TeamCenter: cannot create the export dir/files
Sthighlander
Доброго времени суток! На работе сталкнулся с такой проблемой: при открытии модели детали или сборочной единицы в UG NX из под ТЦЕ выходит ошибка: cannot create the export dir/files
Такая проблема только под обычным пользователем, но под администраторам все нормально.
Вот syslog:
*** c:\temp\q2423b2e0.syslog
*** system log created by q on Wed Jun 25 10:57:42 2014 Московское время (зима)
Node Name    :- otd591-13
Machine type :- Intel x86 Level 6 Revision 0170a
OS           :- Windows NT 5.1 (Workstation) (Build 2600: Service Pack 3)
# Processors :- 2
Memory       :- 3069Mb
Total Swap   :- 4095Mb
Free  Swap   :- 2360Mb
Machine supports 3G address space
Running customer environment
Session is running in codeset 1251 14
UGFLEXlm Log: License server "27000@otd591-13" has been connected.
*************  NX Licensing Information  *************
  Server ID            : UGS
  Webkey Access Code   : 15Q7NS4BIQ
  License File Issuer  : UGS
New Sequencing is enabled.
NX 4.0.0.25
UPDATE: predefined fail option is <Unknown>
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\ugii\ugxml.dll
Module signature = 2660000 1d000 711a34ad-4bb4a408-a96419b6-c6de68e9-1=ugxml___1130817314 version = 4.0.0.25
UGXML is using 'windows-1251' as the local code page
No user customizations read from UGII_SITE_DIR - environment variable is not set
No user customizations read from UGII_GROUP_DIR - environment variable is not set
No user customizations read from UGII_USER_DIR - environment variable is not set
Processing customer default values file C:\Documents and Settings\q\Local Settings\Application Data\Unigraphics Solutions\NX4\nx4_user.dpv
	User customizations file C:\Documents and Settings\q\Local Settings\Application Data\Unigraphics Solutions\NX4\nx4_user.dpv does not exist
Customer CDF (Color Definition File) is not defined
FR_PSMARK: system page size = 4096, ram block size = 1024, disk file threshold =32769, buffer size = 16384
Parasolid version 17.0 build 210 on 19:45:3 29-9-2005
2D DCM version 470002006
CMOD delete: predefined, dumbify-feature option is <TRUE>
CMOD delete: predefined, propagate-delete option is <ON>
CMOD update: predefined, fail-on-missing-refs option is <OFF>
DUC: Initial Session Delay: OFF
DUC: Delay non-displayed parts: OFF
Descriptive Part Names set to $FILENAME
Assemblies: Model reference set defined to be MODEL.
Assemblies: No facet reference set is defined.
Unigraphics V18.0 CAD/PDM Hookup
Release Information
	Version: H.01.01
	Date:    Oct 31 2005
Certified for iMAN Release V7.0.1
NX Manager: Using PDI CORBA to connect to Teamcenter Engineering.
            PDI CORBA module: ugmanager/pdi_corba_client
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\ugmanager\pdi_corba_client.dll
Module signature = 3520000 162000 64fe27e1-46618b8f-88afbd9d-7ce202d-1=pdi_corba_client___1130817011 version = 4.0.0.25
NX Manager Client PDI version: <H.01.01>
NX Manager Server PDI version: <I.01.01>
NX Manager client and server versions confirmed as compatible
UG/Manager: capability Simulation_support is disabled
UG/Manager: capability Add_To_Folder_Tolerant is enabled
UG/Manager: capability AIWEB_chkout_reprev is enabled
UG/Manager: capability ALTERNATE_IDS is enabled
UG/Manager: capability Ask_Checkout_Reason is enabled
UG/Manager: capability Ask_Saveas_Appdata_Info is enabled
UG/Manager: capability Ask_VLA_read_only is enabled
UG/Manager: capability Assembly_Arrangements is enabled
UG/Manager: capability AttrSync_Allow_NullValue is enabled
UG/Manager: capability ATTRSYNC_With_Itemrev is enabled
UG/Manager: capability BOM_Compare_On_Save is enabled
UG/Manager: capability CAE_mgr_v1_support is enabled
UG/Manager: capability CAE_mgr_v2_support is enabled
UG/Manager: capability CAE_mgr_v3_support is enabled
UG/Manager: capability CAM_temp_dir is enabled
UG/Manager: capability CME_env is enabled
UG/Manager: capability Configurable_App_Name is enabled
UG/Manager: capability DB_Settings is enabled
UG/Manager: capability Delete_JT_File_Support is enabled
UG/Manager: capability Find_Config_Childrev is enabled
UG/Manager: capability FMS_Available is enabled
UG/Manager: capability FMS_Available_Phase2 is enabled
UG/Manager: capability Foreign_Assy is enabled
UG/Manager: capability Foreign_Files is enabled
UG/Manager: capability KF_wizard_files is enabled
UG/Manager: capability Master_Model_Relation is enabled
UG/Manager: capability Multisite_Part_Families is enabled
UG/Manager: capability NX_Perf_Improvements is enabled
UG/Manager: capability NX_Perf_Improvements2 is enabled
UG/Manager: capability NX_Perf_Improvements3 is enabled
UG/Manager: capability NX_RemoteCICO_Support is enabled
UG/Manager: capability NX_Routing_Support is enabled
UG/Manager: capability Partlist_Enhancement is enabled
UG/Manager: capability PDM_Feature_Support is enabled
UG/Manager: capability Portal_Update is enabled
UG/Manager: capability RESET_Model_name_desc is enabled
UG/Manager: capability Simulation_support is enabled
UG/Manager: capability SOA_PDI_Sets_Support is enabled
UG/Manager: capability SOA_Support is enabled
UG/Manager: capability TCM_OCC_Type_Support is enabled
UG/Manager: capability TCM_V101_template is enabled
UG/Manager: capability TCM_V91_Enhancements is enabled
UG/Manager: capability TC_Web_ImanFile_URL is enabled
UG/Manager: capability Transient_Saveas is enabled
UG/Manager: capability UGMPFMs_V9_Enhancements is enabled
UG/Manager: capability UID_Based_Part_Names is enabled
UG/Manager: capability UID_Names_Query_Ids is enabled
UG/Manager: capability UpdatePreciseOnSave is enabled
UG/Manager: capability USE_EXT_TRANSFORMS is enabled
UG/Manager: capability Validation_Objects is enabled
UG/Manager: capability Val_Objs_v10_enhancement is enabled
UG/Manager: capability Variant_Items is enabled
UG/Manager: capability Warn_save_Precise_Assembly is enabled
UG/Manager: Loaded attribute mappings in cpu    0.016, real    0.531
NX Manager Server system log : S:\2005SR1\portal\temp\tcserver.exed32b45e0.syslog
NX Manager environment data
Current directory = C:\Temp
Customer Default Settings:
    UGMGR_StructureUpdateOnLoad: On
    UGMGR_StructureUpdateOnSave: On
    UGMGR_CalloutAttribute:      DB_SEQUENCE_NO
    UGMGR_Export:                On
    UGMGR_UserRole:              all
    UGMGR_Unlock:                CLOSE
    UGMGR_Locking_Policy:        AUTOMATIC
Recognisable foreign dataset types (default ordered list declared in the Teamcenter setting) :-
NX Manager: Could not retrieve registry key HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\@@@\General\UGManager\Foreign_Types, name Number with new int value 0 (ifail 1555007)
Hierarchical foreign dataset type (actual search order used from the NX preference) :-
NX Manager Load Options Are :-
    Load Options      : With Revision Rules : Последняя по дате создания
                        Effective date : Not Set, Unit Nos. = Units not set
    Load Components   : Load all the component parts
    Failure Option    : Do not abort load on failure
    Load Fully        : Do not fully load the component parts
    Load Substitution : Do not allow substitutions on load
    Reference Sets    : Do not apply to all levels
    Load Wave Data    : Default load behaviour
    Part family members : Regenerate missing members automatically
A master env file has not been loaded
 **************  Locked Unigraphics Configuration Variables  **************
    UGII_VERSION                     v4
    UGII_FULL_VERSION                v4.0.0.25
 **************        System Environment Variables          **************
    CLASSPATH                        .;set CLASSPATH=C:\oracle\ora92\jdbc\lib\classes12.zip;C:\oracle\ora92\jdbc\lib\ojdbc14.jar;c:\rpc\repc10.jar;c:\rpc\components476\modules\swing-layout-1.0.3.jar;c:\rpc\components476\modules\swing-layout-1.0.4.jar;C:\Program Files\UGS\Teamcenter 2007\RAC Visualization\Program;C:\Program Files\UGS\Teamcenter 2007\RAC Visualization\Program\VisWebS.jar;C:\Program Files\UGS\Teamcenter 2007\RAC Visualization\Program\eaisupportS.jar;C:\Program Files\UGS\Teamcenter 2007\RAC Visualization\Program\SingleEmbeddedViewer.jar;C:\Program Files\UGS\Teamcenter 2007\RAC Visualization\Program\SingleEmbeddedViewerS.jar;S:\2005SR1\portal\fms\jar\fmsutil.jar;S:\2005SR1\portal\fms\jar\fccjavaclientproxy.jar;.\xmldto.jar;c:\rpc\components476\modules\JavaApplication7.jar;.\xml-apis.jar;.\xercesImpl.jar;.\xmlParserAPIs.jar;.\resolver.jar;.\00axis-patch.jar;.\axis.jar;.\jax-qname.jar;.\jaxrpc.jar;.\log4j-1.2.8.jar;.\saaj.jar;.\wsdl4j.jar;.\TcGatewayWebService.jar;.\commons-logging.jar;.\commons-discovery.jar;.\commons-httpclient-2_0_2.jar;.\tcgatewaystubs.jar;.\jacorb.jar;.\avalon-framework-4.1.5.jar;.\logkit.jar;.\icctstubs.jar;.\portal_patch.jar;.\jgraph.jar;.\portal_localization.jar;.\portal.jar;.\xml4j.jar;.\xalan.jar;.\java2com.jar;.\shdocvw-neva.jar;.\wordexcel-neva.jar;.\ssoapplib.jar;.\ssocommon.jar;.\soap.jar;.\mail.jar;.\activation.jar;.\ugstudioplugin.jar;.\processstudio.jar;.\WolfRegistryClient.jar;.\jaxb-api.jar;.\jaxb-impl.jar;.\jaxb-libs.jar;.\namespace.jar;.\relaxngDatatype.jar;.\xsdlib.jar;.\visdis.jar;.\visdis-resource.jar;.\jakarta-slide-webdavlib-2_0.jar
    IMANLIBS                         S:\2005SR1\bin
    IMAN_ROOT                        S:\2005SR1
    JRE_HOME                         S:\2005SR1\portal\jre
    PATH                             C:\Program Files\UGS\NX 4.0\ugii;S:\2005SR1\bin;S:\2005SR1\portal\fms\bin;S:\2005SR1\portal\fms\lib;S:\2005SR1\portal;D:\app\product\11.1.0\db_1\bin;C:\PROGRA~1\Borland\CBUILD~1\Bin;C:\PROGRA~1\Borland\CBUILD~1\Projects\Bpl;C:\Program Files\Java\jdk1.7.0_21\bin;c:\Program Files\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;S:\2005SR1\bin
    PATHEXT                          .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
    TEMP                             C:\temp_tce
    TMP                              c:\temp
    UGII_BASE_DIR                    C:\Program Files\UGS\NX 4.0
    UGII_DISABLE_FLASH               YES
    UGII_LANG                        russian
    UGII_LICENSE_FILE                27000@otd591-13
    UGII_ROOT_DIR                    C:\Program Files\UGS\NX 4.0\ugii\
    UGII_TEMP_DIR                    c:\temp_tce
    UGII_TMP_DIR                     c:\temp
    UGII_UGMGR_EXTERNAL_COMMS_LIB    pdi_corba_client
    USERDNSDOMAIN                    ITSP.AVIASTAR-SP.RU
    USERDOMAIN                       ITSP
    USERNAME                         q
    USERPROFILE                      C:\Documents and Settings\q
    IMAN_DATA                        S:\utv
 Using ugii_env.dat file from C:\Program Files\UGS\NX 4.0\ugii\\ugii_env.dat
 ************** Unlocked Unigraphics Configuration Variables **************
    HOME                             c:\temp
    UGII_LANG                        russian
    UGII_LANGUAGE_FILE               C:\Program Files\UGS\NX 4.0\localization\ugii_russian.lng
    UGII_08_FILE                     C:\Program Files\UGS\NX 4.0\ugopen\08.ugf
    UGII_10_FILE                     C:\Program Files\UGS\NX 4.0\ugii\10.ugf
    UGII_SCHEMA                      C:\Program Files\UGS\NX 4.0\ugii\ugschema
    UGII_ENGLISH_THREADS             C:\Program Files\UGS\NX 4.0\ugii\thd_english.dat
    UGII_METRIC_THREADS              C:\Program Files\UGS\NX 4.0\ugii\thd_metric.dat
    UGII_OLD_SKETCH                  0
    UGII_DUMBIFY_FEATURE             1
    UGII_WAVE_DELETE                 0
    MOLDWIZARD_DIR                   C:\Program Files\UGS\NX 4.0\moldwizard
    MOLDWIZARD_LIB_DIR               C:\Program Files\UGS\NX 4.0\moldwizard
    ELECTRODE_DESIGN_DIR             C:\Program Files\UGS\NX 4.0\moldwizard\electrode
    GEARWIZARD_DIR                   C:\Program Files\UGS\NX 4.0\gearwizard
    PDIEWIZARD_DIR                   C:\Program Files\UGS\NX 4.0\pdiewizard
    PDIEWIZARD_LIB_DIR               C:\Program Files\UGS\NX 4.0\pdiewizard
    TOOLING_BASE_DIR                 C:\Program Files\UGS\NX 4.0\tooling_base
    UGWELD_DIR                       C:\Program Files\UGS\NX 4.0\ugweld
    UGII_WELD_BASE_DIR               C:\Program Files\UGS\NX 4.0\ugweld
    UGII_EXPMAN_CFG_FILE             C:\Program Files\UGS\NX 4.0\ugexpman\expmancfg.dat
    UGII_UDF_LAYER_ORIGINAL          0
    UGII_INOP_SE_IMPORT_ONLY_DESIGN_PART 0
    UGCHECKMATE_DIR                  C:\Program Files\UGS\NX 4.0\ugcheckmate
    UGCHECKMATE_CONFIG               C:\Program Files\UGS\NX 4.0\ugcheckmate\ugcheckmate.dat
    UGII_CHECKMATE_OUTPUT_MQCLOG     1
    UGCHECKMATE_XMLLOG_XSL_FILE      C:\Program Files\UGS\NX 4.0\ugcheckmate\examples\checkmate_log.xsl
    UGCHECKMATE_MENU_TEMPLATE_FILE   C:\Program Files\UGS\NX 4.0\ugcheckmate\user_defined_menu_template.txt
    UGQUICKCHECK_DIR                 C:\Program Files\UGS\NX 4.0\ugquickcheck
    UGII_CAM_BASE_DIR                C:\Program Files\UGS\NX 4.0\mach\
    UGII_CAM_CUSTOM_DIR              C:\Program Files\UGS\NX 4.0\mach\custom\
    UGII_CAM_RESOURCE_DIR            C:\Program Files\UGS\NX 4.0\mach\resource\
    UGII_CAM_SAMPLES_DIR             C:\Program Files\UGS\NX 4.0\mach\samples\
    UGII_CAM_AUXILIARY_DIR           C:\Program Files\UGS\NX 4.0\mach\auxiliary\
    UGII_APT_VOC                     C:\Program Files\UGS\NX 4.0\mach\auxiliary\apt.voc
    UGII_BCL_VOC                     C:\Program Files\UGS\NX 4.0\mach\auxiliary\bcl.voc
    UGII_ISO_VOC                     C:\Program Files\UGS\NX 4.0\mach\auxiliary\iso.voc
    UGII_UNIMAJ_VOC                  C:\Program Files\UGS\NX 4.0\mach\auxiliary\unimaj.voc
    UGII_UNIMIN_VOC                  C:\Program Files\UGS\NX 4.0\mach\auxiliary\unimin.voc
    UGII_VERICUT                     C:\Program Files\UGS\NX 4.0\win_nt\commands\vericut.bat
    UGII_CAM_THREAD_MILL_DIR         C:\Program Files\UGS\NX 4.0\mach\auxiliary\thread_mill\
    UGII_CAM_THREAD_MILL             C:\Program Files\UGS\NX 4.0\mach\auxiliary\thread_mill\thrm.dll
    UGII_CAM_BATCH_DIR               C:\Program Files\UGS\NX 4.0\mach\auxiliary\batch\
    UGII_CAMBATCH_BACKGROUND_EXE     C:\Program Files\UGS\NX 4.0\mach\auxiliary\batch\cambatch_background.exe
    UGII_CAM_TAGGING_DIR             C:\Program Files\UGS\NX 4.0\mach\auxiliary\tagging\
    UGII_CAM_TAGGING_DLL_DIR         C:\Program Files\UGS\NX 4.0\mach\auxiliary\tagging\application\
    UGII_CAM_TAGGING_ENGLISH_DIR     C:\Program Files\UGS\NX 4.0\mach\auxiliary\tagging\english\
    UGII_CAM_TAGGING_METRIC_DIR      C:\Program Files\UGS\NX 4.0\mach\auxiliary\tagging\metric\
    UGII_CAM_FILE_SEARCH_PATH        .\;C:\Program Files\UGS\NX 4.0\mach\;C:\Program Files\UGS\NX 4.0\mach\resource\
    UGII_CAM_CONFIG_DIR              C:\Program Files\UGS\NX 4.0\mach\resource\configuration\
    UGII_CAM_CONFIG                  C:\Program Files\UGS\NX 4.0\mach\resource\configuration\cam_general.dat
    UGII_SHOPS_DIE_MOLD_CONFIG       C:\Program Files\UGS\NX 4.0\mach\resource\configuration\shops_diemold.dat
    UGII_SHOPS_MACHINERY_CONFIG      C:\Program Files\UGS\NX 4.0\mach\resource\configuration\shops_machinery.dat
    UGII_CAM_TEMPLATE_SET_DIR        C:\Program Files\UGS\NX 4.0\mach\resource\template_set\
    UGII_CAM_TEMPLATE_PART_DIR       C:\Program Files\UGS\NX 4.0\mach\resource\template_part\
    UGII_CAM_TEMPLATE_PART_ENGLISH_DIR C:\Program Files\UGS\NX 4.0\mach\resource\template_part\english\
    UGII_CAM_TEMPLATE_PART_METRIC_DIR C:\Program Files\UGS\NX 4.0\mach\resource\template_part\metric\
    UGII_CAM_LIBRARY_TEMPLATE_DIR    C:\Program Files\UGS\NX 4.0\mach\resource\template_dir\
    UGII_CAM_SHOP_DOC_DIR            C:\Program Files\UGS\NX 4.0\mach\resource\shop_doc\
    UGII_CAM_PART_DOC_CONFIG_FILE    C:\Program Files\UGS\NX 4.0\mach\resource\shop_doc\shop_doc.dat
    UGII_CAM_POST_DIR                C:\Program Files\UGS\NX 4.0\mach\resource\postprocessor\
    UGII_CAM_POST_CONFIG_FILE        C:\Program Files\UGS\NX 4.0\mach\resource\postprocessor\template_post.dat
    UGII_CAM_LIBRARY_MACHINE_CONFIG_DIR C:\Program Files\UGS\NX 4.0\mach\resource\postprocessor\
    UGII_CAM_USER_DEF_EVENT_DIR      C:\Program Files\UGS\NX 4.0\mach\resource\user_def_event\
    UGII_CAM_TOOL_PATH_DIR           C:\Program Files\UGS\NX 4.0\mach\resource\tool_path\
    UGII_CAM_WIZARD_DIR              C:\Program Files\UGS\NX 4.0\mach\resource\wizard\
    UGII_CAM_DEBUG_DIR               C:\Program Files\UGS\NX 4.0\mach\resource\debug\
    UGII_CAM_DEFAULT_TYPE_TEMPLATE   C:\Program Files\UGS\NX 4.0\mach\resource\template_set\cam_general.opt
    UGII_CAM_IMAN_TYPE_TEMPLATE      C:\Program Files\UGS\NX 4.0\mach\resource\template_set\cam_teamcenter_general.opt
    UGII_CAM_FEATURE_DATA_DIR        C:\Program Files\UGS\NX 4.0\mach\resource\feature\
    UGII_CAM_FEATURE_DATA_ENGLISH_DIR C:\Program Files\UGS\NX 4.0\mach\resource\feature\english\
    UGII_CAM_FEATURE_DATA_METRIC_DIR C:\Program Files\UGS\NX 4.0\mach\resource\feature\metric\
    UGII_CAM_SPREADSHEET_DIR         C:\Program Files\UGS\NX 4.0\mach\resource\spreadsheet\
    UGII_UG_LIBRARY_DIR              C:\Program Files\UGS\NX 4.0\mach\resource\ug_library\
    UGII_CAM_LIBRARY_DIR             C:\Program Files\UGS\NX 4.0\mach\resource\library\
