40 минут назад, ILL сказал:
Так вот и я о том же..
Не всегда это нужно.
3 часа назад, ILL сказал:
А если файлы разбросаны по папкам??
Заграница нам поможет...
Вот этот макрос выбирает основную папку (проекта, к примеру), создаёт в ней папку "STL". В неё сохраняет все модели из папки с подпапками:
Option Explicit
Private Const BIF_RETURNONLYFSDIRS As Long = &H1
Private Const BIF_DONTGOBELOWDOMAIN As Long = &H2
Private Const BIF_RETURNFSANCESTORS As Long = &H8
Private Const BIF_BROWSEFORCOMPUTER As Long = &H1000
Private Const BIF_BROWSEFORPRINTER As Long = &H2000
Private Const BIF_BROWSEINCLUDEFILES As Long = &H4000
Private Const MAX_PATH As Long = 260
Dim swApp               As SldWorks.SldWorks
Dim swModel             As SldWorks.ModelDoc2
Dim sFileName    As String
Dim nFileName    As String
Dim nPath        As String
Dim Path                As String
Dim stlPath             As String
Dim swFilename          As String
Dim nErrors             As Long
Dim nWarnings           As Long
Dim Response            As String
Dim DocName             As String
Dim bret                As Boolean
Dim swDocTypeLong       As Long
Dim vConfs              As Variant
Dim vPropNames          As Variant
Dim i                   As Integer
Dim j                   As Integer
Dim fso                 As New Scripting.FileSystemObject
Dim MYext               As String
Dim swCustPropMgr       As SldWorks.CustomPropertyManager
Dim tDate               As String
Function BrowseFolder(Optional Caption As String, _
    Optional InitialFolder As String) As String
Dim SH As Shell32.Shell
Dim F As Shell32.folder
Set SH = New Shell32.Shell
Set F = SH.BrowseForFolder(0&, Caption, BIF_RETURNONLYFSDIRS, InitialFolder)
If Not F Is Nothing Then
    BrowseFolder = F.Items.Item.Path
End If
End Function
Sub main()
    Set swApp = Application.SldWorks
    Path = BrowseFolder()
    If Path = "" Then
    MsgBox "Please select the path and try again"
    End
    Else
    Path = Path & "\"
    End If
    stlPath = Path & "STL"
    If Dir(stlPath, vbDirectory) = "" Then MkDir stlPath
    BatchFolder Path, ".SLDPRT", ".SLDASM", True
'    MsgBox "DONE"
End Sub
Sub BatchFolder(folder As String, ext As String, ext2 As String, silent As Boolean)
    If Right(folder, 1) <> "\" Then folder = folder & "\"
    ChDir (folder)
    Response = Dir(folder)
    Do Until Response = ""
        swFilename = folder & Response
        MYext = Right(UCase$(Response), 7)
        If MYext = ext Or MYext = ext2 Then 'this is a file type we want, process it
            swDocTypeLong = Switch(MYext = ".SLDPRT", swDocPART, MYext = ".SLDASM", swDocASSEMBLY, True, -1)
Set swModel = swApp.OpenDoc6(swFilename, swDocTypeLong, swOpenDocOptions_Silent, "", nErrors, nWarnings)
Set swModel = swApp.ActiveDoc
nPath = Left(swModel.GetPathName, InStrRev(swModel.GetPathName, "\"))
nFileName = Left(swModel.GetTitle, Len(swModel.GetTitle)) + ".STL"
swModel.SaveAs (stlPath + "\" + nFileName)
swApp.CloseDoc swModel.GetTitle
Set swModel = Nothing
        End If
        Response = Dir
    Loop
    Dim myFolder As folder
    Dim mySub As folder
    Set myFolder = fso.GetFolder(folder)
    For Each mySub In myFolder.SubFolders
        BatchFolder mySub.Path, ext, ext2, silent
    Next
End Sub
35 минут назад, Kelny сказал:
Всегда надо учитывать различные варианты..
23 минуты назад, Kir95 сказал:
В папке проекта могут быть модели, исключенные из него..
50 минут назад, ILL сказал:
Все варианты не учтёшь. Кому-то исключения нужны, кому-то буквы и регистр букв менять, кому-то уникальные номера присваивать, кому-то ещё и в свойствах файла поковыряться, кому-то ещё и калькулятор удобно... И в результате из небольшого макроса можно такого гиганта сотворить, что он ни кому не понадобится или не будет востребован из-за сложности настроек.
