтажа. ·        Поиск пространственно-временных коллизий. Сравнение облака точек в двух отчетных периодах на графике строительства – S-кривой. Красным подсвечено то, что изменено (это было сделано на другой платформе)   Оптимальное технологическое решение можно выбрать в зависимости от степени сложности точечной задачи в рамках цифрового мониторинга. Продемонстрируем это на конкретных примерах. Прикладная задача 1: проверка проектного положения монтируемого оборудования и конструкций. Выбранная технология: Платформа nanoCAD для совмещения 2D-чертежей с облаком точек. Алгоритм работы технологии: загрузка исходного облака точек формата LAS в nanoCAD импортом NPC → создание удобной ПСК для сравнения облака точек в нужном ракурсе → копирование чертежа и совмещение по «точкам доверия» (например, по колоннам здания) → создание сечения → поиск отклонений. Полученный прикладной результат: разрез на определенной отметке показал отклонение по колоннам здания, из-за чего стена построена «криво». Благодаря этим данным авторский надзор перепроверил расчетные значения и скорректировал решения. В результате эту стену пришлось укреплять дополнительными металлоконструкциями. Плюсы и минусы технологии Плюсы: Минусы: ·        не требуется трехмерная модель; ·        простая технология, которую может освоить каждый; ·        низкие требования к аппаратному обеспечению; ·        низкая стоимость контроля проектных решений без выезда на площадку. ·        трудозатратно, если требуется проверить несколько разных разделов в одной точке; ·        проверка происходит в рамках одного сечения; ·        каждый раз в новом месте проверки требуется совмещение чертежа и облака точек.     Поиск отклонений в конструкциях путем совмещения 2D-чертежей с облаком точек в Платформе nanoCAD   Прикладная задача 2: анализ деформации оборудования – цилиндрической печи. Выбранная технология: ReClouds для сравнения облака точек печи с ее 3D-моделью. Алгоритм: загрузка исходного облака точек (в формате LAS) и цилиндра, выполненного в виде 3D-солида, равного диаметру печи → совмещение 3D-моделей → использование команды ReClouds Сравнение → побор опытным путем радиуса отклонения (вылет точки от нормативного положения) → создание градиентного графика отклонений → поиск отклонений. Полученный прикладной результат: выявлены отклонения трубы от нормативного положения: вмятина и провисание. Наглядный способ проинформировать проектировщиков и строителей, на какие участки следует обратить внимание, чтобы принять решения о ремонте, частичной или полной замене. Эффективность использования ReClouds ·        Автоматизация обработки данных 3D-сканирования. ·        Работа в знакомой инженерной среде с интуитивно понятным интерфейсом. ·        Высокая скорость работы. ·        Минимум финансовых и аппаратных ресурсов. ·        Интеграция со специализированными решениями. ·        Гибридность используемых технологий: Платформа nanoCAD и ReClouds позволяют одновременно работать с 3D-моделью, 2D-чертежом и облаком.                                         Анализ деформации цилиндрической печи с помощью ReClouds. Справа красным и зеленым цветом подсвечена сама труба   Отклонения трубы от эталонного 3D-солида: слева видна вмятина, справа – провисание трубы Мнение пользователя Павел Владимирович Коротких, главный специалист – руководитель группы отдела по цифровизации инженерных процессов и данных, АО «Сибгипробум»   «Когда геополитическая ситуация обострилась и были введены санкции, перед нашим институтом, как и перед предприятиями многих других отраслей, встала задача импортозамещения.   Много где возникали сложности, но было очень отрадно знать, что базовое инженерное ПО нам есть чем заменить. Этим ПО стала Платформа nanoCAD, которая оказалась намного большим, чем просто скопированный зарубежный продукт.   Из стандартного функционала хотелось бы отметить, во-первых, Диспетчер чертежа, который позволяет удобно осуществлять менеджмент чертежей; а, во-вторых, базовые операции при работе с облаками точек: импорт/экспорт, настройки визуализации, подрезку, сечения и т.д.   Использование ReClouds – вертикального приложения к Платформе nanoCAD – дало нам расширенные возможности взаимодействовать с облаками точек, при этом оставаясь в единой инженерной среде.   Обнадеживает активное развитие продуктов со стороны разработчика и неуклонно растущее комьюнити пользователей».   О компании «Нанософт» «Нанософт» – российский разработчик инженерного ПО: технологий автоматизированного проектирования (CAD/САПР), информационного моделирования (BIM/ТИМ) и сопровождения объектов промышленного и гражданского строительства (ПГС) на всех этапах жизненного цикла, а также сквозной цифровизации всех процессов в производстве. Миссия компании – формирование условий для массового оснащения российского рынка лицензионными, качественными и доступными отечественными программными продуктами. «Нанософт» помогает своим заказчикам достичь импортонезависимости в области инженерного ПО и нацелена на развитие собственных технологий в фокусе реальных потребностей. Это позволяет гарантированно защитить критически важную ИТ-инфраструктуру, что особенно актуально сейчас, когда западные вендоры уходят с рынка, замораживают поставки ПО и техническую поддержку. Все программные продукты компании включены в Единый реестр российских программ для электронных вычислительных машин и баз данных. Официальный сайт: nanocad.ru.