    UGII_CAM_LIBRARY_TOOL_DIR        C:\Program Files\UGS\NX 4.0\mach\resource\library\tool\
    UGII_CAM_LIBRARY_TOOL_ASCII_DIR  C:\Program Files\UGS\NX 4.0\mach\resource\library\tool\ascii\
    UGII_CAM_LIBRARY_TOOL_GENIUS_DIR C:\Program Files\UGS\NX 4.0\mach\resource\library\tool\genius\
    UGII_CAM_LIBRARY_TOOL_INCLASS_DIR C:\Program Files\UGS\NX 4.0\mach\resource\library\tool\inclass\
    UGII_CAM_LIBRARY_TOOL_ENGLISH_DIR C:\Program Files\UGS\NX 4.0\mach\resource\library\tool\english\
    UGII_CAM_LIBRARY_TOOL_METRIC_DIR C:\Program Files\UGS\NX 4.0\mach\resource\library\tool\metric\
    UGII_CAM_LIBRARY_TOOL_GRAPHICS_PATH C:\Program Files\UGS\NX 4.0\mach\resource\library\tool\graphics\
    UGII_CAM_LIBRARY_TOOL_ASCII_LOAD_LIMIT 100000
    UGII_CAM_LIBRARY_DEVICE_DIR      C:\Program Files\UGS\NX 4.0\mach\resource\library\device\
    UGII_CAM_LIBRARY_DEVICE_DATA_DIR C:\Program Files\UGS\NX 4.0\mach\resource\library\device\ascii\
    UGII_CAM_LIBRARY_DEVICE_ASCII_DIR C:\Program Files\UGS\NX 4.0\mach\resource\library\device\ascii\
    UGII_CAM_LIBRARY_DEVICE_INCLASS_DIR C:\Program Files\UGS\NX 4.0\mach\resource\library\device\inclass\
    UGII_CAM_LIBRARY_DEVICE_GRAPHICS_PATH C:\Program Files\UGS\NX 4.0\mach\resource\library\device\graphics\
    UGII_CAM_LIBRARY_MACHINE_DIR     C:\Program Files\UGS\NX 4.0\mach\resource\library\machine\
    UGII_CAM_LIBRARY_MACHINE_ASCII_DIR C:\Program Files\UGS\NX 4.0\mach\resource\library\machine\ascii\
    UGII_CAM_LIBRARY_MACHINE_DATA_DIR C:\Program Files\UGS\NX 4.0\mach\resource\library\machine\ascii\
    UGII_CAM_LIBRARY_MACHINE_GENIUS_DIR C:\Program Files\UGS\NX 4.0\mach\resource\library\machine\genius\
    UGII_CAM_LIBRARY_MACHINE_INCLASS_DIR C:\Program Files\UGS\NX 4.0\mach\resource\library\machine\inclass\
    UGII_CAM_LIBRARY_MACHINE_GRAPHICS_PATH C:\Program Files\UGS\NX 4.0\mach\resource\library\machine\graphics\
    UGII_CAM_LIBRARY_FEEDS_SPEEDS_DIR C:\Program Files\UGS\NX 4.0\mach\resource\library\feeds_speeds\
    UGII_CAM_LIBRARY_FEEDS_SPEEDS_ASCII_DIR C:\Program Files\UGS\NX 4.0\mach\resource\library\feeds_speeds\ascii\
    UGII_CAM_LIBRARY_FEEDS_SPEEDS_DATA_DIR C:\Program Files\UGS\NX 4.0\mach\resource\library\feeds_speeds\ascii\
    UGII_CAM_LIBRARY_FEEDS_SPEEDS_GENIUS_DIR C:\Program Files\UGS\NX 4.0\mach\resource\library\feeds_speeds\genius\
    UGII_CAM_LIBRARY_UDF_DIR         C:\Program Files\UGS\NX 4.0\mach\resource\library\udf\
    UGII_UG_LIBRARY_GENIUS_TCP_HOST  localhost
    UGII_UG_LIBRARY_GENIUS_TCP_PORT  2326
    UGII_KF_CLASS_DIR                C:\Program Files\UGS\NX 4.0\ugii\dfa
    UGII_TAB_LABEL_FORMATS_FILE      C:\Program Files\UGS\NX 4.0\ugii\tab_label_format_file.xml
    UGII_SYMBOL_LIBRARY_DIR          C:\Program Files\UGS\NX 4.0\ugii\symbol\
    UGII_UGDOC_BASE_DIR              C:\Program Files\UGS\NX 4.0\ugdoc
    UGII_UGDOC                       C:\Program Files\UGS\NX 4.0\ugdoc\html_files\NT_mainlibrary.html
    UGII_HTML_UGDOC                  C:\Program Files\UGS\NX 4.0\ugdoc\html_files\mainlibrary.html
    UGII_WV_UGDOC                    C:\Program Files\UGS\NX 4.0\ugdoc\ugdoc.bat
    UGII_CSHELP_MAPS                 C:\Program Files\UGS\NX 4.0\ugdoc\html_files\docmaps
    UGII_CSHELP_DOCS                 C:\Program Files\UGS\NX 4.0\ugdoc\html_files
    UGII_CSHELP_HTML_MAPS            C:\Program Files\UGS\NX 4.0\ugdoc\html_files\docmaps
    UGII_CSHELP_HTML_DOCS            C:\Program Files\UGS\NX 4.0\ugdoc\html_files
    UGII_CAST                        C:\Program Files\UGS\NX 4.0\ugcast\castonly.bat
    UGII_CAST_HOME                   C:\Program Files\UGS\NX 4.0\UGII\html_files\start_russian.html
    UGALLIANCE_DIR                   C:\Program Files\UGS\NX 4.0\ugalliance
    UGII_DEFAULT_MENU_DIR            C:\Program Files\UGS\NX 4.0\ugii\menus
    UGII_CUSTOM_DIRECTORY_FILE       C:\Program Files\UGS\NX 4.0\ugii\menus\custom_dirs.dat
    UGII_UG_CUSTOM_DIRECTORY_FILE    C:\Program Files\UGS\NX 4.0\ugii\menus\ug_custom_dirs.dat
    UGII_MAIN_MENU_FILE              C:\Program Files\UGS\NX 4.0\ugii\menus\ug_main.men
    UGII_VIEW_POPUP_MENU_FILE        C:\Program Files\UGS\NX 4.0\ugii\menus\ug_view_popup.men
    UGII_APPL_POPUP_MENU_FILE        C:\Program Files\UGS\NX 4.0\ugii\menus\ug_application_popup.men
    UGII_LOCAL_USER_DEFAULTS         C:\Documents and Settings\q\Local Settings\Application Data\Unigraphics Solutions\NX4\nx4_user.dpv
    UGII_BITMAP_PATH                 C:\Program Files\UGS\NX 4.0\ugii\symbol\
    UGII_CHARACTER_FONT_DIR          C:\Program Files\UGS\NX 4.0\ugii\ugfonts
    UGII_CHARACTER_FONT_DEFAULT      blockfont
    UGII_EDITOR                      notepad
    UGII_LIB1                        c:\temp
    UGII_LIB2                        C:\Program Files\UGS\NX 4.0\ugii\
    UGII_UTIL                        C:\Program Files\UGS\NX 4.0\ugii\
    UGII_TAPEBAUD                    1200
    UGII_FLEX_PART_LOG               2
    UGII_UGMX                        C:\Program Files\UGS\NX 4.0\ugmx\me\etc\startmcad
    UGII_MXUG_FILE                   c:\temp\
    UGII_UGMX_FILE                   c:\temp\
    UGII_SHARE                       C:\Program Files\UGS\NX 4.0\ugii\
    UGII_SPREADSHEET                 C:\Program Files\UGS\NX 4.0\ugii\
    UGII_LOAD_OPTIONS
    UGII_PHYS_MATERIAL_LIB_DIR       C:\Program Files\UGS\NX 4.0\ugii\materials\russian\
    UGII_PHYS_MATERIAL_LIB_DATA_DIR  C:\Program Files\UGS\NX 4.0\ugii\materials\
    UGII_PHYS_MATERIAL_LIB_PATH      .\;C:\Program Files\UGS\NX 4.0\ugii\materials\
    UGII_CAE_REPORT_TEMPLATES_DIR    C:\Program Files\UGS\NX 4.0\UGSTRUCTURES\
    UGII_CAE_POST_TEMPLATE_USER_DIR  c:\temp\post_template_files
    USER_GEO_UNF                     *C:\Program Files\UGS\NX 4.0\unfold\flatpat.grx
    USER_PUNCHTOOLS                  *C:\Program Files\UGS\NX 4.0\punchpress\buildtool.grx
    USER_PUNCH                       *C:\Program Files\UGS\NX 4.0\punchpress\punchlaser.grx
    USER_PUNCHGRID                   *C:\Program Files\UGS\NX 4.0\punchpress\punchgrid.grx
    USER_PDAIF                       C:\Program Files\UGS\NX 4.0\ugpatif\ugpatif
    USER_ICADIF                      C:\Program Files\UGS\NX 4.0\icadif\uficad
    UNC_LANG                         eng
    UNC_CAM_DIR                      C:\Program Files\UGS\NX 4.0\sheetmfg\unc\
    UGII_UGSMD_STDS_LIBRARY          C:\Program Files\UGS\NX 4.0\ugii\
    UGII_ROUTING_APP_VIEW_DIR        C:\Program Files\UGS\NX 4.0\ugroute_mech\appview\;C:\Program Files\UGS\NX 4.0\ugroute_elec\appview\
    UGII_ROUTE_ELEC_APP_VIEW         C:\Program Files\UGS\NX 4.0\ugroute_elec\appview\ugroute_elec_mm.xml
    UGII_ROUTE_MECH_APP_VIEW         C:\Program Files\UGS\NX 4.0\ugroute_mech\appview\ugroute_mech_mm.xml
    UGII_ROUTE_LGCL_APP_VIEW         C:\Program Files\UGS\NX 4.0\ugroute_mech\appview\ugroute_lgcl_mm.xml
    UGII_EPLIB_PART_LIB_VIEW_PATH    C:\Program Files\UGS\NX 4.0\ugroute_mech\appview\;C:\Program Files\UGS\NX 4.0\ugroute_elec\appview\
    UGII_EPLIB_TABLE_PATH            C:\Program Files\UGS\NX 4.0\ugroute_mech\metric\tables\;C:\Program Files\UGS\NX 4.0\ugroute_elec\metric\tables\
    UGII_ROUTE_ELEC_PART_PATH        C:\Program Files\UGS\NX 4.0\ugroute_elec\metric\parts
    UGII_ROUTE_MECH_PART_PATH        C:\Program Files\UGS\NX 4.0\ugroute_mech\metric\parts
    UGII_ROUTE_LGCL_PART_PATH        C:\Program Files\UGS\NX 4.0\ugroute_mech\metric\parts
    UGII_ROUTING_DESIGN_RULES_PATH   C:\Program Files\UGS\NX 4.0\ugroute_mech\rules\;C:\Program Files\UGS\NX 4.0\ugroute_elec\rules\
    UGII_ROUTE_ELEC_TCL_DIR          C:\Program Files\UGS\NX 4.0\ugroute_elec\rules\tcl\
    UGII_ROUTE_MECH_TCL_DIR          C:\Program Files\UGS\NX 4.0\ugroute_mech\rules\tcl\
    UGII_ROUTE_LGCL_TCL_DIR          C:\Program Files\UGS\NX 4.0\ugroute_mech\rules\tcl\
    UGII_RLIST_PATH                  C:\Program Files\UGS\NX 4.0\ugroute_elec\rlist\
    UGII_FMBD_FORMATS_FILE           C:\Program Files\UGS\NX 4.0\ugroute_elec\rlist\fmbd_annotation.fmt
    UGII_FMBD_USE_LAYOUTS            FALSE
    UGII_FMBD_PATTERN_DIR            C:\Program Files\UGS\NX 4.0\ugroute_elec\metric\parts
    UGII_FMBD_CGM_DIR                C:\Program Files\UGS\NX 4.0\ugroute_elec\metric\parts
    UGII_RLIST_SCHEMA_FILE           C:\Program Files\UGS\NX 4.0\ugroute_elec\rlist\routelist.xsd
    UGII_ROUTING_BOM_PATH            C:\Program Files\UGS\NX 4.0\ugroute_mech\metric\parts\
    UGII_ROUTING_BEND_TABLES_PATH    C:\Program Files\UGS\NX 4.0\ugroute_mech\metric\tables\
    UGII_ROUTE_SKIP_LENGTH_ADDITION_CHARX TRUE
    MAYA_PCB_DIR                     C:\Program Files\UGS\NX 4.0\ugpcbxchange
    UGII_REFL_IMAGE_DIR              C:\Program Files\UGS\NX 4.0\ugii\ugvisuals\
    UGII_TEXTURE_TIFF_IMAGE_DIR      C:\Program Files\UGS\NX 4.0\ugstudio\
    UGII_NO_TIFF_SEARCH
    UGII_LI_LAYLA_DIR                C:\Program Files\UGS\NX 4.0\ugphoto
    UGII_RENDER_ARTISTIC_DIR         C:\Program Files\UGS\NX 4.0\ugphoto\artistic_render\
    UGII_SHOWROOM_DATA_DIR           C:\Program Files\UGS\NX 4.0\ugphoto\ug_environment
    UGII_USER_SHOWROOM_DATA_DIR
    UGII_CANNED_MATERIAL_DIR         C:\Program Files\UGS\NX 4.0\ugphoto\ug_canned_mattex
    UGII_MAX_FACETING_SCALE          125.0
    UGII_SDI_BASE                    C:\Program Files\UGS\NX 4.0\nxplot
    STEP203UG_DIR                    C:\Program Files\UGS\NX 4.0\step203ug\
    STEP214UG_DIR                    C:\Program Files\UGS\NX 4.0\step214ug\
    DXFDWG_DIR                       C:\Program Files\UGS\NX 4.0\dxfdwg\
    IGES_DIR                         C:\Program Files\UGS\NX 4.0\iges\
    UGTO2D_DIR                       C:\Program Files\UGS\NX 4.0\ugto2d\
    UGII_CATIA_DIR                   C:\Program Files\UGS\NX 4.0\ugcatia\
    UGII_CATIAV5_DIR                 C:\Program Files\UGS\NX 4.0\catiav5\
    UGII_NXPROE_DIR                  C:\Program Files\UGS\NX 4.0\nxproe\
    UGII_UGMANAGER_DIR               C:\Program Files\UGS\NX 4.0\ugmanager\
    UGII_UGMGR_ATTR_SYNC             NEW
    UGII_MSC_NASTRAN                 C:\msc\bin\
    UGII_NX_NASTRAN                  C:\Program Files\UGSPLM\NXNastran\2.0\bin\
    UGII_MSC_NASTRAN_VERSION         70
    UGII_NX_NASTRAN_VERSION          2.0
    UGII_ANSYS                       C:\ansys55\bin\Intel
    UGII_ANSYS_VERSION               5.5
    UGII_ANSYS_PRODUCT               ANSYS
    UGII_ABAQUS                      C:\ABAQUS\Commands\
    UGII_CONVERT_OLD_MOTION_CONTACTS 0
    UGII_CREATE_OLD_MOTION_CONTACTS  0
    UG_IMAGE                         ugspawn.bat
    UGII_USERFCN                     C:\Program Files\UGS\NX 4.0\ugopen
    UGII_GDT_DIR                     C:\Program Files\UGS\NX 4.0\ugii\gdt_files
    QUICKSTACK_DIR                   C:\Program Files\UGS\NX 4.0\tolstackup\ugquickstack
    UGII_QS_DEFS_DIR                 C:\Program Files\UGS\NX 4.0\tolstackup\ugquickstack\application
    TOLSTACKUP_DIR                   C:\Program Files\UGS\NX 4.0\tolstackup
    UGII_TSV_DEFS_DIR                C:\Program Files\UGS\NX 4.0\tolstackup\application
    UGII_ANNOTATION_TEMPLATE_DIR     C:\Program Files\UGS\NX 4.0\ugii\inh_files\
    UGII_TABLE_TEMPLATES             C:\Program Files\UGS\NX 4.0\ugii\table_files\
    UGII_UPDATE_ALL_ID_SYMBOLS_WITH_PLIST 1
    UGII_SURFACE_FINISH              OFF
    UGII_VSAEXPORT_DIR               C:\Program Files\UGS\NX 4.0\ugvsaexport
    UF_MF_PA_PATH                    C:\moldflow\mpa300\bin
    UF_MF_PA_FACET_TOL               0.05
    UF_MF_PA_MAX_EDGE                10.0
    UF_MF_PA_STL_DIR
    UF_MF_PA_STL_SUF                 slp
    UGPROCESS_AID                    C:\Program Files\UGS\NX 4.0\ugprocess_aid
    UGII_PROCESS_AID_DIR             C:\Program Files\UGS\NX 4.0\ugprocess_aid
    UGAUTOMOTIVE_DIR                 C:\Program Files\UGS\NX 4.0\ugautomotive
    UGBODYDES_DIR                    C:\Program Files\UGS\NX 4.0\ugautomotive\bodydes
    UGDIEDES_DIR                     C:\Program Files\UGS\NX 4.0\ugautomotive\diedes
    UGDIEENG_DIR                     C:\Program Files\UGS\NX 4.0\ugautomotive\dieeng
    UG_VPACK_DIR                     C:\Program Files\UGS\NX 4.0\ugautomotive\packaging
    UG_BD_DEFAULTS_FILE              C:\Program Files\UGS\NX 4.0\ugautomotive\bodydes\defdat\ug_body_design.def
    UGII_VD_WS_REQ_SPREADSHEET_FILE  C:\Program Files\UGS\NX 4.0\ugautomotive\packaging\requirements\windshield_vision_zones_requirement_spreadsheet.xls
    UGDIEDES_STANDARD_DIR            C:\Program Files\UGS\NX 4.0\ugautomotive\diedes
    NXSHIP_DIR                       C:\Program Files\UGS\NX 4.0\nxship
    NXSHIP_GSD_DIR                   C:\Program Files\UGS\NX 4.0\nxship\shipgsd
    NXSHIP_CONFIG_DIR                C:\Program Files\UGS\NX 4.0\nxship\data
    JK_KIT                           C:\Program Files\UGS\NX 4.0\nxhuman\jack_toolkit
    JK_KIT_DEV                       C:\Program Files\UGS\NX 4.0\nxhuman\jack_toolkit
    JK_KIT_PLATFORM                  nt4
    PYTHONPATH                       C:\Program Files\UGS\NX 4.0\nxhuman\jack_toolkit\lib\python2.11\;C:\Program Files\UGS\NX 4.0\nxhuman\jack_toolkit\library\script\;C:\Program Files\UGS\NX 4.0\nxhuman\jack_toolkit\lib
    UGII_BACKGROUND_URL              C:\Program Files\UGS\NX 4.0\UGTIPS\russian\background.html
    OT_PUB_APPLICATION_DIR           C:\Program Files\UGS\NX 4.0\pvtrans\ot_pub
    UGII_JAVA_HOME                   C:\Program Files\UGS\NX 4.0\nxjre
    UGII_JVM_LIBRARY_DIR             C:\Program Files\UGS\NX 4.0\nxjre\bin\server
    UGII_JVM_OPTIONS
    UGII_CLASSPATH
    PVTRANSUI_DIR                    C:\Program Files\UGS\NX 4.0\pvtrans
NX_VERSION=4.0.0.25
Versions of DLLs are:
    C:\Program Files\UGS\NX 4.0\ugii\ugraf.exe       4.0.0.25         400000 59000 9ea98be4-4bfd4662-86266fb9-cfcb51f5-1=ugraf___1133839034 05-Dec-2005 16:17
    C:\WINDOWS\system32\ntdll.dll                    5.1.2600.5512    7c900000 b0000 17510032-425960ca-26b30f8c-ed005058-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\kernel32.dll                 5.1.2600.5512    7c800000 f8000 34560e80-4175f5c5-8e8408b2-bdc563f8-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\WININET.dll                  8.00.6001.18702  63000000 e6000 d41d79ff-4e44b2f0-6e1e73b1-88e6449a-2 08-Mar-2009 0:34
    C:\WINDOWS\system32\msvcrt.dll                   7.0.2600.5512    77c00000 58000 7bcf30d8-4f1bc91b-554efa85-11506289-1 09-Jun-2008 12:0
    C:\WINDOWS\system32\SHLWAPI.dll                  6.0.2900         77f60000 76000 8519e340-47883447-7ffecf84-e0ba911a-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\ADVAPI32.dll                 5.1.2600.5512    77dc0000 ac000 5efb9bf4-40242cc6-2e8064ab-64947346-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\RPCRT4.dll                   5.1.2600.5512    77e70000 92000 ccd4fe9b-48b6704e-312fa1b8-6faa12e1-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\Secur32.dll                  5.1.2600.5512    77fe0000 11000 e8d37874-4a460b8e-cdaf9cb1-7ddf6d2d-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\GDI32.dll                    5.1.2600.5512    77f10000 49000 740f60a9-417e9f2a-4087c396-8d589409-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\USER32.dll                   5.1.2600.5512    7e360000 91000 d18a41b7-458c4e7f-4718acaa-2bfd8e2-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\Normaliz.dll                 6.0.5441.0       3e0000 9000 d0658e32-4ddc2b2d-c9b97fa5-ad6c5c71-1 07-Jan-2009 14:20
    C:\WINDOWS\system32\urlmon.dll                   8.00.6001.18702  1a400000 132000 2ffbb995-48cc5571-e0761e80-15f6439d-2 08-Mar-2009 0:34
    C:\WINDOWS\system32\ole32.dll                    5.1.2600.5512    774d0000 13d000 ed517599-4cf1d2c1-18860092-149c0533-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\OLEAUT32.dll                 5.1.2600.5512    77110000 8b000 f2a20900-4efc9b69-e96c1aad-c1eb92d9-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\iertutil.dll                 8.00.6001.18702  5dca0000 1e8000 86647437-4442f1fb-cd3b58b2-deaec61-2 08-Mar-2009 0:32
    C:\Program Files\UGS\NX 4.0\ugii\ugthemes.dll    4.0.0.25         20000000 28000 b3e0ab92-46799302-8301f8b6-14fd3c6c-1=ugthemes___1133838966 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\MFC71U.DLL      7.10.3077.0      7c250000 102000 18a321d3-42f149e3-a14e1e95-a0df5861-2 27-Oct-2005 8:43
    C:\Program Files\UGS\NX 4.0\ugii\MSVCR71.dll     7.10.3052.4      4b0000 56000 630c7917-42c05c19-4ebcc999-9c619d0-2 27-Oct-2005 8:43
    C:\WINDOWS\system32\COMCTL32.dll                 5.82.2900        5d5b0000 9a000 3053768f-4ab464ff-e49545b7-48b8e2e5-2 09-Jun-2008 12:0
    C:\Program Files\UGS\NX 4.0\ugii\ugtbxm.dll      4.0.0.25         20030000 58000 a5e5e9e1-40877145-1898e49a-907a99bc-1=ugtbxm___1133838975 05-Dec-2005 16:17
    C:\WINDOWS\system32\IMM32.dll                    5.1.2600.5512    76360000 1d000 f7a5b5db-41531332-34af7ab5-51ea770c-2 09-Jun-2008 12:0
    C:\Program Files\UGS\NX 4.0\ugii\ugmfcext.dll    4.0.0.25         20090000 5c000 b23a0423-4da87f9a-23d1cb8a-f391face-1=ugmfcext___1133838980 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\MSVCP71.dll     7.10.3077.0      7c3a0000 7b000 27e1f58f-4d023f1a-b26a2ca4-3c8c5a66-2 27-Oct-2005 8:43
