Avionics / Electrical Systems Engineer
Job Description
- Responsible for the evaluation, development and introduction of avionics systems
- Hold discussions with existing and potential suppliers
- Produce specifications and reports and develop essential documents for system certification and production
- Responsible for looking after the system engineering side of our customer aircraft
- Define technical guidelines for flight-testing, modified systems and support the flight test department during test flights
- Defect analysis of fault and defect messages and the development of solution proposals
Profile
-- Several years experience in aircraft design / development
- Experience with the most modern communication and navigation systems as well as electronic flight instruments
- Working knowledge of civil FAR and JAR regulations and certification
- Good communication skills and be able to work in a team
- High level of computer knowledge (MS Office)
- Excellent written and spoken knowledge of the English language
- Knowledge of the German language is desirable, but not essential
www.eone.com.ua
    • streamdown
    • vs3dpro
