ILL
Официально рекомендованные для SW видеокарты.
1 144 сообщения в этой теме
Pinned posts
3. SW2008 for WinXP32
nVidia
OS Driver Date
Quadro FX 1100
WinXP 6.14.10.9185 06/19/2007
WinXP 6.14.10.7756 06/12/2007
Quadro FX 1300
Quadro FX 1400
WinXP 6.14.11.6265 01/09/2008
WinXP 6.14.10.7756 05/11/2007
Quadro FX 1500
WinXP 6.14.11.6265 01/08/2008
WinXP 6.14.10.9185 06/18/2007
Quadro FX 1700
WinXP 6.14.11.6262 10/03/2007
Quadro FX 3000
WinXP 6.14.10.9185 06/15/2007
WinXP 6.14.10.7756 06/11/2007
Quadro FX 3400
Quadro FX 3450
WinXP 6.14.11.6265 01/11/2008
WinXP 6.14.10.9185 06/11/2007
WinXP 6.14.10.7756 05/15/2007
Quadro FX 350
Quadro FX 3500
Quadro FX 370
Quadro FX 3700
WinXP 6.14.11.6939 02/05/2008
Quadro FX 4000
Quadro FX 4400
Quadro FX 4500
Quadro FX 4600
WinXP 6.14.11.6265 01/10/2008
WinXP 6.14.10.9778 05/30/2007
Quadro FX 470
WinXP 6.14.11.7846 10/27/2008
Quadro FX 500
Quadro FX 540
Quadro FX 550
Quadro FX 5500
Quadro FX 560
Quadro FX 5600
Quadro FX 570
Quadro FX 700
Quadro4 380 XGL
WinXP 6.14.10.9136 04/21/2006
Quadro4 550 XGL
Quadro4 580 XGL
Quadro4 700 XGL
WinXP 6.14.10.9136 04/23/2007
Quadro4 750 XGL
Quadro4 900 XGL
Quadro4 980 XGL
ATI Technologies
OS Driver Date
FireGL V3100
WinXP 8.44 04/16/2008
WinXP 8.353.1.1 06/19/2007
FireGL V3200
FireGL V3300
WinXP 8.44 03/21/2008
WinXP 8.353.1.1 06/21/2007
FireGL V3350
WinXP 8.44 04/18/2008
WinXP 8.353.1.1 06/22/2007
FireGL V3400
FireGL V3600
WinXP 8.44 04/15/2008
WinXP 8.391.2.1.1.1 10/09/2007
FireGL V5000
WinXP 8.44 04/21/2008
FireGL V5100
WinXP 8.44 04/22/2008
FireGL V5200
FireGL V5600
WinXP 8.44 04/24/2008
WinXP 8.391.2.1.1.1 10/13/2007
FireGL V7100
WinXP 8.44 04/25/2008
WinXP 8.353.1.1 06/20/2007
FireGL V7200
FireGL V7300
FireGL V7350
FireGL V7600
WinXP 8.44 02/19/2008
FireGL V7700
WinXP 8.453.1 05/21/2008
FireGL V8600
FireGL V8650
FireGL X3
WinXP 8.391.2.1.1.1 12/14/2007
FirePro V3700
WinXP 8.523.1.1 10/14/2008
FirePro V5700
4. SW2008 for WinXP64
nVidia
Quadro FX 1100
WinXP x64 6.14.10.9185 07/07/2007
Quadro FX 1300
Quadro FX 1400
WinXP x64 6.14.11.6265 01/07/2008
WinXP x64 6.14.10.9185 08/07/2007
Quadro FX 1500
WinXP x64 6.14.11.6265 01/08/2008
WinXP x64 6.14.10.9185 07/13/2007
Quadro FX 1700
WinXP x64 6.14.11.6262 10/05/2007
Quadro FX 3400
Quadro FX 3450
WinXP x64 6.14.10.9185 08/08/2007
Quadro FX 350
Quadro FX 3500
Quadro FX 370
Quadro FX 3700
WinXP x64 6.14.11.6939 02/12/2008
Quadro FX 4400
Quadro FX 4500
Quadro FX 4600
WinXP x64 6.14.11.6250 09/10/2007
Quadro FX 470
WinXP x64 6.14.11.7846 10/28/2008
Quadro FX 500
Quadro FX 540
Quadro FX 550
Quadro FX 5500
Quadro FX 560
Quadro FX 5600
Quadro FX 570
Quadro FX 700
ATI Technologies
FireGL V3100
WinXP x64 8.44 04/17/2008
WinXP x64 8.353.1.1 08/14/2007
FireGL V3200
FireGL V3300
WinXP x64 8.44 03/21/2008
WinXP x64 8.353.1.1 08/15/2007
FireGL V3350
WinXP x64 8.44 04/18/2008
WinXP x64 8.353.1.1 08/17/2007
FireGL V3400
FireGL V3600
WinXP x64 8.44 04/16/2008
FireGL V5000
WinXP x64 8.44 04/21/2008
FireGL V5100
WinXP x64 8.44 04/23/2008
FireGL V5200
FireGL V5600
WinXP x64 8.44 04/25/2008
FireGL V7100
WinXP x64 8.353.1.1 08/21/2007
FireGL V7200
FireGL V7300
FireGL V7350
FireGL V7700
WinXP x64 8.453.1 05/21/2008
FirePro V3700
WinXP x64 8.523.1.1 10/15/2008
FirePro V5700
Поделиться сообщением
На квадро ФХ3450(карте 5 лет) под вин 7х64 солид 2010, все сглаживания работали и с чертежами проблем никаких, ставил дрова самые последние, не обращал ни на какую сертификацию. очень быстрое переключение между окнами в солиде, если отрыто несколько сборок.