    C:\Program Files\UGS\NX 4.0\ugii\ugshext.DLL     4.0.0.25         200f0000 13000 e885ab5e-4896bcc6-84c64485-86cacfc7-1=ugshext___1133838990 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libuginit.dll   4.0.0.25         20110000 1a000 7086aaa-4cd4a174-3896c8a8-5cd55c7b-1=libuginit___1133838447 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libann.dll      4.0.0.25         210c0000 30a000 c1727b98-463bb799-e5ecc6a6-f53efe23-1=libann___1130817846 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libcamsutil2.dll 4.0.0.25         228a0000 6b000 5f7c6772-433182d9-fbe85c8c-3878fe9b-1=libcamsutil2___1133838443 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libcams.dll     4.0.0.25         21be0000 93b000 e5cd40b8-4a5723e1-677ad88-f56850b7-1=libcams___1133838495 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libassy.dll     4.0.0.25         21490000 a1000 1d675102-4016c224-f4da3782-853917b3-1=libassy___1130817882 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libassybox.dll  4.0.0.25         21540000 65000 c0ecc793-4599e822-813cabbd-75be4a37-1=libassybox___1130817961 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libcmod.dll     4.0.0.25         22910000 1e8000 71d4ba34-40d1ccfa-15fbb9ac-f94e52bb-1=libcmod___1131584501 09-Nov-2005 14:5
    C:\Program Files\UGS\NX 4.0\ugii\libautomotive.dll 4.0.0.25         215b0000 627000 69f25ea5-47c03ec5-fc96e1af-a27eec2d-1=libautomotive___1130817473 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libcustdef.dll  4.0.0.25         20c00000 f6000 1ad8c50c-4896f98e-39929b8a-8f2e2f1c-1=libcustdef___1130817980 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libsyss.dll     4.0.0.25         20330000 234000 108c9e7f-470f9513-f8419e8a-3e61ad44-1=libsyss___1133838730 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libugmath.dll   4.0.0.25         201f0000 66000 51c1e3a4-4d26a326-f68ba9ae-1fdf08df-1=libugmath___1130817707 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libpman.dll     4.0.0.25         25d30000 25000 ecab980d-46bbdbbd-35a6cfae-890769e7-1=libpman___1130817974 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libplotq.dll    4.0.0.25         26f20000 12000 2c4a675b-4fa1b97d-1a4d2d93-48056f62-1=libplotq___1130817731 31-Oct-2005 17:17
    C:\WINDOWS\system32\WS2_32.dll                   5.1.2600.5512    71a90000 17000 a7605f86-432995a3-84db8db3-ca04a021-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\WS2HELP.dll                  5.1.2600.5512    71a80000 8000 6049cf58-4e2a77c5-c1ab12b5-99e7b2b4-2 09-Jun-2008 12:0
    C:\Program Files\UGS\NX 4.0\ugii\libdisp.dll     4.0.0.25         22b00000 22e000 3f0a7b76-4dc45e36-fbbf20b3-3b998e4d-1=libdisp___1133838309 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libasmo.dll     4.0.0.25         213d0000 bb000 220ad315-45a1afee-cad681ad-48422764-1=libasmo___1130817683 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libassypos.dll  4.0.0.25         26e60000 3f000 ab5e5a50-42fb9730-878d5ba5-b6bec379-1=libassypos___1130817546 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libdman.dll     4.0.0.25         22d30000 47000 6e99761c-4be7f6d3-46b7efb6-9d4084aa-1=libdman___1130818094 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libjam.dll      4.0.0.25         25ba0000 66000 88c38b08-404d1d5d-e0744c87-f1f85c29-1=libjam___1130817450 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libuglm.dll     4.0.0.25         258e0000 f0000 caffcf50-43babaad-b5c02bad-a077b35d-1=libuglm___1130817452 31-Oct-2005 17:17
    C:\WINDOWS\system32\comdlg32.dll                 6.00.2900.5512   76380000 49000 26a6ff7-4e6170fd-e9bbad86-9ca9ff6d-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\SHELL32.dll                  6.0.2900         7c9c0000 81b000 69b3829b-4926b688-f07bb9a5-6b2c814e-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\NETAPI32.dll                 5.1.2600.5512    5bd50000 55000 fb9eef3b-49ba11c9-78d3fb95-b0070a26-2 09-Jun-2008 12:0
    C:\Program Files\UGS\NX 4.0\ugii\libugutils.dll  4.0.0.25         25b10000 88000 2c8e1e48-41729d3f-625f58c-14e4f621-1=libugutils___1130817201 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libdraw.dll     4.0.0.25         22d80000 141000 7d15f053-489ac994-d76e6cb4-a02cdd12-1=libdraw___1133838663 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libevaluator.dll 4.0.0.25         22ed0000 1ef000 20e26c35-4d1d68dd-e83b4482-fc4de8f0-1=libevaluator___1133838603 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libgeom.dll     4.0.0.25         23830000 1e9000 694a7439-4a944063-66c06da0-2f6cb595-1=libgeom___1131584369 09-Nov-2005 14:5
    C:\Program Files\UGS\NX 4.0\ugii\libgdt.dll      4.0.0.25         23630000 1f7000 9332f154-4a340fe9-ee4d5a8d-1e53da9d-1=libgdt___1130817316 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libgeomutil.dll 4.0.0.25         23a20000 52000 42c918f-4ab04bad-f0e6c58b-32ca2b1f-1=libgeomutil___1130817695 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libfacet.dll    4.0.0.25         230c0000 229000 1502bf55-40e27774-972bd182-566be81-1=libfacet___1133838927 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libocc.dll      4.0.0.25         24030000 1a8000 925a712d-43ba0152-a7561485-eefb4414-1=libocc___1133838782 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libinterop.dll  4.0.0.25         26ea0000 1a000 9f5d439-4bc28784-543bda8b-529c9b88-1=libinterop___1130817164 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libklo.dll      4.0.0.25         23bb0000 10a000 b4fbeda7-424cab18-db555581-1851ddec-1=libklo___1131584261 09-Nov-2005 14:5
    C:\Program Files\UGS\NX 4.0\ugii\libfemg.dll     4.0.0.25         23340000 2eb000 9f46b537-4b4696c3-161afaa2-cda88b6d-1=libfemg___1130817080 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libugmi.dll     4.0.0.25         25d60000 15000 f45052a4-47374e81-9531b83-124050d7-1=libugmi___1130817658 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libpart.dll     4.0.0.25         241e0000 39d000 d1aa22dd-42b974c7-1c817ab-ec3e23f1-1=libpart___1133838587 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libfemgom.dll   4.0.0.25         26610000 37c000 c395b360-495bafeb-5e20b39a-c9048c8f-1=libfemgom___1130818106 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libcaetopodm.dll 4.0.0.25         271d0000 99000 79b3a608-47b7d577-908158a3-e3b7a9d5-1=libcaetopodm___1130817834 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libpartutils.dll 4.0.0.25         20d10000 248000 22915384-4fa582a1-c51942a2-165b0b5b-1=libpartutils___1133838415 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libsmd.dll      4.0.0.25         253e0000 3eb000 bcdd97b4-4c484de4-eafdc09b-e53ea992-1=libsmd___1130817890 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libmodl.dll     4.0.0.25         23d80000 25a000 428191bf-46f45f7f-a484cca2-e511af13-1=libmodl___1133838914 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libcamsproc1.dll 4.0.0.25         26430000 1a9000 e3777105-42083eb8-f0c5f1a4-8f1fd83b-1=libcamsproc1___1133838471 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libcamsproc2.dll 4.0.0.25         226f0000 16000 250d9b75-4e3ab1ee-d038618e-4e6bf7fb-1=libcamsproc2___1133838441 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libcamsmom.dll  4.0.0.25         225b0000 13b000 df640c3b-4c9ec309-17c964a2-9945e2dd-1=libcamsmom___1133838411 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libpartmodl.dll 4.0.0.25         24800000 566000 ef715fa1-4e82f684-1245b282-24c1eb1a-1=libpartmodl___1131584217 09-Nov-2005 14:5
    C:\Program Files\UGS\NX 4.0\ugii\libcsfadp.dll   4.0.0.25         26ed0000 29000 9034727f-44d90fd0-c1cba48d-b0785b5d-1=libcsfadp___1130817285 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libcsf.dll      4.0.0.25         27460000 ff000 78d8cc1-4f006d0b-455498aa-cd9ba4bf-1=libcsf___1130817801 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libpkp.dll      4.0.0.25         26f00000 11000 b47b80ea-48dfe360-db9d6fad-a6339bab-1=libpkp___1130817290 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libmodlgeom.dll 4.0.0.25         26170000 2b7000 4b0fc0e5-4c8ec1cd-4d34aab8-84fda2a2-1=libmodlgeom___1133838453 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libcamsutil1.dll 4.0.0.25         227d0000 c9000 e18e4da9-4de09da8-174a46b6-101020d2-1=libcamsutil1___1133838908 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libpartdisp.dll 4.0.0.25         24780000 7b000 4cf218f2-4378ad5e-45a7298-91eddde9-1=libpartdisp___1133838719 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libpartconv.dll 4.0.0.25         24580000 1fb000 91b869b7-451394e4-f48a4bab-33315ced-1=libpartconv___1133838356 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libcamsobj.dll  4.0.0.25         26e40000 d000 6ff1e6c8-41b509e2-1365bf83-35ae1ad2-1=libcamsobj___1133838907 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libcamsftr.dll  4.0.0.25         22520000 84000 55ae0955-49e2fba1-7f1eb398-9e6001e5-1=libcamsftr___1133838893 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libsmm.dll      4.0.0.25         26e50000 10000 fa8f7824-4c4c8fa7-12644cb2-df96f19a-1=libsmm___1130817925 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libugmr.dll     4.0.0.25         259d0000 131000 9b530d4d-4e9a5113-99f5ebac-c4ac4612-1=libugmr___1133838332 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libpdi.dll      4.0.0.25         27030000 8b000 bdc7c7cc-44a51da2-e56fcdbe-c8fb35fe-1=libpdi___1130817719 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libtable.dll    4.0.0.25         25860000 56000 d7e27a2c-436f404a-f1c958b8-925b83e9-1=libtable___1130818096 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libpartnav.dll  4.0.0.25         26ec0000 d000 d0694107-47d984e1-ace320b3-2be26f-1=libpartnav___1130817791 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libweld.dll     4.0.0.25         27400000 27000 208401c6-4c7c20d1-704dc29c-8f1b2a01-1=libweld___1130817998 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libcamsscop.dll 4.0.0.25         227a0000 30000 a2b42fc2-4c83b319-3a6d319b-d37e6b31-1=libcamsscop___1133838778 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libpatch.dll    4.0.0.25         24d70000 6000 d4536442-46492a2a-a93929b6-d1630bff-1=libpatch___1130817676 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libphymat.dll   4.0.0.25         265e0000 24000 3a8d626f-4b65a313-de26a792-a5ac20e8-1=libphymat___1130818143 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libumdm.dll     4.0.0.25         26f40000 ee000 ad18d927-4dc304b3-c3f04ca2-e0d02440-1=libumdm___1133838617 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libftkutil.dll  4.0.0.25         269c0000 2a000 b85f909b-44d07a68-401fa099-e033a5d9-1=libftkutil___1130817004 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libadflib.dll   4.0.0.25         27620000 1a000 dd80ad66-4f7b3206-5a9303a5-7b1115db-1=libadflib___1130817445 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libfnutil.dll   4.0.0.25         27670000 9000 86f1c538-42cbca50-8d73948c-5f5c9afc-1=libfnutil___1130817621 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libftkfor.dll   4.0.0.25         27680000 23000 9f56591d-4e9742b0-1e04029a-43c47c4e-1=libftkfor___1130817210 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libftkfac.dll   4.0.0.25         276b0000 9000 7717e3b4-42c84032-9a17e093-50a97609-1=libftkfac___1130817933 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libxyplot.dll   4.0.0.25         27640000 2c000 4f16790a-4abba9de-713a7a7-ecd6ee5b-1=libxyplot___1130817448 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libcaeutils.dll 4.0.0.25         27430000 30000 11b96312-41504fc7-ff237b5-a8fadfee-1=libcaeutils___1130817229 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\librout.dll     4.0.0.25         24d80000 4c3000 fd84db79-4ed9a240-6358f3b1-1df9c325-1=librout___1131584571 09-Nov-2005 14:5
    C:\Program Files\UGS\NX 4.0\ugii\libsket.dll     4.0.0.25         25290000 144000 f68241fc-4680d0b4-c5db2a1-2ff7c9db-1=libsket___1131584483 09-Nov-2005 14:5
    C:\Program Files\UGS\NX 4.0\ugii\libsmsputil.dll 4.0.0.25         25840000 19000 97c91354-437797c6-e866aeb2-d67ba96d-1=libsmsputil___1130884871 01-Nov-2005 11:43
    C:\Program Files\UGS\NX 4.0\ugii\libsmsp.dll     4.0.0.25         257d0000 6b000 c1330cb3-46238714-6ae07faa-ebcc05d9-1=libsmsp___1130817070 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libcamssim.dll  4.0.0.25         22710000 8e000 54f810ad-4965d2d4-8a7f86b5-17d1d5b2-1=libcamssim___1133838689 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libsims.dll     4.0.0.25         25250000 38000 73e90acd-4029adc0-e5223e80-217a2a74-1=libsims___1130817456 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libtline.dll    4.0.0.25         258c0000 1f000 7f8f131b-49052ffc-3d004f95-a6b07ad2-1=libtline___1130817099 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libcompos.dll   4.0.0.25         25e70000 1b000 e7560771-4bd1cf60-72dc2ab-8320d6b5-1=libcompos___1130817983 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libgenpos.dll   4.0.0.25         25e40000 23000 a934e5d-413ee33d-a427849f-e08c8e9d-1=libgenpos___1130817499 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libnxpos.dll    4.0.0.25         26990000 27000 a583fa11-486710ae-deef4eb9-57b8e361-1=libnxpos___1130818088 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libhm.dll       4.0.0.25         25d80000 5a000 19fe92d0-4d1928cd-4b8ff2b7-360cb8d2-1=libhm___1130817052 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libjc.dll       0                10000000 210000 0-0-0-0-0 27-Oct-2005 8:41
    C:\Program Files\UGS\NX 4.0\ugii\python21.dll    2.1.1            1e100000 af000 0-0-0-0-0 27-Oct-2005 8:41
    C:\Program Files\UGS\NX 4.0\ugii\libjcplmxml.dll 0                3f0000 7000 0-0-0-0-0 27-Oct-2005 8:41
    C:\Program Files\UGS\NX 4.0\ugii\plmxml51.dll    5.1.0.304        510000 303000 0-0-0-0-0 27-Oct-2005 8:44
    C:\Program Files\UGS\NX 4.0\ugii\pcl51.dll       5.1.0.250        820000 2c000 0-0-0-0-0 27-Oct-2005 8:44
    C:\WINDOWS\system32\WSOCK32.dll                  5.1.2600.5512    71ab0000 a000 2b38fe8f-4dac8414-7fda4b8-fc495ec0-2 09-Jun-2008 12:0
    C:\Program Files\UGS\NX 4.0\ugii\xpk51.dll       5.1.0.182        850000 a000 0-0-0-0-0 27-Oct-2005 8:44
    C:\Program Files\UGS\NX 4.0\ugii\MSVCP60.dll     6.00.8972.0      780c0000 61000 0-0-0-0-0 27-Oct-2005 8:43
    C:\Program Files\UGS\NX 4.0\ugii\libjsPPCore.dll 0                860000 14000 0-0-0-0-0 27-Oct-2005 8:41
    C:\Program Files\UGS\NX 4.0\ugii\libpgs.dll      4.0.0.25         275b0000 69000 746ed9d9-451a8c41-bc0931bb-bbce333e-1=libpgs___1130817234 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libfeatutils.dll 4.0.0.25         232f0000 42000 cbd3954a-4bddd1c1-84cb889a-d3593d30-1=libfeatutils___1130816926 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libsmdpk.dll    4.0.0.25         27560000 4a000 ac95b51d-44b115e4-24f13da3-4a929f69-1=libsmdpk___1130817687 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libcaepost.dll  4.0.0.25         27270000 bb000 14f28cbb-4615ab51-741ca3b5-4c28b87d-1=libcaepost___1130817529 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libfusion.dll   4.0.0.25         270c0000 84000 d1d3a8c0-4188a3b9-739297ae-6915adba-1=libfusion___1130818221 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libcaetopo.dll  4.0.0.25         27150000 76000 6cf15919-4b48dd1e-efa7b792-dab318f-1=libcaetopo___1130817251 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\liblwks.dll     4.0.0.25         23cc0000 b9000 f098ceaa-49d210fe-60ced082-1caded45-1=liblwks___1130817277 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libimage.dll    4.0.0.25         23b30000 7d000 b741c192-451adfc1-25a2448b-3a4aff91-1=libimage___1130817777 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libsfmesh.dll   4.0.0.25         27330000 c7000 14561c2a-40a63721-5f0ccf84-22db3ca5-1=libsfmesh___1130818225 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libmswp.dll     4.0.0.25         23fe0000 50000 88f17527-4a86a5dc-967ef9b3-5ddf5f2f-1=libmswp___1131584194 09-Nov-2005 14:5
    C:\Program Files\UGS\NX 4.0\ugii\libgrip.dll     4.0.0.25         23a80000 b0000 20c1bbdd-4d2d0d7b-c34b89ac-687c789c-1=libgrip___1133838571 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libugdebug.dll  4.0.0.25         20d00000 10000 8930f47e-447e7f69-d679d38b-6913f0b4-1=libugdebug___1130816936 31-Oct-2005 17:17
    C:\WINDOWS\system32\VERSION.dll                  5.1.2600.5512    77bf0000 8000 ea3d1bd3-475cfe65-d8c84984-962207b0-2 09-Jun-2008 12:0
    C:\Program Files\UGS\NX 4.0\ugii\libsbsm.dll     4.0.0.25         25c10000 114000 7e31660-429d530c-1c6f45a0-5706ae7f-1=libsbsm___1131584464 09-Nov-2005 14:5
