Буржуйские ЕСКД
Bajun
Народ, подскажите, есть ли вообще аналоги ЕСКД за рубежом?
Немцы, бриты, пиндосы и пр. как-то же разрабатывают чертежи и схемы, чем они руководствуются?
Изменено пользователем Bajun
ISO 128 (all parts), Technical drawings — General principles of presentation
ISO 129 (all parts), Technical drawings — Indication of dimensions and tolerances
ISO 3040:1990, Technical drawings — Dimensioning and tolerancing — Cones
ISO 3098-0, Technical product documentation — Lettering — Part 0: General requirements
ISO 3098-2:2000, Technical product documentation — Lettering — Part 2: Latin alphabet, numerals and marks
ISO/TR 5460:1985, Technical drawings — Geometrical tolerancing — Tolerancing of form, orientation,
location and run-out — Verification principles and methods — Guidelines
ISO 7083:1983, Technical drawings — Symbols for geometrical tolerancing — Proportions and
dimensions
ISO/TR 14638:1995, Geometrical product specification (GPS) — Masterplan
ISO 16792, Technical product documentation — Digital product definition data practices
ISO 81714-1, Design of graphical symbols for use in the technical documentation of products — Part 1: Basic rules
ISO 3098-5, Technical product documentation — Lettering — Part 5: CAD Lettering of the Latin alphabet, numerals and marks
ISO 1:2002,  Geometrical Product  Specifications  (GPS) — Standard reference temperature for geometrical product specification and verification
ISO 1101:2004, Geometrical Product Specifications (GPS)— Geometrical tolerancing— Tolerances of form, orientation, location and run-out
ISO 1302:2002, Geometrical Product Specifications (GPS) — Indication of surface texture in technical product documentation
ISO/R 1938:1971, ISO system of limits and fits — Part II: Inspection of plain workpieces
ISO 2692:2006. Geometrical product specifications (GPS) — Geometrical tolerancing — Maximum material requirement (MMR), least material requirement (LMR) and reciprocity requirement (RPR)
ISO 2768-1:1989, General tolerances — Part 1: Tolerances for linear and angular dimensions without individual tolerance indications
ISO 14253-1:1998, Geometrical Product Specifications (GPS)— Inspection by measurement of workpieces and measuring equipment— Part 1: Decision rules for proving conformance or non-conformance with specifications
ISO/TR 14638:1995, Geometrical product specifications (GPS) — Masterplan
ISO 17450-1 Geometrical product specifications (GPS) — General concepts — Part 1: Model for geometrical specification and verification
ISO/TS 17450-2:2002, Geometrical product specifications (GPS) — General concepts — Part 2: Basic tenets, specifications, operators and uncertainties
И т.д. и т.п.
Изменено пользователем tmpr
ISO, DIN, AISI и подобные
Это всё аналоги ГОСТ вообще, меня же интересует конкретная система.
Спасибо.
Здесь
Как ФАО или ЕЭК ООН относятся к разработке технической документации?
Я прочту еще раз повнимательнее, может что-то упустил.
Но все же можете сказать, что именно в статье относится к вопросу?
И т.д. и т.п.
Спасибо.
Народ, еще один вопрос: и США и ЕС руководствуются одной системой стандартов при разработке чертежей и схем, или у них разные системы стандартов, или в ЕС у каждой страны по своей системе стандартов?
 Так и ЕСКД состоит из ГОСТов. В упомянутом GD&T (в ссылке вики) там как раз внизу приведены основные документы по ISO
США это имперская система, ЕС метрическая. Одной системы не может быть в принципе. Другое дело, отдельные предприятия могли принять ту или иную систему для работы с конкретными заказчиками.
Bully, я не спорю, что ЕСКД состоит из ГОСТов.
Еще раз: я спрашивал не названия иностранных стандартов, подобных ГОСТ вообще, а конкретно иностранную ЕСКД. Что и предоставили Rino и tmpr.
Bully, я не спорю, что ЕСКД состоит из ГОСТов. Еще раз: я спрашивал не названия иностранных стандартов, подобных ГОСТ вообще, а конкретно иностранную ЕСКД. Что и предоставили Rino и tmpr.
 Понятно. Прошу прощения. Обратил внимание только на
Насколько я понимаю - такой единой системы как ЕСКД у них нет.
Основная часть (чисто техническая), конечно, стандартизирована в ИСО и местных стандартах, и она по всему миру похожа. Но разные бюрократические вещи, типа форматок, вообще могут быть нестандартизированы.
100% аналог нашего ЕСКД в других странах - это только совокупность документов разных организаций.
В Германии, например, кроме DIN есть ещё VDI/VDE и т.д.
В США, кроме ANSI, множество отраслевых организаций - API, AGMA и т.д.
