Поясните пожалуйста:
Выбор делаю с помощью "PropertyManagerPageSelectionbox"
На кнопку поставил:
Private Sub PropertyManagerPage2Handler9_OnButtonPress(ByVal Id As Long)
Dim swSelMgr                     As SldWorks.SelectionMgr
Dim swBody                        As SldWorks.Body2
Dim i                                    As Integer
Dim swError                       As Long
Dim BazaMat                 As String
Dim NameMat                 As String
BazaMat = "solidworks materials.sldmat"
NameMat = "Клен" ' ЛЮБОЙ МАТЕРИАЛ
Set swSelMgr = swModel.SelectionManager
For i = 1 To swSelMgr.GetSelectedObjectCount2(-1)
Set swBody = swSelMgr.GetSelectedObject6(i, -1)
swError = swBody.SetMaterialProperty("", BazaMat, NameMat)
Next i
End Sub
В открытом файле сборки не работает. В детали Да.
Изменено пользователем maikl_lug
Ребята есть часть кода:
swModel = ((IModelDoc2)(swApp.NewDocument("C:\\Solidworks Library\\templates\\Сборка.asmdot", 0, 0, 0)));
swModel = ((IModelDoc2)(swApp.ActivateDoc2("Assem1", false, longstatus)));
swAssembly = ((AssemblyDoc)(swModel));
swAssembly.InsertNewPart2(textBox2.Text, selectFace());
Где textBox2.Text:
private void button3_Click(object sender, EventArgs e)
            Stream myStream;
            SaveFileDialog saveFileDialog1 = new SaveFileDialog();
            saveFileDialog1.Filter = "sldWork files (*.sldprt)|*.sldprt|All files (*.*)|*.*";
            saveFileDialog1.FilterIndex = 1;
            saveFileDialog1.RestoreDirectory = true;
            if (saveFileDialog1.ShowDialog() == DialogResult.OK)
                if ((myStream = saveFileDialog1.OpenFile()) != null)
                    // Code to write the stream goes here.
                    textBox2.Text = saveFileDialog1.FileName;
                    myStream.Close();
selectFace()
private object selectFace()
            String assyName = swModel.GetTitle().ToLower().Contains(".sldasm")
                          ? swModel.GetTitle().Remove(swModel.GetTitle().LastIndexOf("."))
                          : swModel.GetTitle();
            for (int i = 0; i < 100; i++)
                Boolean bRet = swModel.Extension.SelectByID2(partNameNumber1 + "-" + i.ToString() + "@" + assyName, "COMPONENT", 0, 0, 0, false, 0, null, 0);
                if (bRet)
                    break;
            SelectionMgr swSelMgr = (SelectionMgr)swModel.SelectionManager;
            Component2 myOldComp = (Component2)swSelMgr.GetSelectedObject6(1, -1);
            if (myOldComp != null)
                swPart = myOldComp.GetModelDoc2() as PartDoc;
                if (swPart != null)
                    IEntity face = (IEntity)swPart.GetEntityByName("Number1", (int)swSelectType_e.swSelFACES);
                    if (face != null)
                        face = myOldComp.GetCorresponding(face) as IEntity;
                        face1 = face.Select4(false, null);
            return face1;
Проблема состоит в том, что при компиляции и отладке деталь так и не создается в сборке, методы button3_Click (textBox2.Text) и selectFace() передают значение в InsertNewPart2 но деталь все равно не создается... Может быть я как-то неправильно использую метод InsertNewPart2? В справке что-то ничего очевидного я не нашел...
PS Если нужно могу скинуть весь код...
Спасибо.
@@Almo
swAssembly.AddComponent4
И, кстати, swAssembly.InsertNewPart2 возвращает ErrorCode. Попробуйте так:
swInsertNewPartErrorCode_e errorCode = (swInsertNewPartErrorCode_e)swAssembly.InsertNewPart2(textBox2.Text, selectFace());
И посмотрите что там возвращается.
streamdown, а как мне в AddComponent4 запихнуть ссылку на поверхность получаемую методом selectFace() если AddComponent4 на вход принимает координаты?
@@Almo
Погодите, так вам нужно именно создать деталь в контексте сборки? Тогда с AddComponent я погорячился))
Что возвращает errorCode ? Вы попробовали как я показал?
Да, необходимо создать деталь в контексте сборки с указанным путем сохранения на указанной поверхности другой детали.
errorCode возвращает - swInsertNewPartError_FileAlreadyExists, это я так понимаю означает что деталь уже создана?
Хм... а не получается ли это из-за того, что метод button3_Click создает уже готовый файл с расширением sldprt а метод InsertNewPart2 пытается создать его же в свою очередь? Если так, то как бы мне запихнуть в InsertNewPart2 свой путь сохранения и имени будущей детали?
В общем то при записи строки следующим образом
swAssembly.InsertNewPart2("C:\\Part3^Assem3.sldprt", selectFace());
errorCode возвращает swInsertNewPartError_FilePathEmpty а при отладке в окне солида видно значок выбора места вставки новой детали (типа курсор с зеленой галочкой) и для создания ее остается только кликнуть по уже подсвеченной (выбранной) грани...