    C:\Program Files\UGS\NX 4.0\ugii\libvsweep.dll   4.0.0.25         25de0000 52000 e355ba77-4c428e3c-f417fca1-4527220c-1=libvsweep___1133838645 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libpmi.dll      4.0.0.25         25e90000 167000 5a491931-4fd4da49-adebff9a-a97de018-1=libpmi___1133838744 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libkfbindings.dll 4.0.0.25         26000000 b3000 ead18fbb-4a0f4c26-153b7eb4-8e982832-1=libkfbindings___1130818178 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libjafeatures.dll 4.0.0.25         276c0000 3c000 3f87e8be-4fdcb776-33e212b7-fb8dfa25-1=libjafeatures___1130817690 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libblend.dll    4.0.0.25         27700000 35000 7f0dfa83-4fc91887-2ec7038f-67e7d9a7-1=libblend___1130817866 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libship.dll     4.0.0.25         260c0000 6000 8506c4f5-4986409a-7c198aa2-c034a6b1-1=libship___1130818134 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libaerosm.dll   4.0.0.25         260d0000 96000 788f55f-40bbe91e-d10f30be-1e8c5cc7-1=libaerosm___1131584457 09-Nov-2005 14:5
    C:\Program Files\UGS\NX 4.0\ugii\libuginitint.dll 4.0.0.25         20130000 ba000 7e62ddcd-46ef25a2-eb1d18a9-7eb53ee4-1=libuginitint___1133838695 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libannint.dll   4.0.0.25         27740000 15c000 8d7a39c8-4cacdce4-3d0fc49c-1adb36e6-1=libannint___1133838755 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libannutilsint.dll 4.0.0.25         278a0000 68000 d1406c15-4b925e0a-af660aac-caec069f-1=libannutilsint___1130817564 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libgeomint.dll  4.0.0.25         284f0000 255000 f3cf95a6-4caa84cc-c73aada8-a5fca996-1=libgeomint___1133838850 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libassyutilsint.dll 4.0.0.25         27b80000 46000 27ef7224-405b1dc7-7270199-b6f5b0ba-1=libassyutilsint___1130817560 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libassyint.dll  4.0.0.25         27910000 26d000 f39135ad-4ca014cd-bcfbc6a8-3b9e9ff7-1=libassyint___1133838480 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libcamsint.dll  4.0.0.25         27bd0000 138000 4ec4ccdf-4212b7e8-3e94a997-1895d87a-1=libcamsint___1133838337 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libcamssimint.dll 4.0.0.25         27d10000 57000 436a8d3d-48b6f72b-375def90-84d968ec-1=libcamssimint___1133838739 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libcamsutilint.dll 4.0.0.25         27d70000 293000 90696618-4b2bea7a-469028aa-890a2bef-1=libcamsutilint___1133838671 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libgraphics_driver.dll 4.0.0.25         20260000 c6000 8229392e-420e390f-7c7059a3-1c075e79-1=libgraphics_driver___1130817458 31-Oct-2005 17:17
    C:\WINDOWS\system32\OPENGL32.dll                 5.1.2600.5512    5f220000 cc000 6786566-4b11d8b1-2b2a22a8-3bc05597-1 09-Jun-2008 12:0
    C:\WINDOWS\system32\GLU32.dll                    5.1.2600.5512    5ff90000 21000 9e94e4a4-445ebddc-35707db2-2ff06d84-1 09-Jun-2008 12:0
    C:\WINDOWS\system32\DDRAW.dll                    5.03.2600.5512   73720000 4b000 df483a83-447f3685-30d9969f-343c3912-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\DCIMAN32.dll                 5.1.2600.5512    73b80000 6000 5b52df1b-4a7b8235-41b17990-a4d59774-2 09-Jun-2008 12:0
    C:\Program Files\UGS\NX 4.0\ugii\cg.dll          1,4,0,3          880000 1ab000 0-0-0-0-0 27-Oct-2005 8:43
    C:\Program Files\UGS\NX 4.0\ugii\cgGL.dll        1,4,0,3          a30000 41000 0-0-0-0-0 27-Oct-2005 8:43
    C:\Program Files\UGS\NX 4.0\ugii\libugui.dll     4.0.0.25         20570000 441000 3109def1-461696a3-e277c2a0-933828ac-1=libugui___1133838836 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\libugutilsint.dll 4.0.0.25         a80000 236000 419ffc7a-40a9ac3c-245ece8b-e88f471d-1=libugutilsint___1134061637 08-Dec-2005 6:7
    C:\Program Files\UGS\NX 4.0\ugii\liblwksint.dll  4.0.0.25         28a00000 17f000 5cb16a18-4d63d382-e22cecae-9176e82-1=liblwksint___1130817046 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libmold.dll     4.0.0.25         29d90000 86000 589dd90f-45c720bb-45590ca0-14610c84-1=libmold___1130817421 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libkfint.dll    4.0.0.25         289a0000 5a000 6132e73a-46a52ce3-e794898-aeb89a4c-1=libkfint___1130817585 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libgwyint.dll   4.0.0.25         28800000 d6000 577a001e-47efeb21-29354b4-4af3c23d-1=libgwyint___1133838349 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libsketint.dll  4.0.0.25         29490000 dc000 93b8725f-48cd633f-204d0eaf-d6ff6eea-1=libsketint___1133838326 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\liblathint.dll  4.0.0.25         29b30000 29000 d64fd55-48323d95-ddf664b7-b06386af-1=liblathint___1133838905 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libmillint.dll  4.0.0.25         29b60000 183000 baadd022-4bfa2654-93f3c791-e8f8bc4d-1=libmillint___1133838649 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libturnint.dll  4.0.0.25         29cf0000 93000 c1704989-45abefb1-4e296382-403a3044-1=libturnint___1133838860 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libdraftingint.dll 4.0.0.25         28010000 27000 a2a45ca2-486f8bc2-52f201ab-ade6a910-1=libdraftingint___1130817160 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libdrawint.dll  4.0.0.25         28040000 df000 53eb1b10-49cc8525-3b874593-8337b57d-1=libdrawint___1133838709 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libgdtint.dll   4.0.0.25         283f0000 f3000 76aeeda6-443c2a05-ef12f98e-7e0ad96a-1=libgdtint___1130817659 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libsmspint.dll  4.0.0.25         29780000 55000 e1bb0f07-49a7fa71-38dac191-c73384f8-1=libsmspint___1133838700 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libtableint.dll 4.0.0.25         299b0000 27000 9bde3ce6-4df42dc5-c5775e9c-b2b1ec6b-1=libtableint___1130817901 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libsprdint.dll  4.0.0.25         297e0000 ff000 8ab7b002-4bf1f80d-d2928d86-6358a744-1=libsprdint___1130817526 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libmodlint.dll  4.0.0.25         28b80000 628000 dde4a73b-4c723563-176f3e87-bd9e176-1=libmodlint___1133838626 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libpartnavint.dll 4.0.0.25         291d0000 9a000 7a271a59-4ccea5f6-9a56d886-9d8ad90d-1=libpartnavint___1133838899 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libvdac.dll     4.0.0.25         29e20000 5a000 9c41d973-4ac0bd07-a65e30a1-5d3df4b2-1=libvdac___1130817158 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libugmrint.dll  4.0.0.25         299e0000 72000 a19a5e49-4a90e914-3a625180-c7c381f-1=libugmrint___1133838715 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libwvint.dll    4.0.0.25         29b10000 14000 5738a18-40b882bb-6cb2968e-bff09560-1=libwvint___1130818086 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libfemgint.dll  4.0.0.25         28120000 2c3000 77353b65-43bc4332-355e89bb-842fdfe0-1=libfemgint___1133838792 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libftknavint.dll 4.0.0.25         29ab0000 3e000 b6b3183a-4bbbe10b-76088e8c-3186d9f2-1=libftknavint___1130818039 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libftkint.dll   4.0.0.25         29e80000 2f000 2581594d-43064fd9-5100ca9d-109884cd-1=libftkint___1133838693 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libxyplotint.dll 4.0.0.25         29af0000 1f000 842fde4a-4c48c5b1-71d145b0-2b380e2e-1=libxyplotint___1130817033 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libgripint.dll  4.0.0.25         28750000 ad000 bdc7b8df-4b884d5b-d567d39c-63292738-1=libgripint___1133838578 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libhelpint.dll  4.0.0.25         288e0000 b4000 33235d7a-4a20f35e-4ddb1b97-bbf3e41-1=libhelpint___1130817877 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libsmdint.dll   4.0.0.25         29570000 1d8000 9eb613dc-41fe92a2-526ca496-9993dcd4-1=libsmdint___1130817758 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libflat.dll     4.0.0.25         29eb0000 6b000 55d9e8c4-4f38fc57-d2471788-250b886-1=libflat___1130817698 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libmswpint.dll  4.0.0.25         291b0000 1e000 937bfe7f-4717705a-1c07b89f-47dc16af-1=libmswpint___1130817733 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libpmiint.dll   4.0.0.25         29270000 1e000 c7f2117f-4b8bad58-f2684890-9225b5b5-1=libpmiint___1130817602 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libpmanint.dll  4.0.0.25         29290000 27000 2f4fe6ae-4649258a-f425c4bf-b7d59efa-1=libpmanint___1130817219 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libroutint.dll  4.0.0.25         292c0000 1a2000 44b26624-4b8fe724-a5771b8f-784cf5f0-1=libroutint___1130817723 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libsbsmint.dll  4.0.0.25         29470000 11000 77524391-4f94a5dd-86842991-82065477-1=libsbsmint___1130818224 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libsmmint.dll   4.0.0.25         29750000 28000 957447e9-4e10eedc-a2c4a2a8-7bc8220d-1=libsmmint___1130818135 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libstylerint.dll 4.0.0.25         298e0000 c1000 82ed78e1-42166474-7ef828bd-b66907c2-1=libstylerint___1133838372 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libspsdint.dll  4.0.0.25         29a60000 f000 39093475-40a9f635-1af9b2a0-8ad1c433-1=libspsdint___1133838713 05-Dec-2005 16:18
    C:\Program Files\UGS\NX 4.0\ugii\libhm_int.dll   4.0.0.25         29a70000 30000 adee8f4f-4f630de0-e3402a94-b95e5a0b-1=libhm_int___1130817763 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libshipint.dll  4.0.0.25         29aa0000 f000 32d8e06e-43cd4672-a63cbfa7-cb5e7489-1=libshipint___1130817654 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\windowsui.dll   4.0.0.25         20f60000 159000 209fe929-4100c33e-58f947a0-923a1250-1=windowsui___1133839001 05-Dec-2005 16:17
    C:\Program Files\UGS\NX 4.0\ugii\ugwinutils.dll  4.0.0.25         29f20000 1b000 8eb30586-420ae540-923358bb-8a9d7adf-1=ugwinutils___1133838998 05-Dec-2005 16:18
    C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll 6.0.2900         773c0000 103000 50505797-416f1c40-1ded9fb3-57d0be39-1=MicrosoftWindowsCommon-Controls-6.0.2600.5512-comctl32 09-Jun-2008 12:0
    C:\WINDOWS\system32\MSCTF.dll                    5.1.2600.5512    746e0000 4c000 c52f0b4c-455600e9-229f99ae-6619008b-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\UxTheme.dll                  6.00.2900.5512   5b260000 38000 e99e1630-47678f09-b57ff0b1-46e2e5c3-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\msctfime.ime                 5.1.2600.5512    75310000 2e000 60228888-44533af4-23699397-641e093e-1 09-Jun-2008 12:0
    C:\WINDOWS\system32\CLBCATQ.DLL                  03.00.00.4414    76fc0000 7f000 8ae9c547-47643082-a69ef3aa-58878d9f-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\COMRes.dll                   03.00.00.4414    77040000 c7000 a02453a3-413feb42-2653f9bf-7d973e89-f 09-Jun-2008 12:0
    C:\WINDOWS\System32\mswsock.dll                  5.1.2600.5512    71a30000 40000 bc563e5-43e42f9e-a94d079e-7171417d-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\DNSAPI.dll                   5.1.2600.5512    76f10000 27000 2602de4d-48a89843-d46dc3a8-15e2023f-2 09-Jun-2008 12:0
    C:\WINDOWS\System32\winrnr.dll                   5.1.2600.5512    76fa0000 8000 9fe1a466-400f9b69-431a82ac-c59caa67-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\WLDAP32.dll                  5.1.2600.5512    76f50000 2d000 ac04bcf6-4fceff29-938d8bac-173aba7c-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\iphlpapi.dll                 5.1.2600.5512    76d50000 19000 9b09f073-4ca4003f-b380998f-8f4491c0-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\icmp.Dll                     5.1.2600.5512    74250000 4000 c69a7fc8-45343fca-d44e27a5-97908b33-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\rasadhlp.dll                 5.1.2600.5512    76fb0000 6000 cca669b1-47d05828-abd730b3-476a44db-2 09-Jun-2008 12:0
    C:\WINDOWS\system32\hnetcfg.dll                  5.1.2600.5512    698b0000 58000 87332c2b-42fcff6e-a18497b8-71c24ed2-1 09-Jun-2008 12:0
    C:\WINDOWS\System32\wshtcpip.dll                 5.1.2600.5512    71a70000 8000 de2e5260-406d3ffb-d8c85290-72ada184-2 09-Jun-2008 12:0
    C:\Program Files\UGS\NX 4.0\ugii\ugxml.dll       4.0.0.25         2660000 1d000 711a34ad-4bb4a408-a96419b6-c6de68e9-1=ugxml___1130817314 31-Oct-2005 16:55
    C:\Program Files\UGS\NX 4.0\ugii\xerces-c_1_6_0.dll 1,6,0            12000000 144000 0-0-0-0-0 27-Oct-2005 8:57
    C:\Program Files\UGS\NX 4.0\ugii\icuuc20.dll     2,0,2,0          4a800000 50000 0-0-0-0-0 27-Oct-2005 8:57
    C:\Program Files\UGS\NX 4.0\ugii\icudt20.dll     2,0,2,0          4ad00000 7d8000 0-0-0-0-0 27-Oct-2005 8:57
    C:\Program Files\UGS\NX 4.0\ugii\libptr.dll      4.0.0.25         26e10000 22000 8d72fcc7-44b7ee98-8a36f1b2-aa883231-1=libptr___1130817272 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\libcgm.dll      4.0.0.25         269f0000 3db000 c8f27d6f-4c031489-cec9199a-909d0085-1=libcgm___1130817977 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\PSKERNEL.dll    17.00.210        40000000 1761000 cc038faa-457ac6e8-6de716b5-63289415-1 27-Oct-2005 8:44
    C:\Program Files\UGS\NX 4.0\ugmanager\pdi_corba_client.dll 4.0.0.25         3520000 162000 64fe27e1-46618b8f-88afbd9d-7ce202d-1=pdi_corba_client___1130817011 31-Oct-2005 16:50
    C:\Program Files\UGS\NX 4.0\ugii\TAO.dll         1.3a_p1          3690000 15b000 197795b0-46b06e7f-d2f922ab-4b989f1b-1 27-Oct-2005 8:53
    C:\Program Files\UGS\NX 4.0\ugii\ACE.dll         5.3a_p1          37f0000 10f000 e4096732-4b3daf67-24730ba5-99e15e30-1 27-Oct-2005 8:53
    C:\Program Files\UGS\NX 4.0\ugii\libhidl.dll     4.0.0.25         26dd0000 40000 c44b4d12-4df79995-4d7d428c-b816d75f-1=libhidl___1130817401 31-Oct-2005 17:17
    C:\Program Files\UGS\NX 4.0\ugii\PSAPI.DLL       5.00.2134.1      690a0000 b000 0-0-0-0-0 27-Oct-2005 8:44
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\ugii\tl_schema.dll
Module signature = 3a50000 e000 f1aa76e3-4afe37ee-d2a26fbd-ce2be867-1=tl_schema___1130817286 version = 4.0.0.25
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\ugii\treelist.dll
Module signature = 3a60000 46000 baefccd1-4caf71d7-73c25f9d-5a161790-1=treelist___1133838984 version = 4.0.0.25
PAL::REG - PAL_TNL_VIEW_VKEY
PAL::REG - Cannot find standard palette with URL <c:\temp\q2675pse4.pax>
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\ugii\libuifw.dll
Module signature = 3b20000 4c000 5ac31b7f-430e979e-4792888b-dab18f1e-1=libuifw___1130817273 version = 4.0.0.25
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\ugii\libuicomp.dll
Module signature = 3b70000 7f000 54d18865-44063550-3ef201b9-b9ba4ff7-1=libuicomp___1130818151 version = 4.0.0.25
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\ugii\libuicomp_modl.dll
Module signature = 3bf0000 2c000 d21772a8-4dc642ec-d6be9586-711db85c-1=libuicomp_modl___1130817283 version = 4.0.0.25
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\ugii\libuicomp_mswp.dll
Module signature = 3c20000 16000 d691de2b-410902a4-b3ee5cb6-55320dab-1=libuicomp_mswp___1130818024 version = 4.0.0.25
 **************************** Default Registry Settings **************************
REGEDIT4
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_DRAFTING]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_GATEWAY]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_MANUFACTURING]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_MECHANISMS]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_MODELING]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_NOPART]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_ROUTE_ELEC]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_ROUTE_LGCL]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_ROUTE_MECH]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_SBSM]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_SMD_FABRICATION]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_SMD_MULTIPART_GRIDDING]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_SMD_NESTING]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_SMD_PUNCH_PRESS]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_SMD_SHEETMETAL_DESIGN]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_STUDIO]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_APP_STYLER]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_ASSY_SEQ_MOT]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\Default\Layout\Applications\UG_TOOLBOX_SKETCH]
"i"=dword:00000000
[HKEY_CURRENT_USER\Software\Unigraphics Solutions\Unigraphics NX\Default\Layout\Applications\UG_APP_SFEM]
"i"=dword:00000000
LAY_REG:: CANNOT_LOCATE_VALUE for <Dialog Bar>
NX loaded C:\Program Files\UGS\NX 4.0\ugii\menus\master.dtx file as INTERNAL data
NX loaded C:\Documents and Settings\q\Local Settings\Application Data\Unigraphics Solutions\NX4\user.mtx file as CUSTOM data
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\ugweld\startup\weld_uf_startup.dll
Module signature = 3d50000 6000 20c347ed-40c7a527-533737b1-643241d0-1=weld_uf_startup___1130818093 version = 4.0.0.25
UGOPEN_LOADED_LIBRARY Successfully loaded library: C:\Program Files\UGS\NX 4.0\ugweld\startup\weld_uf_startup.dll
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\ugprocess_aid\startup\mpaw_uf_startup.dll
