Измерение на станке с пом. Renishaw
Удобный макрос для измерений готовых деталей на станке с пом. Renishaw.
В MDI набираю:
G65 P99 X1 (Измерение координаты в направлении +X)
G65 P99 X-1 (Измерение координаты в -X)
G65 P99 Y1 (Измерение координаты в +Y)
G65 P99 Y-1 (Измерение координаты в -Y)
G65 P99 Z1 (Измерение координаты в Z)
G65 P99 X100 (Измерение  гнезда по X, размер любой, не только 100)
G65 P99 X100 Z-10 (Измерение  выступа по X)
G65 P99 Y100 (Измерение  гнезда по Y)
G65 P99 Y100 Z-10 (Измерение  выступа по Y)
G65 P99 D40 (отверстие)
G65 P99 D40 Z-10 (вал)
O00099 (MEASURE)
(24-X 25-Y 26-Z 7-D)
G103 P1
#101= #0
#102= #0
#11= #5321 (G59-X)
#12= #5322 (G59-Y)
IF [ [ #24 NE #0 ] AND [ ABS[ #24 ] LT .1 ] ] THEN #24= 10000 * #24
IF [ [ #25 NE #0 ] AND [ ABS[ #25 ] LT .1 ] ] THEN #25= 10000 * #25
IF [ [ #26 NE #0 ] AND [ ABS[ #26 ] LT .1 ] ] THEN #26= 10000 * #26
IF [ #26 GT 0 ] THEN #26= - #26
IF [ [ ABS[ #24 ] EQ 1 ] OR [ ABS[ #25 ] EQ 1 ] OR [ #26 EQ [ -1 ] ] ] GOTO2 (SURF X/Y/Z)
IF [ #24 OR #25 ] GOTO1 (POCKET/WEB X/Y)
IF [ #7 EQ #0 ] GOTO4
(BORE/BOSS)
#1= 1
IF [ #26 ] THEN #1= 2
G00 G90
G65 P9023 A#1 D#7 Z#26 S59.
G103 P1
#5321= #11 (G59-X)
#5322= #12 (G59-Y)
G00 G90
T25 M06
G43 H25
G65 P9832 (OMP ON)
G103 P1
IF [ #26 ] THEN #26= #26 + #5043 - #5083
G65 P9812 X#7 Z#26
#101= #188 (DIAMETER X)
G65 P9812 Y#7 Z#26
#102= #188 (DIAMETER Y)
GOTO3
(POCKET/WEB)
N1 IF [ [ #24 NE #0 ] AND [ #25 NE #0 ] ] GOTO4
IF [ [ #24 LT 0 ] OR [ #25 LT 0 ] ] GOTO4
#1= 3
IF [ #26 ] THEN #1= 4
G65 P9023 A#1 X#24 Y#25 Z#26 S59.
G103 P1
#5321= #11 (G59-X)
#5322= #12 (G59-Y)
IF [ #24 ] THEN #101= #188 (Size X)
IF [ #25 ] THEN #102= #188 (Size Y)
GOTO3
(SURFACE)
N2 IF [ [ [ #24 NE #0 ] OR [ #25 NE #0 ] ] AND [ #26 NE #0 ] ] GOTO4
G00 G90
T25 M06
G43 H25
IF [ #24 ] THEN #24= 10 * #24 + #5041
IF [ #25 ] THEN #25= 10 * #25 + #5042
IF [ #26 ] THEN #26= 10 * #26 + #5043 - #5083
G65 P9832 (OMP ON)
G65 P9811 X#24 Y#25 Z#26
G103 P1
IF [ #24 ] THEN #101= #185 (SURF X)
IF [ #25 ] THEN #102= #186 (SURF Y)
IF [ #26 ] THEN #101= #187 (SURF Z)
N3 G65 P9833 (OMP OFF)
G00 G90
/G53 Z0
N4 G103
M99
Изменено пользователем father
  • 1 год спустя...