Как бы добавить этот клик?)
код у вас должен быть таким
  1. //if ((myStream = saveFileDialog1.OpenFile()) != null)
    {// Code to write the stream goes here.
    //myStream.Close();}
а про выбор кромки почитайте ещё GetSpecificFeature2
Не могу понять как применить GetSpecificFeature2 касательно моей проблемы, да и вообще честно говоря не очень понятен его смысл... Не могли бы объяснить?
PS появилась идея заменить InsertNewPart2 на InsertNewVirtualPart а уже потом ее сохранять, но все же, неужели никто не использует InsertNewPart2 ?
Спасибо.
Эээх, вот умеете вы заставить поработать по средам)))
Логика у вас неправильная.
Как должно быть:
- создать сборку (swApp.NewDocument)
- вставить туда деталь с вашей Face2;
- selectFace()
- InsertNewPart
 private void button1_Click(object sender, EventArgs e)
            GetSolidworks();
//Тут создать сборку и вставить в нее деталь!!!!
            //swModel = (ModelDoc2)(swApp.NewDocument(@"D:\AddonSW\SWPlus\Шаблоны\Сборка.asmdot", 0, 0, 0));
//AddComponent("тут деталька с гранью");
            swAssembly = (AssemblyDoc)(swModel);
            Face2 rrr = selectFace();
            swInsertNewPartErrorCode_e errorCode = (swInsertNewPartErrorCode_e)swAssembly.InsertNewPart2(@"C:\oneforme.sldprt", selectFace());
private Face2 selectFace()
                Boolean bRet = swModel.Extension.SelectByID2("part" + "-" + i.ToString() + "@" + assyName, "COMPONENT", 0, 0, 0, false, 0, null, 0);
                if (bRet)
                    break;
                if (swPart != null)
                    if (face != null)
                        Face2 retFase = (Face2)face;
                        return retFase;
            return null;
Не добавлялась новая деталь у вас потому, что вы создаёте сначала новую сборку БЕЗ своей детали и пытаетесь там в пустоте искать компонент.
Как должно быть:
- selectFace()
- InsertNewPart
            GetSolidworks();
                if (bRet)
                    break;
                if (swPart != null)
                    if (face != null)
                        return retFase;
            return null;
Логика у меня была такая как вы написали, проблема как оказалось была в том, что перед вызовом InsertNewPart2 я не вызывал метод selectFace()...
Спасибо огромное за подсказку!!!!
PS когда применяется GetSpecificFeature2?))) Если можно то вкратце на пальцах)
Незачто.
огда применяется
Ну, там просто в API была ссылка на этот метод в Remarks. Надо читать.
Записал макрос.
Надо его немного подправить, на в програмирование не силён.
Суть макроса в следующем.
Делаем привязку к внешнему файлу, с темже именем как и сам файл, перестраиваем, сохраняем. и сохраняем в формат DXF с тем же именем как и файл, текущий вид.
Получается в макросе нужно сделать чтоб привязка к файлом была не жёстко по пути и имени, а брала в текущей папке, с тем же именем файла.
Sub main()
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("Уравнения", "EQNFOLDER", 0, 0, 0, False, 0, Nothing, 0)
Part.ClearSelection2 True
longstatus = Part.SaveAs3("D:\Производство\43\29.DXF", 0, 0)
swPart = swApp.NewPart()
Dim myModelView As Object
Set myModelView = Part.ActiveView
myModelView.FrameLeft = 0
myModelView.FrameTop = 22
myModelView.FrameState = swWindowState_e.swWindowMaximized
swApp.ActivateDoc2 "Чертеж1 - Лист1", False, longstatus
myModelView.FrameTop = 0
swApp.ActivateDoc2 "29", False, longstatus
Dim myView As Object
Set myView = Part.CreateDrawViewFromModelView3("D:\Производство\43\29.SLDPRT", "*Текущий", 0, 0, 0)
boolstatus = Part.DeleteNamedView(*Текущий)
End Sub
Всем привет. Нужно програмно изменить слой объекта чертежа. Ручками делается так: выбираю допустим размер, в менеджере слоев выбираю нужный слой. На скиншоте менеджер слоев внизу слева  https://yadi.sk/i/9c83uceGe3iNz
Примеры мне не помогли. Есть ChangeComponentLayer, не могу понять, как его использовать. Нашел так же команды swCommands_LayerProperties и swCommands_Layer_Select как приминить их тоже не понял.
Пробовал
            doc_md_ext.SelectAll(); // выделить все
            sw.Command(1151, ""); // потом выбрать слой
не помогло. Что я делаю не так?
Может кто нибудь покажет рабочий код, изменяющий слой?
Изменено пользователем sova2004
Ну так а если sw.Command(1151, "LayerName")
Тоже как то интересовался этим вопросом. Быстро ответа не нашёл.
Попробовал. Не помогло. Подставил и имя слоя, и цифру 1(в надежде что это единственный слой), и цифру 3(в надежде что есть еще два системных), и цифру 2 (на всякий случай), также вставил туда  слой как объект. Так же не помогло. Пробовал и со свойствами слоя. Может есть еще варианты?