Module signature = 4250000 6000 801919c8-478d30c3-ca8e929e-341d10eb-1=mpaw_uf_startup___1130816937 version = 4.0.0.25
UGOPEN_LOADED_LIBRARY Successfully loaded library: C:\Program Files\UGS\NX 4.0\ugprocess_aid\startup\mpaw_uf_startup.dll
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\ugcheckmate\startup\mqc_uf_startup.dll
Module signature = 4290000 6000 2f727a5b-4c89a1be-8bf7e6ba-d9457180-1=mqc_uf_startup___1130817276 version = 4.0.0.25
Knowledge Fusion Version is 19.2001.001-ugs
KF search path used is from the registry, not from UGII_KF_USER_CLASS_DIR
UGOPEN_LOADED_LIBRARY Successfully loaded library: C:\Program Files\UGS\NX 4.0\ugcheckmate\startup\mqc_uf_startup.dll
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\ugautomotive\startup\autodes_uf_startup.dll
Module signature = 47c0000 6000 eabade21-49a0aca9-7f092ca4-8229d5cf-1=autodes_uf_startup___1130817464 version = 4.0.0.25
UGOPEN_LOADED_LIBRARY Successfully loaded library: C:\Program Files\UGS\NX 4.0\ugautomotive\startup\autodes_uf_startup.dll
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\pvtrans\ot_pub\startup\libotpub.dll
Module signature = 47d0000 b000 713f6276-472f230a-25fa648e-7d7dd80-1=libotpub___1130817199 version = 4.0.0.25
UGOPEN_LOADED_LIBRARY Successfully loaded library: C:\Program Files\UGS\NX 4.0\pvtrans\ot_pub\startup\libotpub.dll
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\nxship\startup\ship_uf_startup.dll
Module signature = 4820000 6000 f37169a9-44edc4dc-bfd48591-eff22571-1=ship_uf_startup___1130816906 version = 4.0.0.25
UGOPEN_LOADED_LIBRARY Successfully loaded library: C:\Program Files\UGS\NX 4.0\nxship\startup\ship_uf_startup.dll
MB_LOADED_MENU_FILE Using UGII_MAIN_MENU_FILE setting, successfully loaded menu file: C:\Program Files\UGS\NX 4.0\ugii\menus\ug_main.men
MB_LOADED_MENU_FILE Using UGII_VIEW_POPUP_MENU_FILE setting, successfully loaded menu file: C:\Program Files\UGS\NX 4.0\ugii\menus\ug_view_popup.men
MB_LOADED_MENU_FILE Using UGII_APPL_POPUP_MENU_FILE setting, successfully loaded menu file: C:\Program Files\UGS\NX 4.0\ugii\menus\ug_application_popup.men
MB_LOADED_MENU_FILE Loaded startup menu file: C:\Program Files\UGS\NX 4.0\ugalliance\site\startup\uf_mold_mf.men
MB_LOADED_MENU_FILE Loaded startup menu file: C:\Program Files\UGS\NX 4.0\ugweld\startup\ug_weld.men
MB_LOADED_MENU_FILE Loaded startup menu file: C:\Program Files\UGS\NX 4.0\mach\auxiliary\batch\startup\ug_cam_add_batch.men
MB_LOADED_MENU_FILE Loaded startup menu file: C:\Program Files\UGS\NX 4.0\ugprocess_aid\startup\ug_datum.men
MB_LOADED_MENU_FILE Loaded startup menu file: C:\Program Files\UGS\NX 4.0\tolstackup\startup\minmax_tsv.men
MB_LOADED_MENU_FILE Loaded startup menu file: C:\Program Files\UGS\NX 4.0\ugautomotive\bodydes\startup\bodydes_app.men
MB_LOADED_MENU_FILE Loaded startup menu file: C:\Program Files\UGS\NX 4.0\ugautomotive\dieeng\startup\dieeng_app.men
MB_LOADED_MENU_FILE Loaded startup menu file: C:\Program Files\UGS\NX 4.0\ugautomotive\diedes\startup\diedes_app.men
MB_LOADED_MENU_FILE Loaded startup menu file: C:\Program Files\UGS\NX 4.0\ugautomotive\diedes\startup\presslinesim_app.men
MB_LOADED_MENU_FILE Loaded startup menu file: C:\Program Files\UGS\NX 4.0\ugimw\startup\iware_integ.men
MB_LOADED_MENU_FILE Loaded startup menu file: C:\Program Files\UGS\NX 4.0\ugautomotive\packaging\startup\ug_vd_app.men
MB_LOADED_MENU_FILE Loaded startup menu file: C:\Program Files\UGS\NX 4.0\pvtrans\ot_pub\startup\otpub.men
MB_LOADED_MENU_FILE Loaded startup menu file: C:\Program Files\UGS\NX 4.0\nxship\startup\ug_ship_app.men
        GL_MAX_TEXTURE_UNITS_ARB = 4
        GL_MAX_GENERAL_COMBINERS_NV = 8
OpenGL EXTENSIONS SUPPORTED:
    GL_ARB_multitexture         = 1
    GL_ARB_shadow               = 1
    GL_ARB_depth_texture        = 1
    GL_ARB_shadow_ambient       = 0
    GL_NV_register_combiners    = 1
    GL_EXT_blend_color          = 1
    GL_ARB_vertex_program       = 1
    GL_ARB_fragment_program     = 1
WGL_ARB_extensions_string       = 1
    WGL_ARB_pbuffer             = 1
    WGL_ARB_pixel_format        = 1
    WGL_ARB_render_texture      = 1
    WGL_NV_render_depth_texture = 1
CG_GL_VERTEX = 7001
CG_GL_FRAGMENT = 6151
Display adapter:  NVIDIA GeForce GT 240 6.14.12.5896
Graphics device:  GeForce GT 240/PCI/SSE2
Translucency method:  Alpha-blend translucency
Maximum texture size:  8192
Stereo viewing:  Unavailable
Full-scene antialiasing:  Unavailable
Texture cube map:  Available
Inter-object shadows:  Available
Disable Translucency is supported and enabled
Backface Culling is supported and disabled
Depth-Sorted Wireframe is supported and disabled
Line Antialiasing is supported and disabled
Edge Emphasis is supported and enabled
&MACRO WINDOW RESIZE 1.000000 6.754429 3.829355 -1.000000 -0.566940 1.000000 0.566940
&MACRO WINDOW RESIZE 1.000000 6.809793 3.884719 -1.000000 -0.570461 1.000000 0.570461
&MACRO FOCUS CHANGE IN 1
&MACRO MGW ACTION 1 6 2
INTEROP: Establishing server
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\ugii\interop_server.dll
Module signature = 6e40000 d000 54a71b6f-426c93db-27cf15aa-ba5e79aa-1=interop_server___1130817470 version = 4.0.0.25
INTEROP: Established server at port 1800
INTEROP: Establishing client-proxy for interoperating
UGINTEROP: Registering modified function
Playback is at level 5
Macros resize flag is OFF
Knowledge Fusion Navigator Column Headers NAME,On,200:VALUE,On,100:OBJECT_NAME,Off,100
UG/Manager: capability TC_is_Teamcenterized is disabled
UG/Manager: Could not retrieve ID DISP RULE value in registry named: Current ID Display Rule
&MACRO NX 4.0.0.25
&MACRO Macro Version 7.50
&MACRO Macro List Language and Codeset: russian 14
&MACRO Created by q on Wed Jun 25 10:57:47 2014
&MACRO Part Name Display Style: $FILENAME
&MACRO Selection Parameters 1 2 0.203002 1
&MACRO Display Parameters 1.000000 6.809793 3.884719 -1.000000 -0.570461 1.000000 0.570461
&MACRO *****************
Part Navigator Column Headings NAME,On,200FEATURE_TYPE,Off,200TIMESTAMP,Off,100LAYER,On,100STATE,Off,100OUT_OF_DATE,Off,100CREATED,Off,100MODIFIED,Off,100COMMENT,On,100REQUIREMENT_ID,Off,100VALUE,Off,100CREATEDBY,Off,100MODIFIEDBY,Off,100
Using PLMXML.
NX Manager: Assuming there are multisited foreign parts with existing - but not exported - UGMASTERS
Checking URL http://www.ugs.com/nx_user/index.html
Failed to restore previous assemblies preference for add component preview - defaulting to ON
DEFAULT_ROLE::LOAD - Default Role from C:\Program Files\UGS\NX 4.0\ugii\menus\roles\essentials.mtx file was loaded successfully
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Program Files\UGS\NX 4.0\ugii\menus\ug_nopart.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Program Files\UGS\NX 4.0\pvtrans\ot_pub\application\otpub_nopart.men
INTEROP: Starting message type 0
&MACRO FOCUS CHANGE OUT 1
UGINTEROP: Receiving interop request...
INTEROP:    Starting packet type 1
UGINTEROP: Bookmark stream
UGINTEROP: Receiving bookmark...
INTEROP:   Met end of packet
NX Manager Load Options Are :-
    Load Options      : With Revision Rules : Последняя по дате создания
                        Effective date : Not Set, Unit Nos. = Units not set
    Load Components   : Load all the component parts
    Failure Option    : Do not abort load on failure
    Load Fully        : Do not fully load the component parts
    Load Substitution : Do not allow substitutions on load
    Reference Sets    : Do not apply to all levels
    Load Wave Data    : Default load behaviour
    Part family members : Regenerate missing members automatically
UG/Manager: WAVE relations are Item Revision to Item
UNDO_UG AUTO_IMPORTANCE 'OFF'
Versioning rules :-
             part_name_format :-
             part_name_match :-
             part_name_substitution :-
             version_substitution :-
             version_type :- military
Closing/deleting initial_part
Loading "%UGMGR=V3.2 PH=LMCpSV2EhDiy0B PN=R6{1757} PRN=V1 " which was saved in NX V4.0
Found 9540 bitmaps in 0.03 seconds
UG/Manager: Unset user string in tag file '%UL=V1.0 PH=LMCpSV2EhDiy0B'
Using OCC partial loading: UGII_OCC_PARTIAL_LOADING is unset
  Read in all for part "%UGMGR=V3.2 PH=LMCpSV2EhDiy0B PN=R6{1757} PRN=V1 ", cpu    0.219, real    0.687
Partition info: RM:1 (0.1, 0.1) CM:1 (0.0, 0.0) EXP:1 (0.0, 0.0) PATT:1 (0.0, 0.0) OCC:1 (0.0, 0.0) PS:1 (0.0, 0.0) KF:1 (0.0, 0.0)
Loaded and updated part "%UGMGR=V3.2 PH=LMCpSV2EhDiy0B PN=R6{1757} PRN=V1 " cpu    0.234, real    0.734
NX Manager: Updating assembly of '%UGMGR=V3.2 PH=LMCpSV2EhDiy0B PN=R6{1757} PRN=V1 '.
Not creating NXManager plist on the fly
NX Manager: Updated assembly structure of '%UGMGR=V3.2 PH=LMCpSV2EhDiy0B PN=R6{1757} PRN=V1 ' in  cpu    0.000, real    0.000
*** EXCEPTION: Error code  940009 in line 2168 of O:\ugnx40\ip25\src\ugmr\no\ind\ugmgr_file_management.c at Wed Jun 25 10:58:00 2014 Московское время (зима)
+++ Unable to create export directory. Disk full or no write access.
[ 1] 7C812AEB                                                              (kernel32)
[ 2] 20357A3A                                                              (libsyss)
[ 3] 20355504                                                              (libsyss)
[ 4] 203566BB                                                              (libsyss)
[ 5] 2035685B                                                              (libsyss)
[ 6] 2035278C                                                              (libsyss)
[ 7] 20352DD1                                                              (libsyss)
[ 8] 25A25043                                                              (libugmr)
[ 9] 25A26990                                                              (libugmr)
[10] 25A0999F                                                              (libugmr)
[11] 203386DE                                                              (libsyss)
[12] 203386D3                                                              (libsyss)
[13] 203386D3                                                              (libsyss)
[14] 203386D3                                                              (libsyss)
[15] 203386D3                                                              (libsyss)
[16] 203386D3                                                              (libsyss)
[17] 20338CEC                                                              (libsyss)
[18] 241E8862                                                              (libpart)
[19] 241E88EF                                                              (libpart)
[20] 241E50A6                                                              (libpart)
[21] 214D4E73                                                              (libassy)
[22] 214D5ED1                                                              (libassy)
[23] 214D650F                                                              (libassy)
[24] 214DDCDF                                                              (libassy)
[25] 20E7B557                                                              (libpartutils)
[26] 20E7B68E                                                              (libpartutils)
[27] 26EA52ED                                                              (libinterop)
[28] 06E41584                                                              (interop_server)
[29] 7C27B191                                                              (MFC71U)
[30] 7C27B27D                                                              (MFC71U)
[31] 7C27B31C                                                              (MFC71U)
[32] 7C27B385                                                              (MFC71U)
[33] 7C27B3C3                                                              (MFC71U)
[34] 7E368734                                                              (USER32)
[35] 7E368816                                                              (USER32)
[36] 7E3689CD                                                              (USER32)
[37] 7E368A10                                                              (USER32)
[38] 7C283830                                                              (MFC71U)
[39] 20FBB604                                                              (windowsui)
[40] 20FBB715                                                              (windowsui)
[41] 20706BE1                                                              (libugui)
[42] 206EB262                                                              (libugui)
[43] 20706C16                                                              (libugui)
[44] 20135363                                                              (libuginitint)
[45] 00404718                                                              (ugraf)
[46] 00407B02                                                              (ugraf)
>>>> Error code  940009 caught in file "O:\ugnx40\ip25\src\ugmr\no\ind\ugmgr_file_management.c" at line number 4320
>>>> Error code  940009 caught in file "O:\ugnx40\ip25\src\part\no\ind\base_part.c" at line number 1275
>>>> Error code  940009 caught in file "O:\ugnx40\ip25\src\part\no\ind\base_part.c" at line number 1301
set root/work part failed "%UGMGR=V3.2 PH=LMCpSV2EhDiy0B PN=R6{1757} PRN=V1 ": CPU time:   0.499 secs, Real time:  1.344 secs
>>>> Error code  940009 caught in file "O:\ugnx40\ip25\src\assy\no\ind\bkm_interop_handler_definitions.c" at line number 88
>>>> Error code  940009 caught in file "O:\ugnx40\ip25\src\interop\no\ind\interop_manager_definitions.c" at line number 110
>>>> Error code  940009 caught in file "O:\ugnx40\ip25\src\interop_server\no\wnt\interop_wnt_server_thread_definitions.cxx" at line number 147
otd591-13 otd591-13:0.0 GeForce GT 240/PCI/SSE2 configuration:polyline_set=array_set,single,display_list,8:tri_set=array,single,display_list,8:tri_strip_set=array_set,single,display_list,8:
Displayed in: CPU time:   0.109 secs, Real time:  0.156 secs
&MACRO WINDOW RESIZE 1.000000 10.131644 6.782111 -1.000000 -0.669399 1.000000 0.669399
UGINTEROP: Received bookmark
INTEROP: Met end of message
Graphics window is of zero dimension
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Program Files\UGS\NX 4.0\ugii\menus\ug_gateway.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Program Files\UGS\NX 4.0\ugii\menus\ug_modeling.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Program Files\UGS\NX 4.0\ugii\menus\ug_show_application_popup.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Program Files\UGS\NX 4.0\ugweld\application\add_ug_weld.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Program Files\UGS\NX 4.0\ugprocess_aid\application\add_ug_datum.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Program Files\UGS\NX 4.0\ugautomotive\bodydes\application\bodydes.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Program Files\UGS\NX 4.0\ugautomotive\dieeng\application\dieeng.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Program Files\UGS\NX 4.0\ugautomotive\diedes\application\diedes.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Program Files\UGS\NX 4.0\ugautomotive\diedes\application\presslinesim.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Program Files\UGS\NX 4.0\ugautomotive\packaging\application\ug_vd.men
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\ugii\libwizardint.dll
Module signature = 7080000 40000 d7a83204-40777d7a-cedd4e9d-bb4f35af-1=libwizardint___1130816933 version = 4.0.0.25
Successfully loaded dynamic module C:\Program Files\UGS\NX 4.0\ugii\wizstrint.dll
Module signature = 70c0000 3d000 fff7e811-4610cb80-a602c4a4-97c34f6d-1=wizstrint___1130817037 version = 4.0.0.25
&MACRO WINDOW RESIZE 1.000000 9.817913 6.468381 -1.000000 -0.658835 1.000000 0.658835
&MACRO SUB_SELECT 1
*** S:\2005SR1\portal\temp\tcserver.exed32b45e0.syslog
*** system log created by q on Wed Jun 25 10:33:57 2014 Московское время (зима)
Node Name    :- otd591-13
Machine type :- Intel x86 Level 6 Revision 0170a
OS           :- Windows NT 5.1 (Workstation) (Build 2600: Service Pack 3)
# Processors :- 2
Memory       :- 3069Mb
Total Swap   :- 4095Mb
Free  Swap   :- 2486Mb
Machine supports 3G address space
Running customer environment
POM V10.0.1.0  compiled on Aug 24 2009
Compiled:  -D__DB_ORACLE  -D__DB_MSSQL
Session is running in codeset 1251 14
Defaulted NLS_LANG based upon TEXT encoding.
  Oracle env: NLS_LANG=russian_cis.cl8mswin1251.
  Oracle env: NLS_SORT=BINARY.
**** Connected to 'tceng' as 'infodba'
DBMS VERSION:: Oracle Database 10g Enterprise Edition Release 10.2.0.1.0 - 64bi
DBMS VERSION:: PL/SQL Release 10.2.0.1.0 - Production
DBMS VERSION:: CORE	10.2.0.1.0	Production
DBMS VERSION:: TNS for 64-bit Windows: Version 10.2.0.1.0 - Production
DBMS VERSION:: NLSRTL Version 10.2.0.1.0 - Production
Database Installation Identifier: "INFORMATION MANAGER V10.0.3.8.3" info=00000001
  LOADING SCHEMA FILE: S:\utv\pom_schema_TEAMCENTER31_tceng
Cache:       name "SCHEMA" version "ByC5d5cNBvFBPB".
User:        name "infodba" date "2011/11/30 05:41:59".
Logical DB:  site 481640692 version "AEO1FFJDBvFBPB".
DB Server:   database "DBMS server version: 10" db id "tceng".
Hardware:    type "Intel x86/Windows NT" name "omsotd591".
Application: name "POM-ITK" version 1000.0.1.