Тот же комп с Ати ХД 5770 (новая карта), сглаживание чуть хуже, на чертежах качество намного хуже. по производительности карты равные, прилично выигрывает квадро на чертежах при перемешении, приближение и тд. Тупит при переключении между сборками.
Тот же комп АТИ ФайрЖЛ В7700(карте 2 года), Солид 2010 Сп4(без патча сглаживания вообще нет), Сглаживание работает при вращении, на чертежах качество хорошее только при просмотре, при перетаскивании и тд, становиться хуже, Карта в 2 раза быстрее предыдущих карт. Драйвера стоят последние, нет никакой сертификации. Видать из за пача прога сама летать стало раза в 2 быстрее, открытие , закрытие, сохранение и тд.
Все тестилость на Вин 7х64.
Винда ХП 64 ничего не изменила и сертификация не помогла. наоборот нашел инфу зависимости версий дров и версий винды от производительности... Вин 7 вылазит в перед.
Изменено пользователем Vith
Подскажите, как отключить режим OpenGL? Стоит флажок, но строка затенена.
SW2006, Windows7. Драйвера последние, Quadro FX1500.
открой солид но не создавай никаких документов, жмакай настройки и отключай
Ситуация та же, затененная строка.
Включил RealView так же как Jim Shark, но появились проблемы со сглаживанием размеров, оно работает только во время вращения. И еще старая проблема, исчезают грани или елцые объекты на некоторое время, особенно сильно проявляется когда проводишь курсором по детали. Что это может быть?
...Что это может быть?
Это может быть что угодно. Так как изменения в реестре позволяют только обмануть SolidWorks и включить RealView. Проф. возможности обеспечивают во-первых проф. драйвера, а во-вторых само железо. Для nVidia полностью разлочить игровую видеокарту в профессиональную (с полными проф. возможностями железа) удавалось только до карты GeForce 6600 A1, а установить проф. драйвера (но без проф. возможностей железа) до карты GeForce 8800 A1. Все что выше не позволяет установить проф. драйвера, а все добавки в реестр, - это кому как повезет.
Кстати, у меня сейчас стоит Quadro FX580 - так не нарадуюсь. Раньше была карточка от ATI Radeon, разлоченная в FireGL. SW 2007 в ней работал корректно. SW 2009 начал выдавать кучу глюков. Подбирал другие дрова, - Солид начал работать нормально, а в Autodesk Moldflow начались проблемы с отображением картинки. Сейчас все отлично! Так что, мой совет, если вы работаете в нескольких CAD/CAE системах - покупайте проф. карту. Сейчас они стали вполне доступны по цене.
Доброго в.с. уважаемому сообществу.
Вопрос в общем-то один. Можно ли как-то количественно оценить выигрыш от профессиональной видеокарты? Т.е. померить производительность в каких ни будь "попугаях". Интересует именно производительность применительно к SoldWork (сейчас стоит 2010-SP0). Вроде внимательно просмотрел всю тему, но кроме включения/не включения realview и весьма субъективных "стало шустрее" никаких других преимуществ использования Quadro FX видеокарт так и не нашёл. А есть ли они вообще?
Сейчас сижу на обычной 8800GTS-512. Работаю в основном с весьма простыми деталями и несложными (где-то до 50 деталей сборками) На днях обещали дать не на долго (на "поиграть") 8800GT переделанную в Quadro FX 3700. Хочется как-то объективно оценить - чем она будет превосходить мою карточку (если вообще будет).
