lookinf for Senior Engineer Rotating & Static Equipment !
Господа инженеры,на работу в Голландию требуется квалифицированный конструктор оборудования (судостроение,нефтегазовая промышленность,машиностроение).
У Вас есть подобные навыки или возможно вы знаете таких специалистов-ждем развернутое резюме на английском языке на мейл inzynier@inbox.ru.
Условия трудоустройства-конкурентные
Всем хорошего дня!
The Rotating & Static Equipment Department (RSE) is responsible for the engineering of all rotating, static and packaged equipment installed on floating or fixed, oil and gas producing offshore installations.
Position
You will be either leading a project team of several Mechanical Engineers or act as a Package Engineer handling the major mechanical packages on a project. As a Package Engineer you will be involved in the selection of suitable process and marine equipment and will be responsible for all technical related matters of purchased equipment.
Activities will comprise: preparation of specifications, performing technical evaluations, liaise with purchasing department, intermediate between equipment supplier and internal engineering disciplines, coordinate the integration of purchased equipment into the overall offshore installation, review of vendor drawings and calculations and final inspections of equipment.
Profile
MSc or BSc degree (TU/HTS) with at least 10 years experience as a Mechanical Engineer in preferably the (offshore) oil and gas production industry. You have a thorough knowledge of rotating and/or static equipment and mechanical systems and should be familiar with the applicable design codes and standards. You combine a solid theoretical know-how with a pragmatic approach and should be able to execute the work with limited supervision.
www.eone.com.ua
Изменено пользователем rabota
    • dps
      Да. На моем случает 5шт кажется опций. И я сейчас уже не вспомню порядок восстановления. Если кто-то возьмется его все же полно и достоверно изложить- было бы очень замечательно. Или может инструкция есть от того же ХААс-а?
    • Александр 36
    • Igor Lipin
      Доброва времени суток, помогите разобраться с неисправностью станка Hiperturn 65-dt на стойке Sinumerik 840 DSL.  После сервисного обслуживания подрядчиком периодически срабатывает ошибка 21612: Канал 1: Ось S1/C11 разрешение сброшено, причина 1. Сервомотор шпинделя оснащен датчиком на валу AMO, других энкодеров на валу не нашел. Неисправность возникает хаотично, на разных операциях программы обработки, но при вращении шпинделя. По рекомендации справки (Help) повышали параметр 36060, на какое-то время помогало, а потом опять ошибка. Пробовали при работе шевелить все соединения в КК двигателя и привода, SMC20, датчики температуры, энкодер AMO.Короче ничего не помогает. Кто встречался с такой ошибкой, посоветуйте.
      по штоку смотрите. Т.е. в миллиметрах. Ну , у нас так..))
    • clavr
      переменные одни и те же? не будет конфликта?
    • Alexandr97
      Проблема кроется в следующем. После создания библиотеки стандартных изделий и создания конфигурации системы в tflex docs через cad, невозможно обновить библиотеку на других компьютерах. Вся библиотека была привязана к конфигурации формата tws. Пользователи Tflex cad через меню документов закрепляют у себя библиотеку с помощью выбранной конфигурации, но она автоматически сохраняется у них на диске. Таким образом, если начальный разработчик в библиотеке воспроизведет изменение, то остальные пользователи этого не увидят, данные не обновятся, так как все сохранено у них на компьютере почему-то, и с docs новые изменение не подтягиваются. Вопрос: подскажите, пожалуйста, как же все таки настроить библиотеку в docs так, чтобы при ее обновлении, вся библиотека у всех пользователей автоматически обновилась? Сейчас выходит так:разработчик делает изменение, сохраняет в докс, пользователи этого не видят, так как система не обновляется. Разработчику остается только создать заново конфигурацию и всем пользователям ее заново у себя прикрепить... Так же не должна работать система?
      @clavrНет, мои макросы самостоятельные, только делают тоже что и Мпроп заносят свойства в деталь/сборку. Плюс в том, что есть пакетный режим обработки
    • clavr
      там экзешник MProp.exe. его тоже запустит? или именно макрос нужен? p.s. сижу на макросах SWPlus.NET v.1.0
      @clavr Мой макрос делает это для сборки: https://snake-60.ru/blog/blog-list/84-onepage-blog/78-fromfilenametoproperties-vba-makros-paketnogo-zaneseniya-svojstv-v-detali-i-ili-podsborki А этот для папки с проектом: https://snake-60.ru/blog/blog-list/84-onepage-blog/80-makros-paketnogo-zaneseniya-svojstv-v-detali-sborki-nakhodyashchiesya-v-papke
      Версия должна быть SW2014 и выше: https://help.solidworks.com/2014/RUSSIAN/SolidWorks/sldworks/c_3d_bounding_boxes.htm   Как вариант макросом (но не всегда корректно давал габарит на не прямые поверхности, например, сферы или кривые поверхности): https://kelnyproject.ucoz.ru/load/6-1-0-7 при желании можно поковываться и встроить макрос в документ модели, что бы обнавляло при запуске или обновлении модели.   А в последних версиях так же появилась ГРАНИЧНАЯ РАМКА (см. ссылку на справку выше), которая имеет габариты и эти габариты могут быть вставленны как ссылка на размер, как раз в том виде как вы приводите.