Layer layer1;
LayerMgr doc_layer;
doc_layer = (LayerMgr)doc_model.GetLayerManager();
layer1 = doc_layer.GetLayer(textBox1.Text); // предварительно создается слой с именем из textBox1.Text и делается активным(текущим)
sw.Command(1151, layer1);
Заглянул в справку. Не понимаю в чём у вас проблема?
//Добавим список слоев
LayerMgr lMgr = (LayerMgr)swModel.GetLayerManager();
Object[] layers = lMgr.GetLayerList();
comboBox1.Items.AddRange(layers);
//Переместим размер на нужный слой
String currentLayerName = "AM_5";
DisplayDimension dim = (DisplayDimension)swModel.SelectionManager.GetSelectedObject6(1, -1);
Annotation myAnn = dim.GetAnnotation();
myAnn.Layer = currentLayerName;
Где то так для размеров:
private void cmdNewLayer_Click(object sender, EventArgs e)
    SldWorks swApp = GetActiveSolidWorks();
    if (swApp == null)
        return;
    IModelDoc2 swModel = swApp.IActiveDoc2;
    if (swModel == null)
        string message = "Загрузите документ SolidWorks-а!";
        MessageBox.Show(message, "Warning!", MessageBoxButtons.OK, MessageBoxIcon.Warning);
        return;
    int docType = swModel.GetType();
    if (docType != (int)swDocumentTypes_e.swDocDRAWING)
        string message = "Функция выполняется только с документами чертежей (*.slddrw)!";
        return;
    ISelectionMgr swSelMgr = swModel.ISelectionManager;
    int countObj = swSelMgr.GetSelectedObjectCount();
    for (int i = 1; i <= countObj; i++)
        swSelectType_e selType = (swSelectType_e)swSelMgr.GetSelectedObjectType2(i);
        switch (selType)
            case swSelectType_e.swSelDIMENSIONS:
                    IDisplayDimension swDisplayDimension = swSelMgr.GetSelectedObject5(i) as IDisplayDimension;
                    IAnnotation swAnnot = swDisplayDimension.IGetAnnotation();
                    swAnnot.Layer = "DIM"; // Имя слоя
                break;
P.S. Опередили.
Спасибо Вам большое streamdown и Shvg. Помогло. Проблема была в моем не понимании, связать DisplayDimension и Annotation. DisplayDimension к стати тоже пере этим пробовал, а до Annotation так и не дошло дело.
Доброго времени суток.
Вкратце есть форма (см.рис1) алгоритм работы которой следующий:
1. указывается путь к фланцу с помощью кнопки "фланец"
2. нажимается кнопка "button4" которая должна считать конфигурации фланцы и "запихнуть" их в "comboBox1".
    Реализацию кнопки button4 смотрите в спойлере ниже:
private void backgroundWorker1_DoWork(object sender, DoWorkEventArgs e)
            if (button4_Click_Click == true) // флаг для кнопки button4, до ее нажатия button4_Click_Click = false
                Process[] processes = Process.GetProcessesByName("SLDWORKS");
                foreach (Process process in processes)
                    //Searching the sld procceses and kill them if there exist
                    process.CloseMainWindow();
                    process.Kill();
                //Starting solidWorks
                Object processSW = System.Activator.CreateInstance(System.Type.GetTypeFromProgID("SLDWORKS.Application"));
                swApp = (SldWorks)processSW;
                swApp.Visible = true;
                //Opening flange and getting of configuration
                String asd = pathOfFlange.Text;
                IModelDoc2 swModelFlange = (IModelDoc2)swApp.OpenDoc6(asd, 1, 2, "", 0, 0);
                ConfigurationManager swConfMgr = default(ConfigurationManager);
                swConfMgr = (ConfigurationManager)swModelFlange.ConfigurationManager;
                object[] configNameArr = null;
                configNameArr = (object[])swModelFlange.GetConfigurationNames();
                foreach (String flangeConf in configNameArr)
                    comboBox1.Items.Add(flangeConf);
                    int comLength = comboBox1.Items.Count;
                    int confLength = configNameArr.Length;
                    if (comboBox1.Items.Count == configNameArr.Length)
                        break;
            else
                MessageBox.Show("Нажмите применить");
3. после чего выбирается необходимая конфигурация фланца в выпадающем комбобоксе
4. создается патрубок с помощью кнопки "патрубок"
5. нажимается кнопка "выполнить" и тд...
Вопрос состоит в следующем:
- как бы мне разбить работу этой программы на потоки. Мне кажется необходимо пункт 2 вынести в отдельный поток, что я и сделал с помощью класса backgroundWorker, но при компиляции выскакивает ексепшн " Недопустимая операция в нескольких потоках: попытка доступа к элементу управления 'comboBox1' не из того потока, в котором он был создан". Как мне синхронизировать эти потоки (главный и бекнраунд), или быть может как-то по другому реализовать исполнение кнопки button4 . Мб есть какой то другой алгоритм получения списка конфигураций, я буду признателен за пример кода.
Спасибо.