Да и ещё - обязательно ли ставить рекомендованные Солидом дрова (191.87_Quadro_winxp_32bit_english_whql) или лучше самые свежие от нВидиа (на сегодня это 259.81-Quadro-winxp-32bit-international-whql).
Заранее спасибо.
Мнения есть разные. Мнение пользователя Квадры 3400 и ATI4870.
Не рекомендуется заниматься программным "самопалом", тем более выигрыша это не принесет.
Особого ускорения при использовании проф. карт не будет, при оформлении сложных чертежей все будет упираться в проц, тормоза неизбежны. Дрова можете ставить любые свежие, для игровых свои, для квадр свои. Хотя возможны различные осложнения, это уже зависит конкретного случая, ящика или ОСи.
Я все карты от nVidia после SW2004(кажется) оцениваю по кол-ву открытия/закрытия/переключения окон SW. Это были GF4 Ti4400, GF6600GT, GF8600GT и Quadro FX580. В игровом варианте первые три обычно затыкались на 20-30 окнах. Если разлочить, то кол-во окон увеличивалось до 100 на Ti4400(больше не пришлось проверить) и где то 80 на двух других. На квадре этого нет. Пример открытия/закрытия - сохранение комплекта чертежей в *.pdf или *.tif в цикле. То есть, я обеими руками за квадру.
Скажу Вам всем по секрету, что в кад системах видео карта не так важна, как тактовая частота процессора и тайминги памяти. Именно в солиде квадро просто напросто позволяет включить режим REALVIEW, к примеру, в CATIA, подобный режим работает и без квадро. Зачем вам крутое видео (хотя у меня самого Quadro Quadro 6000), когда есть RealView, который темпаче рендерит исключительно на CPU, причём в многоядерном режиме
Заранее спасибо.
У меня nVidia Quadro FX580. Стоят рекомендованные драйвера 191.87. SW 2010 x64 sp4 работает без проблем во всех режимах. Ставил самые свежие драйвера от nVidia - начались серьезные глюки графики при работе с поверхностями. Поэтому в нашем случае не всегда стоит гнаться за "свежачком".
Всем привет!
Возникла проблемма, никак решить не могу.
Купил комп
Windows 7х64, Видеокарта NVIDIA GeForce GTS 450
Проблемма в том, что картинку глючит при масштабировинии и повороте моделей (отсутствует полная отрисовка).
А с OpenGL таращит мрачно.
Может кто уже сталкивался с таким?
Не совсем в тему, но оч. близко...
По моему производители видях специально так подстраиваю драйвера, чтобы "старая добрая" видяха в конце концов по всей объективности становилась тормознутой. У меня было такое года 4 назад. Комп собирал, чтоб дома в Pro/E можно было работать. Взял Nvidia7600 (пассив - главное чтоб на мозги шум не давил!). Оказалось, что только короткая последовательность версий драйверов корректно работала ! Более старые на знали карту. А более новые устраивали в OpenGL какое-то дебильное подетальное перестроение с каждым не только поворотом, но даже просто при панорамировании (смещении изображения без поворота).
Вообще чушь какая-то. 10 лет назад игровые карты показывали вполне-так-себе неплохие в OGL результаты. И с каждым годом становились мощнее (Например Riva раза в 3 по-быстрее была DimondFireGL). А потом производителям знать надоела такая утечка барыша. Специально что-то делают, чтоб игровые карты тормозились в CADах !
Всем привет!
Купил комп
Метод в таких случаях един - перебирать драйвера...
Три раза перечитал тему, пытаясь извлечь полезную для себя, старого начинающего юзера, но понял только одно - это "Тетрис". На тебя все производители всё валят, а ты изобретаешь возможность уложить это правильно, и это бесконечно долго будет продолжаться. Так выпьем за бесконечность!!!
Три раза перечитал тему, пытаясь извлечь полезную для себя, старого начинающего юзера информацию, но понял только одно - это "Тетрис". На тебя все производители всё валят, а ты изобретаешь возможность уложить это правильно, и это бесконечно долго будет продолжаться. Так выпьем за бесконечность!!!
Три не потянул но всё же не понял что недорогого такого купить чтобы просто работать нормально, реалвиев думаю не нужен и не понадобится, некчёмная это игрушка.
можете написать конфигурацию своего компьютера, и оставить отзыв- с чем тормозит, что быстро переваривает.
спасибо
спасибо
А вопрос кому?