O00099 (MEASURE)
(01-A 7-D 18-R 24-X 25-Y 26-Z)
G103 P1
#101= #0
#102= #0
#11= #5321 (G59-X)
#12= #5322 (G59-Y)
IF [ [ #24 NE #0 ] AND [ ABS[ #24 ] LT 0.1 ] ] THEN #24= 10000 * #24
IF [ [ #25 NE #0 ] AND [ ABS[ #25 ] LT 0.1 ] ] THEN #25= 10000 * #25
IF [ [ #26 NE #0 ] AND [ ABS[ #26 ] LT 0.1 ] ] THEN #26= -10000 * ABS[ #26 ]
IF [ [ #1 NE #0 ] AND [ ABS[ #1 ] LT 0.1 ] ] THEN #1= 10000 * #1
IF [ [ #18 NE #0 ] AND [ ABS[ #18 ] LT 0.1 ] ] THEN #18= 10000 * #18
IF [ #1 NE #0 ] GOTO3 (ANG)
IF [ #7 EQ #0 ] GOTO6
(BORE/BOSS)
#1= 1
G00 G90
G103 P1
#5321= #11 (G59-X)
#5322= #12 (G59-Y)
G00 G90 G80 G40
T25 M06
G43 H25
G65 P9832 (OMP ON)
G103 P1
G65 P9812 X#7 Z#26
G65 P9812 Y#7 Z#26
GOTO5
(POCKET/WEB)
N1 IF [ [ #24 NE #0 ] AND [ #25 NE #0 ] ] GOTO6
IF [ [ #24 LT 0 ] OR [ #25 LT 0 ] ] GOTO6
#1= 3
G103 P1
#5321= #11 (G59-X)
#5322= #12 (G59-Y)
GOTO5
(SURFACE)
G103 P1
N2 IF [ [ [ #24 NE #0 ] OR [ #25 NE #0 ] ] AND [ #26 NE #0 ] ] GOTO6
G00 G90 G80 G40
T25 M06
G43 H25
G65 P9832 (OMP ON)
G103 P1
GOTO5
(ANG XY SURFACE)
N3 IF [ #7 ] GOTO4
IF [ #18 EQ #0 ] THEN #18= 10.
G00 G90 G80 G40
T25 M06
G43 H25
G65 P9832 (OMP ON)
G65 P9821 A#1 D#18
G103 P1
#101= #188 (DISTANCE)
GOTO5
(ANG POCKET/WEB)
N4 #7= ABS[ #7 ]
#1= #1 + 90
G00 G90 G80 G40
T25 M06
G43 H25
IF [ #26 ] THEN #26= #5043 - #5083 + #26
G65 P9832 (OMP ON)
G65 P9822 A#1 D#7 Z#26
G103 P1
#101= #188 (Size)
N5 G65 P9833 (OMP OFF)
G00 G90
N6 G103
M99
O00088
(ANGLE & OTVIR MEASURE)
(1-A 24-X 25-Y 26-Z 7-D)
G103 P1
N1 IF [ [ #26 EQ #0 ] OR [ [ #7 EQ #0 ] AND [ #1 EQ #0 ] ] ] GOTO1
IF [ ABS[ #26 ] LT 0.1 ] THEN #26= 10000 * #26
T25 M06
G54 G90 G00 X#24 Y#25
G90 G00 G43 Z100. H25
G65 P9832 (OMP ON)
G65 P9810 Z#26 F2222.
G65 P99 A#1 D#7 R#18
G00 G90 G53 Z0
G103
M99
Пример: измерить расстояние от точки х23.y46.z-8. до поверхности под углом 53°
G65P88X23Y46Z-8A53
Померять диаметр отверстия:
G65P88X102.2Y25Z-10D25
    • streamdown
    • vs3dpro
      А мы-то думали, что пропорциональный гидравлический.....