По поводу форматок, например у англичан, можно посмотреть тут: http://www.roymech.co.uk/Useful_Tables/Drawing/Title_blocks.html
Как видим, требования фактически на три надписи... это далеко не ГОСТ.
Прошу уловить главное: Если в СССР/России  ЕСКД, как и любой ГОСТ, имело форму закона, то есть либо по ГОСТу, либо никак, то в буржуйских нормах это - РЕКОМЕНДАЦИИ. Соблюдать ты их обязан лишь только в том случае, если ты этот стандарт указываешь в наименовании продукта. В остальном- делай как хочешь.
Помните фразу "несоблюдение данного ГОСТа преследуется по Закону"?
Необязятельность "их" стандартов, на самом деле никаких особенных проблем не вызывает.
Обязательные стандарты (безопасность, например) так же обязательны. Работать в разрез с необязательными - не особо выгодно.
Технический уровень стандартов не ниже, в каких-то случаях даже выше.
Я хотел наоборот подчеркнуть то, что проблемы часто вызывает "обязательность" российских стандартов.
Например, требование выбирать модули зубчатых передач непременно из норморяда в любом случае.
И это при желании можно обойти.  Только, как Вы правильно заметили, это не особо выгодно, так как придется  тестами доказывать, что применяемые тобой нестандартные детали не хуже стандартизованных, а это очень долго и дорого. Проще взять стандартное и сослаться на него.
А у нас тоже теперь несоблюдение не преследуется по закону. Из новых редакций это вычёркивается.
    • Artas28
      Syntec 220MA Во время смены инструмента, шпиндель по Z уехал выше. После нажатия паузы. Всё встало. Станок находится выше машинного нуля и не опускается. Кто сталкивался? Как опустить?  Ошибка MLCHint R590.7 Plc hint
      @Alexey0336  Да, всё работает: https://cloud.mail.ru/public/NGNq/Ft8UAJtf3
      Так оно и есть, китайский клон Сименс-808.
      Что Вы подразумеваете под словом "Конфликтовать"? Мпроп и мой макрос делают одно и тоже действие, создают и заносят свойства в файл солида. Если свойства с одинаковым именем (например Обозначение и Наименование), то Да, свойство перезапишется тем макросом, которой отработал последним. Щас проверю, отпишусь. Изначально Наименование и Обозначение берутся из имени файла, но его всегда можно перезаписать... Если что, это всегда можно переписать под Ваши требования.
      Если у вас SW не выше 18й версии, могу проверить у себя.
    • Orchestra2603
      Ну, есть же, например QZ алгоритм (обобщение QR разложения, для слуая когда матрица масс не равна I). Отлично работает, когда одна из матриц вырожденная. Вот статься:  https://deepblue.lib.umich.edu/bitstream/handle/2027.42/6667/bac9269.0001.001.pdf?sequence=5   вот коротко в Вики     Раскопал это вообще, глядя в справку от матлаба: https://www.mathworks.com/help/matlab/ref/eig.html.   Это все нюансы....  И все эти алгоритмы сущетсвуют уже кучу лет во всяких библиотеках типа LAPACK. Вы думаете, что в Dassault Systemes или Ansys про это не знают, и их модальник - лажа?
    • karlf
      Сегодня не было времени, завтра посмотрю и пришлю фото как выглядит
      АСКОН выпустил новый релиз среды общих данных Pilot. В нем получили развитие инструменты строительного контроля и авторского надзора, появилась возможность вручную координировать модель объекта капитального строительства. Стройконтроль Вести стройконтроль на площадке, а также авторский надзор за деятельностью арендаторов и собственников поможет привязка панорамных фото объекта к чертежам и документам. Для съемки панорамных фото используется мобильное приложение Pilot-Photo360, доступное для Android. С помощью приложения специалисты строительных организаций, компаний-застройщиков, девелоперов смогут: Находясь на объекте строительства или эксплуатации, фотографировать объект на специализированную панорамную камеру и сразу прикреплять снимки к точкам на чертежах и документах в Pilot-BIM или Pilot-ICE Enterprise. Группировать панорамные снимки по альбомам. Просматривать фото помещения с разных ракурсов, при этом видеть направление взгляда относительно [...] View the full article
    • wega7777
      Судя по формату ошибки похоже на Систему ЧПУ от HCNC — аналог Siemens и Fanuc. ЧПУ HNC808DiT, но могу ошибаться.
    • Alexey0336
      Похоже на то, что мне нужно) Пара вопросов: 1. Будет ли макрос конфликтовать с Mprop? 2. Если я каждой сборке/детали заранее пропишу в обозначение: $PRP:"Порядковый номер" ХХ.YY.ZZZ, подхватит ли формула свойство "порядковый номер" после всех действий?