Есть железный раздел на этом форуме там много про тормоза и их решения
<noindex>http://fsapr2000.ru/index.php?showforum=41</noindex>
Не снимается галка OpenGL, RealView не включается. :helpsmilie:
Операционная система Win7x64 Professional SP1
Процессор Intel Core i7-2600 3.4Ghz, ОЗУ 8 Мб
Видеокарта PNY Quadro 4000, драйвер 259.57
SW2008SP0
Использовать OpenGL. Отключение аппаратного ускорения видеоадаптера, вместо этого включение графического отображения с помощью только программных средств. Для большинства графических плат это приводит к уменьшению скорости отображения. Этот параметр следует выбирать только по указанию технической поддержки. Этот параметр можно выбрать, когда нет открытых документов.
Ели выбран параметр Использовать программу OpenGL, SolidWorks изменяет значения некоторых параметров с целью оптимального функционирования программы. Нажмите здесь Нажмите здесь для просмотра изменяемых параметров. При необходимости можно отменить любые из этих параметров.
Этот параметр устанавливается автоматически и не может быть изменен, если графическая карта вообще не поддерживает аппаратное ускорение или не поддерживает аппаратное ускорение для текущего разрешения, количества цветов, частоты обновления и т.д.
Источник: <noindex>http://help.solidworks.com/2010/russian/so...performance.htm</noindex>
Справку я читал. В системе WinXP SP2 все работает. Я читал что поддержка Win7 начинается с SW2010 SP1, но возможности обновить программу пока нет (очень не дешевое удовольствие), а работать с полным объемом оперативной памяти хочется.
WinXP x64 для этой цели не подходит?
Выпуск WinXP x 64 прекращен (и насколько мне известно больше не поддерживаетмя Microsoft), а выбор между Win7 x 64 и Vista x 64 ...
Для 64-разрядной версии Windows XP пакет обновления 3 (SP3) недоступен. Если компьютер работает под управлением 64-разрядной версии Windows XP с пакетом обновления 2 (SP2), вы используете последний пакет обновления и будете получать поддержку и обновления до 8 апреля 2014 года.
Да и так понимаю, что не поддерживается как раз SW2008.
зато хрюня 64 не отъедает стока ресурсов сколько вынь7 и виста, и проблемы с sw в основном идут на 7-ке... на хрюше64 проблем нет
Да именно SW2008. Но думаю 2009 постигнет аналогичная участь. Подержка Win7 обещана только с SW2010 SP1. Для нормальной работы видеокарты Quadro 4000 в SW2008 с Win XP требуется установки SolidWorks 2008 Quadro Patch (для SW2009 соответственно SolidWorks 2009 Quadro Patch). Вот здесь думаю собаку и зарыли. :angel_sadangel:
Имеется только Win7x64 Professional SP1.
SW2008SP0
Попробуй поставить более свежие драйвера на видео - 267.79 например.
И может стоит накатить сервис пак на SW.
Сегодня была опубликована новая версия драйвера 270.71.
Драйвер 267.79-Quadro-win7-winvista-64bit уже ставили. Не свезло. Обновить SW2008 SP0 не получилось (пишет что имеется обновления до SW2008 SP5, а затем что обновление не доступно для скачивания). :angel_sadangel:
Посмотри в ветке реестра солида - возможно там не прописалась видеокатра.
HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2008\Performance\Graphics\Hardware\Gl2Shaders\NV40
Прописана. Более того эта ветка совпадает с веткой реестра WinXP SP2. А там все работает.
<noindex>http://solidworld.ru/php/print.php?id=43</noindex>
Notes:
For RealView support with SolidWorks 2008, sw2008Quadro.msi ( <noindex>http://www.solidworks.com/downloads/videoc...w2008Quadro.msi</noindex> ) must be installed.
Источник: <noindex>http://www.solidworks.com/sw/support/videocardtesting.html</noindex>
Там живет SolidWorks 2008 Quadro Patch. Он установлен. :angel_sadangel:
У нас sw2008sp5.0 и quadro2000 под winXP32sp2 - более-менее стабильно все работает только с той версией дров, что сертифицированы (т.е. выложены на сайте solidworks.com). Все новье - что скачивалось с nvidia.com - глючит вплоть до "синего экрана"....
Проблема SW2008 с Win7 x 64 а не с WinXP x 32 :angel_sadangel:
Ответьте пожалуйста на вопрос, какой на данный момент можно собрать комп в пределах 50 000 рублей для эффективной работы в Солиде. Монитор, естественно в эту сумму не включая. Или дайте ссылочку на тесты, обсуждения, может быть есть видео на эту тему.
В этом разделе много интересного....
Создать аккаунт
Зарегистрировать аккаунт
Войти
Войти сейчас