В 07.02.2018 в 11:16, tompsongun сказал:
Подскажите, пожалуйста, по следующему вопросу:
на один старый комп поставил
пакет макросов SWPLus, RecordDimM - работают,
ГЕОС, Roughness (простановка шероховатости), ТТ, ChangeFormatka - не работают, пишут или запустите твёрдого* или нет активе икс ...
Я так понимаю/подозреваю  нужно доустановить Microsoft visual c++ только вот какие?
у меня на компе работает всё и у меня майкрософт визуал установлены 2005, 2008, 2010, 2012, 2013, 2015 - по несколько версий
*Solid
Блин, я сталкивался уже с этой проблемой в 2016 году. В антивирусе Comodo - файлы SWPlus надо в доверенные добавить (или папку) и посмотреть не попали ли файлы в песочницу. В них вирусов нет, просто антивирус параноит. Сменил Солид, а про то и забыл. Теперь-то пометку вписал в инсталяции ). Даже если песочницы нет, бывает, что Comodo по прошествии времени блокирует "неопознанные" файлы, если их не пометить "доверенными".
Изменено пользователем tompsongun
Всем привет. Для "нормального" сохранения в pdf иногда пользую PDFCreator+SaveAsPDF макрос. И все бы ок, концы стрелок не вылазят за выносные линии размеров и линии обозначения разрезов и прочие плюхи. Если бы не одно НО! (см. скрин). У одного меня эти точки возникают? Причем только при записи в две строки (две строки в свою очередь формирует RecordDim). Помогите побороть сей баг. :dash1:
Изменено пользователем R2D2_
Такая же ерунда и при сохранении в других виртуальных принтерах (PdfFactory Pro например), так что - это косяк солида. Как побороть - ХЗ. Как вариант редактировать уже сформированный PDF-файл в редакторе типа Adobe Acrobat Pro или IcenyInfix
7 минут назад, Snake 60 сказал:
это косяк солида
Точно? )))
Макро - SaveAsPDF через функции солида, не принтера.
@streamdown , косяк PDFCreator'а. Но этот виртуальный принтер как раз и использовал потому, что родная утилита импортирует в PDF криво (например концы размерных стрелок вылазят за выносные линии и пр.) Если знаете как этого избежать и использовать стандартное "Сохранить как..." - прошу поделится опытом.
В 09.03.2018 в 14:05, streamdown сказал:
Точно? )))
  Показать содержимое
Возможно))) Попробовал виртуальный принтер от самих Adobe (при установки Про версии ставится) - та же ситуёвина. Заметил, что точки появляются только там, где применяется тег <stack> - как вариант не применять его, ставить вторую строку обычной заметкой, но это костыль. Хотелось бы докопаться до сути, почему солидовский конвертер скрывает эти точки, а другие нет.
Привет.
При работе в SW2015 на WIN 10 с недавнего времени начало выскакивать уведомление о критическом уровне памяти. Хотя это происходит на довольно простых деталях и операциях (типа создания эскиза или открытие детали из сборки). При этом комп довольно мощный. Считаю, что данное сообщение не связано с реальным положением дел (с памятью все ок) и уведомление генерируется на основе каких-то косвенных признаков в работе системы.
Подскажите чего? Спасибо.
9 часов назад, breeze сказал:
Привет.
Не совсем понятно. В диспетчере задач у вас сколько процентов свободной оперативной памяти при этом?
Из справки солида:
Изменено пользователем MUXALblCH
Да меня самого достало это предупреждение... памяти больше 50% свободно, а солид истерит... Не понимаю почему вообще так происходит.
Надо смотреть, сколько съедает сам солид.. И если он объелся, зайти в "Инструменты" - "Добавления".. И солид в памяти будет занимать меньше 50 Мб.. Но это до первого сохранения или перестроения..
А вообще, эта тема про макросы..
14 часа назад, breeze сказал:
Может действительно вы посчитали что реальной памяти (ОЗУ) выше крыши и отключили файл подкачки (виртуальная память), а программа посмотрела что файла подкачки нет или он очень мал и решила, что вы её ущемляете в памяти? Вот и выдала предупреждение.
В 11.03.2018 в 00:43, Snake 60 сказал:
попробовал pdf 24 - все то же самое...
Не помню, чтоб раньше такое было...
@Yurikman , хвала Ньютону! Осталось дело за малым: раздобыть и поправить исходник SaveAsPDF.swp))
@Yurikman а откуда Вы этот стек знаете?
Какие еще есть?
Может опубликуете весь список?
42 минуты назад, R2D2_ сказал:
Что-то лежит вот здесь: https://forum.solidworks.com/thread/82613
Пардон. Пилить то надо не SaveAsPDF, а RecordDimM.swp. Но там такие дебри, что боюсь придется призывать @Leon'а.
    • Solidman