TextServer::failed to open file 'rdv_text.xml'
TextServer:: searched in directories
          S:\2005SR1\lang\textserver\ru
TextServer::WARNING: bad file name, rdv_text.xml
TextServer::failed to open file 'tcx_property_names_locale.xml'
TextServer::WARNING: bad file name, tcx_property_names_locale.xml
	SCHEMA LOADED
TC environment variables:
    TCENG_HTDOCS=S:\2005SR1\web\htdocs
    TCFS_Service=tcfs_utv
    TCSERVER_ACTIVATION_MODE=NORMAL
    TCSERVER_CONFIG_DIR=C:\temp_tce\server_configs_NET
    TC_DB_CONNECT=infodba:daAS6wT2ujE@tceng
    TC_INSTALL_DIR=S:\2005SR1\install
    IMAN_BIN=S:\2005SR1\bin
    IMAN_CHARACTER_ENCODING_SET=Cp1251
    IMAN_DATA=S:\utv
    IMAN_DB_CONNECT=infodba:daAS6wT2ujE@tceng
    IMAN_DISABLE_FLASH=true
    IMAN_FS_Service=tcfs_utv
    IMAN_HELP_FILE=S:\2005SR1\web\htdocs\imanhelp\imanhelp.hlp
    IMAN_INCLUDE=S:\2005SR1\include
    IMAN_LIBRARY=S:\2005SR1\lib
    IMAN_LOCALIZATION_DIR=ru
    IMAN_LOG=S:\utv\log_TEAMCENTER31_tceng
    IMAN_LSE_ROOT=S:\2005SR1\portal
    IMAN_MSG_ROOT=S:\2005SR1\lang\textserver
    IMAN_PRINTER=lpr.exe
    IMAN_TMP_DIR=S:\2005SR1\portal\temp
    IMAN_TRACEBACK=ON
    IMAN_UG_DEFAULT_PART=S:\utv\blank_english.prt
    IMAN_USER_TOOLS=S:\2005SR1\local\tools
    IMAN_XML_ENCODING=WINDOWS-1251
    IMAN_ROOT=S:\2005SR1
    POM_SCHEMA=S:\utv\pom_schema_TEAMCENTER31_tceng
    POM_TRANSMIT_DIR=S:\utv\pom_transmit
    ORACLE_HOME=S:\2005SR1
    ORACLE_SERVER=TEAMCENTER31
    ORACLE_SID=tceng
    ORA_NLS33=S:\2005SR1\nls\data
    TNS_ADMIN=S:\utv
    API_JOURNAL=OFF
    UGII_APISERVER_PROGRAM=S:\2005SR1\bin\start_apiserver.bat
    UGII_BASE_DIR=C:\Program Files\UGS\NX 4.0
    UGII_LANG=russian
    UGII_LICENSE_FILE=27000@otd591-13
    UGII_ROOT_DIR=C:\Program Files\UGS\NX 4.0\UGII\
    UGII_TEMP_DIR=c:\temp_tce
    UGII_TMP_DIR=c:\temp
    XBMLANGPATH=S:\utv\bitmaps\%B
    XFILESEARCHPATH=S:\utv\bitmaps\%N\;S:\utv\%N%S
    UGII_LANG=russian
    Path=S:\2005SR1\portal\fms\bin;S:\2005SR1\portal\fms\lib;S:\2005SR1\portal\fms;S:\2005SR1\bin;S:\2005SR1\install\install\jre\bin\client;S:\2005SR1\install\install\jre\bin;S:\2005SR1\install\install\jre\bin\server;S:\2005SR1\fms;S:\2005SR1\fms\lib;S:\2005SR1\bin;S:\2005SR1\portal\fms\bin;S:\2005SR1\portal\fms\lib;S:\2005SR1\portal;D:\app\product\11.1.0\db_1\bin;C:\PROGRA~1\Borland\CBUILD~1\Bin;C:\PROGRA~1\Borland\CBUILD~1\Projects\Bpl;C:\Program Files\Java\jdk1.7.0_21\bin;c:\Program Files\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
    PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
    S:\2005SR1\bin\tcserver.exe                      V10.0.3.8.3.0823 понедельник, 08/24/2009 11:47:34
    C:\WINDOWS\system32\ntdll.dll                    5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\kernel32.dll                 5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    S:\2005SR1\bin\libugmgr_im.dll                   V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:07
    S:\2005SR1\bin\libpom.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:19
    S:\2005SR1\bin\libsyss.dll                       4.0.0.27         пятница, 09/11/2009 08:26:23
    S:\2005SR1\bin\MSVCR71.dll                       7.10.3052.4      пятница, 09/11/2009 08:26:22
    S:\2005SR1\bin\MSVCP71.dll                       7.10.3077.0      пятница, 09/11/2009 08:26:18
    C:\WINDOWS\system32\ADVAPI32.dll                 5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\RPCRT4.dll                   5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\Secur32.dll                  5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\USER32.dll                   5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\GDI32.dll                    5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\ole32.dll                    5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\msvcrt.dll                   7.0.2600.5512    понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\OLEAUT32.dll                 5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\ODBC32.dll                   3.525.1132.0     понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\COMCTL32.dll                 5.82.2900        понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\comdlg32.dll                 6.00.2900.5512   понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\SHELL32.dll                  6.0.2900         понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\SHLWAPI.dll                  6.0.2900         понедельник, 06/09/2008 12:00:00
    S:\2005SR1\bin\libtcsso.dll                                       пятница, 09/11/2009 08:26:09
    C:\WINDOWS\system32\WSOCK32.dll                  5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\WS2_32.dll                   5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\WS2HELP.dll                  5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    S:\2005SR1\bin\TcCrypto.dll                                       пятница, 09/11/2009 08:26:06
    C:\WINDOWS\system32\PSAPI.DLL                    5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    S:\2005SR1\bin\OCIW32.dll                        9.2.0.7.0        пятница, 09/11/2009 08:26:12
    S:\2005SR1\bin\libae.dll                         V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:16
    S:\2005SR1\bin\libcxpom.dll                      V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:06
    S:\2005SR1\bin\libfclasses.dll                   V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:17
    S:\2005SR1\bin\libappr.dll                       V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:12
    S:\2005SR1\bin\libbom.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:17
    S:\2005SR1\bin\libcfm.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:15
    S:\2005SR1\bin\libepm.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:14
    S:\2005SR1\bin\libarchive.dll                    V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:22
    S:\2005SR1\bin\libbackup.dll                     V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:13
    S:\2005SR1\bin\libiman.dll                       V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:11
    S:\2005SR1\bin\libaie.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:14
    S:\2005SR1\bin\libform.dll                       V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:05
    S:\2005SR1\bin\libeint.dll                       V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:11
    S:\2005SR1\bin\libeintstub.dll                   V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:18
    S:\2005SR1\bin\libss.dll                         V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:08
    C:\WINDOWS\system32\MPR.dll                      5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    S:\2005SR1\bin\icuuc32.dll                       3, 2, 0, 0       пятница, 09/11/2009 08:26:17
    S:\2005SR1\bin\icudt32.dll                       3, 2, 0, 0       пятница, 09/11/2009 08:26:09
    S:\2005SR1\bin\libaiwebservice.dll               V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:08
    S:\2005SR1\bin\libtceng_utils.dll                V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:09
    S:\2005SR1\bin\pcl51.dll                         5.1.1.003        пятница, 09/11/2009 08:26:06
    S:\2005SR1\bin\plmxml51.dll                      5.1.1.039        пятница, 09/11/2009 08:26:07
    S:\2005SR1\bin\xpk51.dll                         5.1.1.003        пятница, 09/11/2009 08:26:16
    S:\2005SR1\bin\libps.dll                         V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:13
    S:\2005SR1\bin\libcollabctx.dll                  V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:12
    S:\2005SR1\bin\libimancore.dll                   V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:17
    S:\2005SR1\bin\libecm.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:11
    S:\2005SR1\bin\libme.dll                         V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:20
    S:\2005SR1\bin\libics.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:12
    S:\2005SR1\bin\libitk.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:19
    S:\2005SR1\bin\libbmf.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:08
    S:\2005SR1\bin\libtextsrv.dll                    V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:18
    S:\2005SR1\bin\libsa.dll                         V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:20
    S:\2005SR1\bin\libobjio.dll                      V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:10
    S:\2005SR1\bin\libproperty.dll                   V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:05
    S:\2005SR1\bin\liblov.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:09
    S:\2005SR1\bin\libres.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:24
    S:\2005SR1\bin\libmgc.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:18
    S:\2005SR1\bin\libpublication.dll                V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:22
    S:\2005SR1\bin\libpie.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:21
    S:\2005SR1\bin\libgrm.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:08
    S:\2005SR1\bin\libmechatronics.dll               V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:06
    S:\2005SR1\bin\libove.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:20
    S:\2005SR1\bin\libtcengcoreext.dll               V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:15
    S:\2005SR1\bin\libuser_exits.dll                 V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:12
    S:\2005SR1\bin\libdmi.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:05
    S:\2005SR1\bin\libqry.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:05
    S:\2005SR1\bin\libsml.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:05
    S:\2005SR1\bin\libusagewc.dll                    V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:09
    S:\2005SR1\bin\librdv.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:23
    S:\2005SR1\bin\libimantrushape.dll               V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:09
    S:\2005SR1\bin\xerces260.dll                                      пятница, 09/11/2009 08:26:12
    S:\2005SR1\bin\libuglm.dll                       4.0.0.25         пятница, 09/11/2009 08:26:18
    C:\WINDOWS\system32\NETAPI32.dll                 5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    S:\2005SR1\bin\libusage.dll                      V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:08
    S:\2005SR1\bin\xalan19.dll                                        пятница, 09/11/2009 08:26:22
    S:\2005SR1\bin\libsub_mgr.dll                    V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:11
    S:\2005SR1\bin\FPLibrary.dll                     Version 2.3      пятница, 09/11/2009 08:26:16
    S:\2005SR1\bin\FPParser.dll                                       пятница, 09/11/2009 08:26:06
    S:\2005SR1\bin\PAI_module.dll                    Version 2.3      пятница, 09/11/2009 08:26:15
    S:\2005SR1\bin\plmxmlBusiness51.dll              5.1.1.005        пятница, 09/11/2009 08:26:05
    S:\2005SR1\bin\plmxmlTcEng51.dll                 5.1.1.005        пятница, 09/11/2009 08:26:20
    S:\2005SR1\bin\plmxmlClassification51.dll        5.1.1.006        пятница, 09/11/2009 08:26:13
    S:\2005SR1\bin\plmxmlMechatronics51.dll          5.1.1.005        пятница, 09/11/2009 08:26:09
    S:\2005SR1\bin\plmxmlMPM51.dll                   5.1.1.005        пятница, 09/11/2009 08:26:10
    S:\2005SR1\bin\plmxmlDelta51.dll                 5.1.1.005        пятница, 09/11/2009 08:26:12
    S:\2005SR1\bin\WINRPC32.dll                      3.5.1            пятница, 09/11/2009 08:26:06
    S:\2005SR1\bin\libinternal_exits.dll             V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:19
    S:\2005SR1\bin\aiwebservice_pth.dll                               пятница, 09/11/2009 08:26:17
    S:\2005SR1\bin\SSLEAY32.dll                                       пятница, 09/11/2009 08:26:21
    S:\2005SR1\bin\LIBEAY32.dll                                       пятница, 09/11/2009 08:26:20
    S:\2005SR1\bin\OCI.dll                                            пятница, 09/11/2009 08:26:21
    S:\2005SR1\bin\oraclient9.dll                                     пятница, 09/11/2009 08:26:10
    S:\2005SR1\bin\oracore9.dll                                       пятница, 09/11/2009 08:26:16
    S:\2005SR1\bin\oranls9.dll                                        пятница, 09/11/2009 08:26:15
    S:\2005SR1\bin\oraunls9.dll                                       пятница, 09/11/2009 08:26:18
    C:\WINDOWS\system32\WINMM.dll                    5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    S:\2005SR1\bin\oravsn9.dll                                        пятница, 09/11/2009 08:26:21
    S:\2005SR1\bin\oracommon9.dll                                     пятница, 09/11/2009 08:26:11
    S:\2005SR1\bin\orageneric9.dll                                    пятница, 09/11/2009 08:26:19
    S:\2005SR1\bin\oraxml9.dll                                        пятница, 09/11/2009 08:26:13
    C:\WINDOWS\system32\MSVCIRT.dll                  5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    S:\2005SR1\bin\oraxsd9.dll                                        пятница, 09/11/2009 08:26:19
    S:\2005SR1\bin\oran9.dll                                          пятница, 09/11/2009 08:26:15
    S:\2005SR1\bin\oranl9.dll                                         пятница, 09/11/2009 08:26:22
    S:\2005SR1\bin\oranldap9.dll                                      пятница, 09/11/2009 08:26:11
    S:\2005SR1\bin\orannzsbb9.dll                                     пятница, 09/11/2009 08:26:20
    S:\2005SR1\bin\oraldapclnt9.dll                                   пятница, 09/11/2009 08:26:18
    S:\2005SR1\bin\orancrypt9.dll                                     пятница, 09/11/2009 08:26:19
    S:\2005SR1\bin\ORATRACE9.dll                                      пятница, 09/11/2009 08:26:15
    S:\2005SR1\bin\oranro9.dll                                        пятница, 09/11/2009 08:26:20
    S:\2005SR1\bin\oranhost9.dll                                      пятница, 09/11/2009 08:26:19
    S:\2005SR1\bin\oranoname9.dll                                     пятница, 09/11/2009 08:26:15
    S:\2005SR1\bin\orancds9.dll                                       пятница, 09/11/2009 08:26:12
    S:\2005SR1\bin\orantns9.dll                                       пятница, 09/11/2009 08:26:20
    S:\2005SR1\bin\oranms.dll                                         пятница, 09/11/2009 08:26:23
    S:\2005SR1\bin\oranmsp.dll                                        пятница, 09/11/2009 08:26:20
    S:\2005SR1\bin\orapls9.dll                                        пятница, 09/11/2009 08:26:08
    S:\2005SR1\bin\oraslax9.dll                                       пятница, 09/11/2009 08:26:21
    S:\2005SR1\bin\orasnls9.dll                                       пятница, 09/11/2009 08:26:21
    S:\2005SR1\bin\orawtc9.dll                                        пятница, 09/11/2009 08:26:23
    S:\2005SR1\bin\orasql9.dll                                        пятница, 09/11/2009 08:26:10
    S:\2005SR1\bin\libcae.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:19
    S:\2005SR1\bin\LIBARM32.dll                      V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:06
    S:\2005SR1\bin\libvispublish.dll                 V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:10
    S:\2005SR1\bin\libexpress.dll                    V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:13
    C:\WINDOWS\system32\VERSION.dll                  5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    S:\2005SR1\bin\libugmath.dll                     4.0.0.25         пятница, 09/11/2009 08:26:08
    S:\2005SR1\bin\libpdi_corba_server.dll           V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:24
    S:\2005SR1\bin\ACE.dll                           5.4a_p2          пятница, 09/11/2009 08:26:08
    C:\WINDOWS\system32\MSWSOCK.dll                  5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    S:\2005SR1\bin\TAO.dll                           1.4a_p2          пятница, 09/11/2009 08:26:15
    S:\2005SR1\bin\TAO_PortableServer.dll            1.4a_p2          пятница, 09/11/2009 08:26:22
    S:\2005SR1\bin\libtcgateway.dll                  V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:05
    S:\2005SR1\bin\libvis.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:10
    S:\2005SR1\bin\libgdis.dll                       V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:06
    S:\2005SR1\bin\libicctimpl.dll                   V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:11
    S:\2005SR1\bin\libict.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:18
    S:\2005SR1\bin\librwr.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:19
    S:\2005SR1\bin\libstep.dll                       V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:18
    S:\2005SR1\bin\libicctskel.dll                   V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:10
    S:\2005SR1\bin\libtcxsd.dll                      V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:21
    S:\2005SR1\bin\libtcwebdav.dll                   V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:17
    S:\2005SR1\bin\libweb.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:24
    S:\2005SR1\bin\libtcsoacommon.dll                V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:09
    S:\2005SR1\bin\libtcsoaserver.dll                V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:20
    S:\2005SR1\bin\libmrp.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:22
    S:\2005SR1\bin\libsap.dll                        V10.0.3.8.3.0823 пятница, 09/11/2009 08:26:06
    S:\2005SR1\bin\TAO_IORTable.dll                  1.4a_p2          пятница, 09/11/2009 08:26:09
    C:\WINDOWS\system32\IMM32.DLL                    5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll 6.0.2900         понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\odbcint.dll                  3.525.1117.0     понедельник, 06/09/2008 12:00:00
    S:\2005SR1\bin\orantcp9.dll                                       вторник, 01/24/2006 04:45:42
    C:\WINDOWS\system32\hnetcfg.dll                  5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\System32\wshtcpip.dll                 5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\DNSAPI.dll                   5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\System32\winrnr.dll                   5.1.2600.5512    понедельник, 06/09/2008 12:00:00
    C:\WINDOWS\system32\WLDAP32.dll                  5.1.2600.5512    понедельник, 06/09/2008 12:00:00
The Transient Volume Root Directory at C:\Documents and Settings\q\Local Settings\Temp\TransientDirs already exists.
Loaded library libtccoresvc
Loaded library libtcpsmsvc
Loaded library libtccbasvc
Loaded library libtcscmsvc
Loaded library libtcmechatronicssvc
Loaded library libtcsoacore
Loaded library libtcsoaadministration
Loaded library libtcsoaquery
Loaded library libtcsoaai
Loaded library libtcsoacad
Loaded library libtcsoamultisite
Loaded library libtcintegration
Loaded library libtcsoatranslation
Loaded library libtcsoagdis
	SCHEMA LOADED
POM_login: "Админстратор" admin / dba has logged in
ACS is initialized for usage-based licensing.
UGFLEXlm Log: License server "27000@otd591-13" has been connected.
*************  Teamcenter Licensing Information  ************ *
  Server ID            : UGS
  License File Issuer  : UGS
Current POM environment information:
            Timeout:  Strategy 0 Interval 0
          AM bypass:  DISABLED
          Wildcards:  one "?" any "%"
          AM bypass:  DISABLED
          Wildcards:  one "?" any "*"
POM Package "POM_UTILS" not installed
            Timeout:  Strategy 4001 Interval 0
          AM bypass:  DISABLED
            Timeout:  Strategy 4001 Interval 5
          AM bypass:  DISABLED
          AM bypass:  DISABLED
        Journalling:  DISABLED
24 seconds to POM DB x-act
ConstructorRegistry::registerConstructor -- no 'TCX_SCConfig' class in the database
this is probably because you are running new code (which expects the new class) against
an old database which has not been upgraded to have the new class
FTS: The FTS engine could not be found.
Method ListOfValuesChar: LOV_create / <<null prop>> already registered
Method ListOfValuesChar: LOV_insert_values / <<null prop>> already registered
Method ListOfValuesChar: LOV_ask_values / <<null prop>> already registered
Method ListOfValuesChar: LOV_set_values / <<null prop>> already registered
Method ListOfValuesChar: LOV_is_valid / <<null prop>> already registered
Method ListOfValuesChar: LOV_ask_num_of_values / <<null prop>> already registered
Method ListOfValuesChar: LOV_ask_disp_values / <<null prop>> already registered
Method ListOfValuesChar: LOV_ask_value_descriptions / <<null prop>> already registered
Method ListOfValuesChar: LOV_set_value_descriptions / <<null prop>> already registered
Method ContentStorage: OBJIO_SM_store / <<null prop>> already registered
Method ContentStorage: OBJIO_SM_retrieve / <<null prop>> already registered
Method ContentStorage: OBJIO_SM_online / <<null prop>> already registered
Method ContentStorage: OBJIO_SM_transfer_imanfiles / <<null prop>> already registered
Method ContentStorage: OBJIO_SM_retrieve_imanfile_from_cs / <<null prop>> already registered
Method ContentStorage: OBJIO_SM_store_content_address / <<null prop>> already registered
Method ContentStorage: OBJIO_SM_retrieve_content_address / <<null prop>> already registered
Method ContentStorage: OBJIO_SM_check_file_exists / <<null prop>> already registered
--- iMAN version is: Teamcenter Engineering V10.-1.3.8.3_build_0823 ---
Security Level = 1
UG library version V4.0.0.27
EFFECTIVITY MODEL: V7
  Server ID            : UGS
*** EXCEPTION: Error code  3600004 in line 2076 of W:\libsyss_SR1\src\syss\no\ind\lmldr.c at Wed Jun 25 10:34:41 2014 Московское время (зима)
+++ No such file - libius
Loaded module C:\WINDOWS\system32\icmp.Dll 74250000 4000 c69a7fc8-45343fca-d44e27a5-97908b33-2 version = 5.1.2600.5512
Loaded module C:\WINDOWS\system32\iphlpapi.dll 76d50000 19000 9b09f073-4ca4003f-b380998f-8f4491c0-2 version = 5.1.2600.5512
Loaded module S:\2005SR1\bin\dbghelp.dll 2f30000 b5000 b30a024b-4c91eb63-80fe31bf-aacb5b5-1 version = 6.0.17.0
Loaded module S:\2005SR1\bin\libtcsoagdistypes.dll 2f00000 1b000 8ad8df90-47f6475c-a92a4583-aac8b1bc-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoagdis.dll 2ec0000 3d000 bda30af7-41b234f9-c46c9eb1-b0700264-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoatranslationtypes.dll 2e80000 31000 fb691c7b-4f138448-31f0be98-ce256b0b-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libets_user_exits.dll 2e70000 6000 7c48ce1d-429c7e27-b15c2191-bfb447bb-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libets.dll 2e40000 2a000 897ca674-4447434f-1af83f82-adfa6879-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoatranslation.dll 2df0000 43000 62b38e49-4ddd21ec-bfcf9d85-36081107-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcintegrationtypes.dll 2dc0000 2e000 f40801d-4a6fa34e-78106181-e0661955-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcintegration.dll 2d70000 42000 677d188c-44958c84-573b42a9-17085056-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoamultisitetypes.dll 2d40000 25000 ae68945b-4f027973-380806a8-13a4653f-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoamultisite.dll 2cf0000 44000 2ccd034-4c950a4c-b02bfaa-160466b1-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoacadtypes.dll 2a90000 25b000 726f906d-433e50ac-e269b79d-dd3bed7e-2 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoacad.dll 27f0000 29b000 ec5d8728-4a41324f-5e010b8e-130a51ad-2 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoaaitypes.dll 2720000 c8000 9a1285cc-49d86450-5a0fc488-b75546c8-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoaai.dll 2600000 11d000 f60a5299-431d81da-2030c483-c89770e1-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoaquerytypes.dll 2580000 71000 f1936582-4275fefd-c3eb38b3-fa1b6272-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoaquery.dll 24f0000 88000 202ffea5-43f2b472-43bc25be-7bb06348-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoaadministrationtypes.dll 2480000 65000 fe0e1a98-44bb8392-71d44d83-d0dafcb4-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoaadministration.dll 2400000 73000 79171047-4eafbfa5-a3efaaa2-1645c170-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoacoretypes.dll 20a0000 358000 5720a14c-4794fb36-34f6d3bc-6f78f526-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoacore.dll 1cf0000 3a8000 9f9ac387-4c78a803-ab93f899-d8fe8c40-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcmechatronicssvc.dll 1cd0000 18000 601c0581-401ee5bf-3050389e-28fea3fd-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcscmsvc.dll 1cb0000 19000 829a5b97-4e95f149-a0e2f3a1-4599f3b0-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtccbasvc.dll 1c90000 1a000 694d85e8-44a1b43b-e548d597-591973ca-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcpsmsvc.dll 1c70000 20000 ba08352-46174894-b85951bb-68901fb2-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libinternal_server_exits.dll 1c50000 12000 710afd51-4da611ba-d5a2a097-34f7f7ae-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libserver_exits.dll 1c40000 6000 ef8f44a7-46f41a97-31d536a2-1a987134-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtccoresvc.dll 10000000 41000 b7f99b42-448f2631-67e5ef90-b473de1a-1 version = 10.0.3.8
Loaded module C:\WINDOWS\system32\rasadhlp.dll 76fb0000 6000 cca669b1-47d05828-abd730b3-476a44db-2 version = 5.1.2600.5512
Loaded module C:\WINDOWS\system32\WLDAP32.dll 76f50000 2d000 ac04bcf6-4fceff29-938d8bac-173aba7c-2 version = 5.1.2600.5512
Loaded module C:\WINDOWS\System32\winrnr.dll 76fa0000 8000 9fe1a466-400f9b69-431a82ac-c59caa67-2 version = 5.1.2600.5512
Loaded module C:\WINDOWS\system32\DNSAPI.dll 76f10000 27000 2602de4d-48a89843-d46dc3a8-15e2023f-2 version = 5.1.2600.5512
Loaded module C:\WINDOWS\System32\wshtcpip.dll 71a70000 8000 de2e5260-406d3ffb-d8c85290-72ada184-2 version = 5.1.2600.5512
Loaded module C:\WINDOWS\system32\hnetcfg.dll 698b0000 58000 87332c2b-42fcff6e-a18497b8-71c24ed2-1 version = 5.1.2600.5512
Loaded module S:\2005SR1\bin\orantcp9.dll 11a0000 c000 0-0-0-0-0 version = 9.2.0.7
Loaded module C:\WINDOWS\system32\odbcint.dll 1f840000 18000 0-0-0-0-0 version = 3.525.1117.0
Loaded module C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll 773c0000 103000 50505797-416f1c40-1ded9fb3-57d0be39-1=MicrosoftWindowsCommon-Controls-6.0.2600.5512-comctl32 version = 6.0.2900.5512
Loaded module C:\WINDOWS\system32\IMM32.DLL 76360000 1d000 f7a5b5db-41531332-34af7ab5-51ea770c-2 version = 5.1.2600.5512
Loaded module S:\2005SR1\bin\TAO_IORTable.dll 65ca0000 c000 c49fb7ff-40178564-dd05fb4-cf90718e-1=IORTable version = 1.4.3.0
Loaded module S:\2005SR1\bin\libsap.dll 67660000 6000 406698ef-47b0f7dd-bb27f2b9-d2e3132c-1=libsap_generic version = 10.0.3.8
Loaded module S:\2005SR1\bin\libmrp.dll 60e50000 42000 be087bf2-4778e7e7-fad68b97-3d3e5a1d-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoaserver.dll 61880000 68000 b999d1f6-445d19d3-56954d92-db729712-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcsoacommon.dll 65a80000 88000 bc82955d-4f813f46-d89ebd89-34a0dba6-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libweb.dll 5fed0000 41a000 4fda1922-4bf8f055-7161cfbb-57216031-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcwebdav.dll 62840000 3a000 9ac18728-41f448f8-2887c790-c5d5bfd8-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcxsd.dll 61050000 7b000 a219a670-4a5ff3c8-b90755bd-36cf27ef-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libicctskel.dll 64fb0000 732000 3248432f-49232cb6-f292babc-1b14e255-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libstep.dll 622c0000 199000 5994a40b-4d97b9e2-2a06e5bb-8a570b69-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\librwr.dll 61aa0000 59000 89a35ccd-4ba7ce6a-264e448a-fca10e5a-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libict.dll 62460000 26a000 da326fb4-47fd23df-11f22ca7-2c78adac-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libicctimpl.dll 64b60000 420000 943380ab-48fe7211-52c61ea8-8092f1a2-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libgdis.dll 679d0000 21000 a6d5b7ab-4b879e61-5dfa5982-da2eeaa7-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libvis.dll 64f90000 1d000 10ff3f4a-4770aeb4-8f141182-96e28faf-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcgateway.dll 67b00000 84000 409f11cc-4e43e2ff-7d622b85-22b50be5-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\TAO_PortableServer.dll 60f20000 96000 e976c3c6-43de98ad-eda751b2-5b54f370-1=PortableServer version = 1.4.3.0
Loaded module S:\2005SR1\bin\TAO.dll 633d0000 190000 b5dd6f3d-497c6cb7-97ab0783-a0029904-1 version = 1.4.3.0
Loaded module C:\WINDOWS\system32\MSWSOCK.dll 71a30000 40000 bc563e5-43e42f9e-a94d079e-7171417d-2 version = 5.1.2600.5512
Loaded module S:\2005SR1\bin\ACE.dll 66b70000 107000 938177b-47ffb5d9-22222d98-8d3ee07-1 version = 5.4.3.0
Loaded module S:\2005SR1\bin\libpdi_corba_server.dll 602f0000 350000 647e5420-4cb395be-b240ca88-2624cd57-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libugmath.dll 66d10000 66000 33687b0-46df5b62-23a2a99e-e5a16d14-4 version = 4.0.0.25
Loaded module C:\WINDOWS\system32\VERSION.dll 77bf0000 8000 ea3d1bd3-475cfe65-d8c84984-962207b0-2 version = 5.1.2600.5512
Loaded module S:\2005SR1\bin\libexpress.dll 63df0000 e7000 aa9e2f0c-45648316-f6ce69a4-3e252d3a-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libvispublish.dll 64f80000 f000 9f215986-488932fd-fceb4b93-352e7d63-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\LIBARM32.dll 679c0000 6000 7cd00acf-4c4aa014-2337ecba-ec8a1441-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libcae.dll 61b30000 98000 e96f3c30-42ea36c4-b5d3a82-d8611673-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\orasql9.dll 658e0000 77000 0-0-0-0-0 version = 9.2.0.6
Loaded module S:\2005SR1\bin\orawtc9.dll 60650000 6000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\orasnls9.dll 61000000 11000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\oraslax9.dll 60ff0000 7000 0-0-0-0-0 version = 0.0.0.0
Loaded module S:\2005SR1\bin\orapls9.dll 66840000 321000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\oranmsp.dll 61800000 11000 0-0-0-0-0 version = 9.2.0.0
Loaded module S:\2005SR1\bin\oranms.dll 60640000 7000 0-0-0-0-0 version = 9.2.0.0
Loaded module S:\2005SR1\bin\orantns9.dll 61760000 7000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\orancds9.dll 64530000 6000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\oranoname9.dll 63660000 6000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\oranhost9.dll 61a90000 6000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\oranro9.dll 615c0000 37000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\ORATRACE9.dll 63560000 3e000 0-0-0-0-0 version = 0
Loaded module S:\2005SR1\bin\orancrypt9.dll 61a50000 18000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\oraldapclnt9.dll 62760000 26000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\orannzsbb9.dll 61770000 90000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\oranldap9.dll 64890000 13000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\oranl9.dll 60ef0000 2c000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\oran9.dll 635a0000 b6000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\oraxsd9.dll 61b00000 2a000 0-0-0-0-0 version = 9.2.0.9
Loaded module C:\WINDOWS\system32\MSVCIRT.dll 330000 11000 bc303bbd-4dc88b94-d7dcfcb1-3cd6f135-1 version = 7.0.2600.5512
Loaded module S:\2005SR1\bin\oraxml9.dll 63cf0000 7f000 0-0-0-0-0 version = 9.2.0.9
Loaded module S:\2005SR1\bin\orageneric9.dll 61f10000 28d000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\oracommon9.dll 64a60000 91000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\oravsn9.dll 610d0000 6000 0-0-0-0-0 version = 9.2.0.7
Loaded module C:\WINDOWS\system32\WINMM.dll 76b20000 2e000 90fc96d5-40a2ad84-895548b1-d62ed95b-2 version = 5.1.2600.5512
Loaded module S:\2005SR1\bin\oraunls9.dll 62790000 11000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\oranls9.dll 637d0000 7a000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\oracore9.dll 63260000 a0000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\oraclient9.dll 65740000 193000 0-0-0-0-0 version = 9.2.0.7
Loaded module S:\2005SR1\bin\OCI.dll 61020000 2b000 0-0-0-0-0 version = 0.0.0.0
Loaded module S:\2005SR1\bin\LIBEAY32.dll 61600000 c6000 0-0-0-0-0 version = 0
Loaded module S:\2005SR1\bin\SSLEAY32.dll 60fc0000 26000 0-0-0-0-0 version = 0
Loaded module S:\2005SR1\bin\aiwebservice_pth.dll 62cb0000 9000 0-0-0-0-0 version = 0
Loaded module S:\2005SR1\bin\libinternal_exits.dll 61bd0000 a000 19570fd4-41368e39-fa259dac-5762da5b-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\WINRPC32.dll 67920000 13000 0-0-0-0-0 version = 3.10.5.0
Loaded module S:\2005SR1\bin\plmxmlDelta51.dll 644f0000 2b000 0-0-0-0-0 version = 5.1.1.5
Loaded module S:\2005SR1\bin\plmxmlMPM51.dll 656f0000 50000 0-0-0-0-0 version = 5.1.1.5
Loaded module S:\2005SR1\bin\plmxmlMechatronics51.dll 65b10000 5f000 0-0-0-0-0 version = 5.1.1.5
Loaded module S:\2005SR1\bin\plmxmlClassification51.dll 63d70000 77000 0-0-0-0-0 version = 5.1.1.6
Loaded module S:\2005SR1\bin\plmxmlTcEng51.dll 616d0000 85000 0-0-0-0-0 version = 5.1.1.5
Loaded module S:\2005SR1\bin\plmxmlBusiness51.dll 67cb0000 8f000 0-0-0-0-0 version = 5.1.1.5
Loaded module S:\2005SR1\bin\PAI_module.dll 63670000 41000 0-0-0-0-0 version = 2.3.39.0
Loaded module S:\2005SR1\bin\FPParser.dll 67670000 2a5000 0-0-0-0-0 version = 0
Loaded module S:\2005SR1\bin\FPLibrary.dll 63010000 243000 0-0-0-0-0 version = 2.3.301.0
Loaded module S:\2005SR1\bin\libsub_mgr.dll 64b00000 56000 9f9af5c3-4a9f965d-8872659d-d75e6aee-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\xalan19.dll 60c90000 1be000 0-0-0-0-0 version = 0
Loaded module S:\2005SR1\bin\libusage.dll 66ce0000 22000 dacbbb3d-4869ec72-fd98b699-cca13b6e-1 version = 10.0.3.8
Loaded module C:\WINDOWS\system32\NETAPI32.dll 5bd50000 55000 fb9eef3b-49ba11c9-78d3fb95-b0070a26-2 version = 5.1.2600.5512
Loaded module S:\2005SR1\bin\libuglm.dll 621d0000 f0000 56d03dd0-425b50d4-d2b9e8be-ebcd81ae-2 version = 4.0.0.25
Loaded module S:\2005SR1\bin\xerces260.dll 64110000 205000 0-0-0-0-0 version = 0
Loaded module S:\2005SR1\bin\libimantrushape.dll 65cb0000 45000 b363478b-465185d3-3929b090-4fcc2c87-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\librdv.dll 60660000 231000 1fc9befb-40160b15-d2c2c29b-77a91b8f-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libusagewc.dll 65d00000 14e000 7d2dc889-40e9c12b-fc8ee8ac-28a670ad-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libsml.dll 67e80000 174000 d5372c0c-4af3bcb6-bb6bfcba-6e95ae03-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libqry.dll 67d40000 dc000 a72e53ce-4ccf2855-959b5e83-5e646cb0-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libdmi.dll 67b90000 1e000 7f7091a1-41c19622-170c6d92-4a0b8da0-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libuser_exits.dll 64540000 50000 1d2adcd-4ac232ba-46a1e793-c4d46659-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtcengcoreext.dll 636c0000 57000 95c2d080-4d556aa8-26f12db2-95e9405a-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libove.dll 61820000 5e000 3e84b524-4158bd60-79ebce8f-b54b6b9b-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libmechatronics.dll 67a30000 c4000 2821bb0-4bd786c7-bf3d42aa-d207b388-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libgrm.dll 66820000 1f000 db1ab02b-406c7b9f-f7a419a1-4d4adec9-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libpie.dll 610e0000 38a000 3cd626c6-4c9d5162-f4faadbb-579c0aa5-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libpublication.dll 60b40000 148000 16c9c237-43d99284-ae00d7b7-7ddd3947-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libmgc.dll 626d0000 6000 2bd7c833-4e417802-4ac1cba4-ea0f61f-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libres.dll 5fe80000 48000 239abb7a-4100cc7d-86b60ea7-f0bad9c8-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\liblov.dll 65bd0000 c3000 20d38d18-4244c2b8-e303848c-7ca5508f-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libproperty.dll 67bb0000 100000 5cc41fc-472af498-aa4d3785-bf2367d4-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libobjio.dll 65960000 11e000 9ab438d6-4e08dbd6-d8583abc-109311dc-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libsa.dll 61470000 14b000 6ee6110f-447f0747-d29d4bb4-5e2cea81-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libtextsrv.dll 621a0000 24000 50b66b67-4a97a868-a6560fa7-d3975015-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libbmf.dll 66c80000 60000 1f3a67a9-423f7a3e-206b69af-8aa28eb1-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libitk.dll 61a70000 13000 c2752497-43169f13-b22c86a0-512dc90e-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libics.dll 64590000 1e6000 7d9602f5-4dae2e17-6d97a9ab-5c15a5f4-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libme.dll 618f0000 151000 e4de8f79-4c543615-f344709d-b1d36478-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libecm.dll 647d0000 b2000 90ea3f9c-442ac831-e45a1b83-447f2542-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libimancore.dll 62940000 362000 5f6c5db7-47d4393a-9a0ba9bd-8d4d26de-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libcollabctx.dll 64320000 3d000 4a478eb4-46e5a6c0-6adf2e9c-42f21302-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libps.dll 63ee0000 225000 76111ccc-4e71aa88-583a1280-95591493-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\xpk51.dll 63300000 a000 0-0-0-0-0 version = 5.1.1.3
Loaded module S:\2005SR1\bin\plmxml51.dll 67280000 31e000 0-0-0-0-0 version = 5.1.1.39
Loaded module S:\2005SR1\bin\pcl51.dll 67a00000 2c000 0-0-0-0-0 version = 5.1.1.3
Loaded module S:\2005SR1\bin\libtceng_utils.dll 65b70000 5b000 69e5d9f-474e2b07-3017509e-b0c595f8-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libaiwebservice.dll 66d80000 22d000 67eeb750-48f08496-342553b1-d42540c3-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\icudt32.dll 65ea0000 956000 0-0-0-0-0 version = 3.2.0.0
Loaded module S:\2005SR1\bin\icuuc32.dll 62cc0000 94000 0-0-0-0-0 version = 3.2.0.0
Loaded module C:\WINDOWS\system32\MPR.dll 71b00000 12000 a9b54230-4aa26c36-fe5ef2ba-5a2b3c9f-2 version = 5.1.2600.5512
Loaded module S:\2005SR1\bin\libss.dll 66800000 20000 985fd446-47de4d5d-d88c3ba4-4645dd7-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libeintstub.dll 627b0000 87000 e12d9aa8-4f215df2-5af096a3-63de184f-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libeint.dll 64780000 49000 92fed856-4230f965-837ccf83-2e1f91da-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libform.dll 67e20000 5f000 957473d7-4f4939f9-2663578b-c4116770-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libaie.dll 63850000 112000 f0b18f1-4f51abab-3f166180-c05b2064-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libiman.dll 648b0000 1a1000 b01df647-4e0d8649-c4d133af-f7cd7bcb-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libbackup.dll 63cc0000 22000 7b5c49b2-416f7942-466212a2-a00eca0f-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libarchive.dll 60ea0000 4f000 e3cd2507-476e1240-9286c180-89de2127-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libepm.dll 63970000 345000 357cde59-4bdce319-4edb0cbd-9e5be331-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libcfm.dll 63720000 a9000 59616c59-47a59810-61634298-9678ef3c-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libbom.dll 62d60000 2ae000 178b7de0-4a31d7f9-a83e1b9a-d824f382-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libappr.dll 64360000 190000 ce0a9eb1-40e0b715-b973cabc-7004483c-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libfclasses.dll 62880000 b5000 b92137a6-425078d4-7a42daae-16d4fffa-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libcxpom.dll 67940000 7f000 f2e4095c-44f9ca4e-e0151786-8c15b620-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libae.dll 63310000 c0000 f1fb2bd8-49ca1c5b-def6b0a7-343ee42b-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\OCIW32.dll 64520000 9000 0-0-0-0-0 version = 1.0.0.5
Loaded module C:\WINDOWS\system32\PSAPI.DLL 76be0000 b000 b9875a55-4893c874-b88fea84-312c3205-2 version = 5.1.2600.5512
Loaded module S:\2005SR1\bin\TcCrypto.dll 675a0000 b9000 0-0-0-0-0 version = 0
Loaded module C:\WINDOWS\system32\WS2HELP.dll 71a80000 8000 6049cf58-4e2a77c5-c1ab12b5-99e7b2b4-2 version = 5.1.2600.5512
Loaded module C:\WINDOWS\system32\WS2_32.dll 71a90000 17000 a7605f86-432995a3-84db8db3-ca04a021-2 version = 5.1.2600.5512
Loaded module C:\WINDOWS\system32\WSOCK32.dll 71ab0000 a000 2b38fe8f-4dac8414-7fda4b8-fc495ec0-2 version = 5.1.2600.5512
Loaded module S:\2005SR1\bin\libtcsso.dll 65e50000 50000 9cd14357-42a53a9f-4ab02b94-d3c71285-1 version = 0
Loaded module C:\WINDOWS\system32\SHLWAPI.dll 77f60000 76000 8519e340-47883447-7ffecf84-e0ba911a-2 version = 6.0.2900.5512
Loaded module C:\WINDOWS\system32\SHELL32.dll 7c9c0000 81b000 69b3829b-4926b688-f07bb9a5-6b2c814e-2 version = 6.0.2900.5512
Loaded module C:\WINDOWS\system32\comdlg32.dll 76380000 49000 26a6ff7-4e6170fd-e9bbad86-9ca9ff6d-2 version = 6.0.2900.5512
Loaded module C:\WINDOWS\system32\COMCTL32.dll 5d5b0000 9a000 3053768f-4ab464ff-e49545b7-48b8e2e5-2 version = 5.82.2900.5512
Loaded module C:\WINDOWS\system32\ODBC32.dll 73fb0000 3d000 602a6ab-4bea21f8-c639309b-4c88ac72-2 version = 3.525.1132.0
Loaded module C:\WINDOWS\system32\OLEAUT32.dll 77110000 8b000 f2a20900-4efc9b69-e96c1aad-c1eb92d9-2 version = 5.1.2600.5512
Loaded module C:\WINDOWS\system32\msvcrt.dll 77c00000 58000 7bcf30d8-4f1bc91b-554efa85-11506289-1 version = 7.0.2600.5512
Loaded module C:\WINDOWS\system32\ole32.dll 774d0000 13d000 ed517599-4cf1d2c1-18860092-149c0533-2 version = 5.1.2600.5512
Loaded module C:\WINDOWS\system32\GDI32.dll 77f10000 49000 740f60a9-417e9f2a-4087c396-8d589409-2 version = 5.1.2600.5512
Loaded module C:\WINDOWS\system32\USER32.dll 7e360000 91000 d18a41b7-458c4e7f-4718acaa-2bfd8e2-2 version = 5.1.2600.5512
Loaded module C:\WINDOWS\system32\Secur32.dll 77fe0000 11000 e8d37874-4a460b8e-cdaf9cb1-7ddf6d2d-2 version = 5.1.2600.5512
Loaded module C:\WINDOWS\system32\RPCRT4.dll 77e70000 92000 ccd4fe9b-48b6704e-312fa1b8-6faa12e1-2 version = 5.1.2600.5512
Loaded module C:\WINDOWS\system32\ADVAPI32.dll 77dc0000 ac000 5efb9bf4-40242cc6-2e8064ab-64947346-2 version = 5.1.2600.5512
Loaded module S:\2005SR1\bin\MSVCP71.dll 626e0000 7b000 27e1f58f-4d023f1a-b26a2ca4-3c8c5a66-2 version = 7.10.3077.0
Loaded module S:\2005SR1\bin\MSVCR71.dll 60ae0000 56000 630c7917-42c05c19-4ebcc999-9c619d0-2 version = 7.10.3052.4
Loaded module S:\2005SR1\bin\libsyss.dll 608a0000 236000 4e6477e5-48341649-ba066e8f-8a9fa11d-2 version = 4.0.0.27
Loaded module S:\2005SR1\bin\libpom.dll 61be0000 32b000 4cd45f3e-4ab25ac4-903651bf-d6e5ff44-1 version = 10.0.3.8
Loaded module S:\2005SR1\bin\libugmgr_im.dll 66fb0000 2c4000 83dcc4d5-4fc97dd7-9997db8a-861cc0d5-1 version = 10.0.3.8
Loaded module C:\WINDOWS\system32\kernel32.dll 7c800000 f8000 34560e80-4175f5c5-8e8408b2-bdc563f8-2 version = 5.1.2600.5512
Loaded module C:\WINDOWS\system32\ntdll.dll 7c900000 b0000 17510032-425960ca-26b30f8c-ed005058-2 version = 5.1.2600.5512
Loaded module S:\2005SR1\bin\tcserver.exe 400000 26000 23fb1cf8-4bddea84-64b6cf9f-15249ede-1 version = 10.0.3.8
[ 2] 608A9772 error_wnt_trace_back\ERROR_trace_back Line 1020 +0xa2        (libsyss)
[ 3] 60970564 error_exception\UGS::Error::Exception::doTraceback Line 652 +0x74 (libsyss)
[ 4] 6097166B error_standard\UGS::Error::Standard::Standard Line 167 +0x5b (libsyss)
[ 5] 6097180B error_standard\UGS::Error::Standard::raise Line 94 +0x3b     (libsyss)
[ 6] 60940A9C error\error_ftn_note Line 555 +0xbc                          (libsyss)
[ 7] 609410E1 error\ERROR_raise Line 1993 +0x21                            (libsyss)
[ 8] 608B76AE lmldr\LDR_load_imageEx Line 2091 +0x2de                      (libsyss)
[ 9] 608B7B92 lmldr\LDR_load_image Line 1814 +0x22                         (libsyss)
[10] 01C5630E internal_server_exits\USERSERVICE_register_internal_methods Line 213 +0x23e (libinternal_server_exits)
[11] 1000CEDD tcloginservice\TcLoginService::login Line 495 +0x1ed         (libtccoresvc)
[12] 1001EB0D bindtcloginservice\BindTcLoginService::login Line 280 +0x23d (libtccoresvc)
[13] 1001E369 bindtcloginservice\BindTcLoginService::invokeMethod Line 183 +0x1d9 (libtccoresvc)
[14] 67B287F9 tcservicegateway_i\TcServiceGateway_i::invokeMethod Line 497 +0x279 (libtcgateway)
[15] 67B35377 tccorbaservicegateways\POA_TcCorbaServiceGateway::invokeMethod_skel Line 1672 +0x217 (libtcgateway)
[16] 60F58ED9                                                              (TAO_PortableServer)
[17] 67B368F9 tccorbaservicegateways\POA_TcCorbaServiceGateway::_dispatch Line 2592 +0x39 (libtcgateway)
[18] 60F3BEC6                                                              (TAO_PortableServer)
[19] 633D6916                                                              (TAO)
>>>> Error code  3600004 caught in file "M:\wxp_sr1mp8c\server_src\internal_server_exits\code\internal_server_exits.cxx" at line number 221
 could not load the library
IMANVolume::load volume3:f:\volume3 accesses in mode TCP (Tcfs mode 1)
--- Portal Client version is: 2005 SR1/2007 ---
--- Portal Server version is: V10.-1.3.8.3_build_0823 ---
TextServer::failed to open file 'sap_errors.xml'
TextServer::WARNING: bad file name, sap_errors.xml
TextServer::failed to open file 'soa_errors.xml'
TextServer::WARNING: bad file name, soa_errors.xml
Iman Preference is IMAN_config_rule_nameThe preference name is Последняя по дате созданияIMAN_Security_Level = 1
UG Hookup: API_FILE_CACHE =
	   hence file caching is OFF
UG Hookup: getenv (API_ALWAYS_REFRESH) = (NULL)
	hence alwaysRefresh = FALSE
UG Hookup: getenv (API_NO_CACHING) = (NULL)
	hence cachingAllowed = TRUE
Object's name has been modified: was '(blank)', now '47601.5341.717.000.24/00'
  Server ID            : UGS
Initializing UG/Manager licensing...
(dsType 00000000 "(NULL)", itemType 00000000 "(NULL)"):
    "DB_PART_NO" : Item.item_id ( cadMaster false imanMaster true )   /description="Part Number "
    created ok
    "DB_PART_REV" : ItemRevision.item_revision_id ( cadMaster false imanMaster true )   /description="Part Revision "
    created ok
    "DB_PART_TYPE" : Item.object_type ( cadMaster false imanMaster false )   /description="Part Type "
    created ok
    "DB_UNITS" : Item.uom_tag.symbol ( cadMaster false imanMaster true )   /description="Part Unit of Measure "
    created ok
(dsType 00003d10 "UGMASTER", itemType 00000000 "(NULL)"):
    "DB_PART_NAME" : Item.object_name ( cadMaster false imanMaster true ) /write_once  /description="Part Name "
    created ok
    "DB_PART_DESC" : Item.object_desc ( cadMaster false imanMaster true ) /write_once  /description="Part Description "
    created ok
    "DB_PART_NAME" : Item.object_name ( cadMaster false imanMaster true )   /description="Part Name "
    created ok
    "DB_PART_DESC" : Item.object_desc ( cadMaster false imanMaster true )   /description="Part Description "
    created ok
(dsType 00003d18 "UGPART", itemType 00000000 "(NULL)"):
    "DB_DATASET_ID" : pubr_object_id ( cadMaster true imanMaster true )   /description="Part File ID "
    created ok
    "DB_DATASET_REV" : rev ( cadMaster true imanMaster true )   /description="Part File Rev "
    created ok
    created ok
    created ok
    created ok
    created ok
    created ok
    created ok
    created ok
    created ok
    created ok
    created ok
*** NOTE:: in line 3878 of M:\wxp_sr1mp8c\src\ugmgr_im\code\pdi_im_session.cxx at Wed Jun 25 10:35:47 2014 Московское время (зима)
+++ Preference TC_NX_allow_checkoutin_commands is not found in scope IMAN_preference_site
Unresolved handle 'ReQNqqlKBvFBPB' for API object, the PDI object corresponding to this handle is NULL
Unresolved handle 'ReRNqqlKBvFBPB' for API object, the PDI object corresponding to this handle is NULL
Object's name has been modified: was '(blank)', now 'Inch'
Object's name has been modified: was '(blank)', now 'Metric'
Object's name has been modified: was '(blank)', now 'Metric_dwg'
Object's name has been modified: was '(blank)', now 'Inch_dwg'
CACHE CLEAR: 0 items, 0 item-revs, 0 refreshed-tags
UG Hookup: The IMF cache routines are enabled.
SetOwnerAccessRightsOnly Error 2:GetFileSecurity on S:\2005SR1\portal\temp\ci0lql52hki32xas_tmp628.prt
SetOwnerAccessRightsOnly Error 5:SetNamedSecurityInfo
directory S:\2005SR1\portal\temp is owned by group 0, user 0
*** NOTE:: in line 3280 of M:\wxp_sr1mp8c\src\res\code\res_internal.cxx at Wed Jun 25 10:36:04 2014 Московское время (зима)
+++ No reservation object for replica object (00006b4f).
ERROR_store_initial_error storing 515193 "47601.5341.717.000.24/00" "" "" "" "" "" "" on top of existing errors
Contents of the error store:-
       ERROR 32015 Объект  не заблокирован
PROTECT MARK111125
       ERROR515193 Копия 47601.5341.717.000.24/00 доступна только для чтения
       ERROR  1700 Опция не найдена: IMAN_Cache_Protection
*** NOTE:: in line 1645 of M:\wxp_sr1mp8c\src\imancore\code\aom_itk.cxx at Wed Jun 25 10:36:04 2014 Московское время (зима)
+++ okToModify() returned error code: 7027. Clearing error stack.
*** NOTE:: in line 308 of M:\wxp_sr1mp8c\src\ugmgr_im\code\pdi_im_rep.cxx at Wed Jun 25 10:36:04 2014 Московское время (зима)
+++ Found one or more BOMViewRevisions but none of the IMAN_UG_view_type.
Unresolved handle 'T$K9AHsch68LQC' for API object, the PDI object corresponding to this handle is NULL
process_instances: Attempt to load indirected Item object T$B9AHsch68LQC (00006fb9)
*** EXCEPTION: Error code  515177 in line 472 of M:\wxp_sr1mp8c\pom_src\dms\code\dms_load.cxx at Wed Jun 25 10:36:04 2014 Московское время (зима)
+++ Failed to load the requested object
Loaded module C:\WINDOWS\system32\SAMLIB.dll 71bd0000 13000 4bb85de7-4f159b10-f16df995-c891acad-2 version = 5.1.2600.5512
Loaded module C:\WINDOWS\system32\NTMARTA.DLL 77680000 21000 eb9b3e21-4f51f92f-6fd885ad-a841774d-2 version = 5.1.2600.5512
Loaded module S:\2005SR1\install\install\jre\bin\net.dll 71d0000 f000 0-0-0-0-0 version = 0
Loaded module S:\2005SR1\install\install\jre\bin\zip.dll 4700000 d000 0-0-0-0-0 version = 0
Loaded module S:\2005SR1\install\install\jre\bin\java.dll 46e0000 19000 0-0-0-0-0 version = 0
Loaded module S:\2005SR1\install\install\jre\bin\verify.dll 46d0000 e000 0-0-0-0-0 version = 0
Loaded module S:\2005SR1\install\install\jre\bin\hpi.dll 46b0000 7000 0-0-0-0-0 version = 0
Loaded module S:\2005SR1\install\install\jre\bin\client\jvm.dll 8000000 139000 0-0-0-0-0 version = 1.4.2.60
Loaded module S:\2005SR1\fms\lib\FSCClientProxy.dll 4690000 7000 0-0-0-0-0 version = 0
[ 8] 61C6F072 dms_load\DMS_load_instances Line 472 +0xf2                   (libpom)
[ 9] 61C6EF98 dms_load\DMS_load_instances Line 485 +0x18                   (libpom)
[10] 61DA2767 ril_load\RIL_load_instances Line 129 +0x87                   (libpom)
[11] 61D40148 pom_most_interface_funs\POM_load_instances Line 3428 +0x348  (libpom)
[12] 66FFDFF3 pdi_im_fast_itk_access\PDI_im_fast_item_ask_name Line 333 +0xa3 (libugmgr_im)
[13] 67025863 pdi_im_part\PDI_im_find_part_by_item Line 1545 +0x13         (libugmgr_im)
[14] 6701D38E pdi_im_mapping\PDI__im_lookup_mapping Line 294 +0x6e         (libugmgr_im)
[15] 6701E4F5 pdi_im_object\PDI__l_find_object_by_handle Line 644 +0xd5    (libugmgr_im)
[16] 6705E619 pdi_svr\PDI_AIWS_find_object_by_handle Line 617 +0x259       (libugmgr_im)
[17] 670CDB31 PDI_find_object_by_handle +0x11                              (libugmgr_im)
[18] 602F2558 pdiserver_i\PDIServer_i::find_object_by_handle Line 302 +0x58 (libpdi_corba_server)
[19] 60447BD9 cdr\POA_PDIServer::find_object_by_handle_skel Line 155 +0x169 (libpdi_corba_server)
[20] 60F58ED9                                                              (TAO_PortableServer)
[21] 604D0599 POA_PDIServer::_dispatch +0x39                               (libpdi_corba_server)
[22] 60F3BEC6                                                              (TAO_PortableServer)
[23] 633D6916                                                              (TAO)
>>>> Error code  515177 caught in file "M:\wxp_sr1mp8c\pom_src\pom\code\pom_most_interface_funs.cxx" at line number 3468
*** EIM_abort_transaction on error ***
Unresolved handle 'T$B9AHsch68LQC' for API object, the PDI object corresponding to this handle is NULL
Unresolved handle 'yaO9AHsch68LQC' for API object, the PDI object corresponding to this handle is NULL
process_instances: Attempt to load indirected Item object yaF9AHsch68LQC (00006fbc)
*** EXCEPTION: Error code  515177 in line 472 of M:\wxp_sr1mp8c\pom_src\dms\code\dms_load.cxx at Wed Jun 25 10:36:05 2014 Московское время (зима)
[23] 633D6916                                                              (TAO)
Unresolved handle 'yaF9AHsch68LQC' for API object, the PDI object corresponding to this handle is NULL
CACHE CLEAR: 0 items, 0 item-revs, 2 refreshed-tags
AddAccessRightsForUser Error 5:SetFileSecurity on 47601.5341.717.000.2_000
***SS_ChdmodNt: chmod on 47601.5341.717.000.2_000 failed.
UG/Manager File Cache Statistics:
    Disabled
*** NOTE:: in line 3280 of M:\wxp_sr1mp8c\src\res\code\res_internal.cxx at Wed Jun 25 10:49:00 2014 Московское время (зима)
+++ No reservation object for replica object (00006726).
ERROR_store_initial_error storing 515193 "СЗ_47601-3738-701-242_2013_10_28" "" "" "" "" "" "" on top of existing errors
PROTECT MARK130208
       ERROR515193 Копия СЗ_47601-3738-701-242_2013_10_28 доступна только для чтения
PROTECT MARK130207
*** NOTE:: in line 3280 of M:\wxp_sr1mp8c\src\res\code\res_internal.cxx at Wed Jun 25 10:49:01 2014 Московское время (зима)
+++ No reservation object for replica object (00007342).
ERROR_store_initial_error storing 515193 "УЛ_47601.5141.921.000.70/00" "" "" "" "" "" "" on top of existing errors
PROTECT MARK130733
       ERROR515193 Копия УЛ_47601.5141.921.000.70/00 доступна только для чтения
PROTECT MARK130732
Object's name has been modified: was '(blank)', now '47601.5141.921.000.24/00'
    created ok
    created ok
    created ok
    created ok
    created ok
    created ok
    created ok
    created ok
    created ok
    created ok
*** NOTE:: in line 3878 of M:\wxp_sr1mp8c\src\ugmgr_im\code\pdi_im_session.cxx at Wed Jun 25 10:49:14 2014 Московское время (зима)
SetOwnerAccessRightsOnly Error 2:GetFileSecurity on S:\2005SR1\portal\temp\r3dkclritji32xas_tmp628.prt
*** NOTE:: in line 3280 of M:\wxp_sr1mp8c\src\res\code\res_internal.cxx at Wed Jun 25 10:49:31 2014 Московское время (зима)
+++ No reservation object for replica object (0000735b).
ERROR_store_initial_error storing 515193 "47601.5141.921.000.24/00" "" "" "" "" "" "" on top of existing errors
PROTECT MARK175766
       ERROR515193 Копия 47601.5141.921.000.24/00 доступна только для чтения
*** NOTE:: in line 1645 of M:\wxp_sr1mp8c\src\imancore\code\aom_itk.cxx at Wed Jun 25 10:49:31 2014 Московское время (зима)
*** NOTE:: in line 308 of M:\wxp_sr1mp8c\src\ugmgr_im\code\pdi_im_rep.cxx at Wed Jun 25 10:49:31 2014 Московское время (зима)
Unresolved handle 'hbfFa$R3h68LQC' for API object, the PDI object corresponding to this handle is NULL
process_instances: Attempt to load indirected Item object hbWFa$R3h68LQC (0000745d)
*** EXCEPTION: Error code  515177 in line 472 of M:\wxp_sr1mp8c\pom_src\dms\code\dms_load.cxx at Wed Jun 25 10:49:31 2014 Московское время (зима)
[23] 633D6916                                                              (TAO)
Unresolved handle 'hbWFa$R3h68LQC' for API object, the PDI object corresponding to this handle is NULL
AddAccessRightsForUser Error 5:SetFileSecurity on 47601.5141.921.000.2_000
***SS_ChdmodNt: chmod on 47601.5141.921.000.2_000 failed.
*** NOTE:: in line 308 of M:\wxp_sr1mp8c\src\ugmgr_im\code\pdi_im_rep.cxx at Wed Jun 25 10:53:33 2014 Московское время (зима)
    Disabled
Object's name has been modified: was '(blank)', now 'R6{1757}/V1'
    created ok
    created ok
    created ok
    created ok
    created ok
    created ok
    created ok
    created ok
    created ok
    created ok
*** NOTE:: in line 3878 of M:\wxp_sr1mp8c\src\ugmgr_im\code\pdi_im_session.cxx at Wed Jun 25 10:57:47 2014 Московское время (зима)
SetOwnerAccessRightsOnly Error 2:GetFileSecurity on S:\2005SR1\portal\temp\rfvj5vlgskybcfto_tmp628.prt
*** NOTE:: in line 3280 of M:\wxp_sr1mp8c\src\res\code\res_internal.cxx at Wed Jun 25 10:57:59 2014 Московское время (зима)
+++ No reservation object for replica object (0000746c).
ERROR_store_initial_error storing 515193 "R6{1757}/V1" "" "" "" "" "" "" on top of existing errors
PROTECT MARK231730
       ERROR515193 Копия R6{1757}/V1 доступна только для чтения
*** NOTE:: in line 1645 of M:\wxp_sr1mp8c\src\imancore\code\aom_itk.cxx at Wed Jun 25 10:57:59 2014 Московское время (зима)
AddAccessRightsForUser Error 5:SetFileSecurity on R6{1757}_000
***SS_ChdmodNt: chmod on R6{1757}_000 failed.
По-моему все ясно. Нет доступа к какой-то папке, поищите к какой именно.
У меня такое было, когда в поле "Start in" ярлыка, запускающего TC, была указана папка без прав доступа на запись.
