ExtraRight
Shared Workspace в Smarteam
На ибм-овском сайте техподдержки в комментах к юзерскому запросу, претендовавшему на баг, нашли такие строки:
SMARTEAM Shared Workspace is not a functionality
that should be promoted for collaboration on top of
CATIA.
SMARTEAM CATIA Integration pushes collaboration
thru into-vault and out-of-vault operations, allowing
designers to synchronize their design on demand
and in a robust way. Functionalities such as Check-
Out-on-the-fly, Global Refresh, and Replace With
Selected Revision promote design collaboration.
SMARTEAM CATIA Integration architecture was not
designed to support the new behavior introduced
by SMARTEAM Shared Workspace product.
Managing this new behavior, would require a
complete redesign of SMARTEAM CATIA Integration
code.
Внимание, вопрос: для какого CAD писалась эта технология? Для SolidWorks?
Share this post
green_fx , у тебя как с английским?
Английским по белому же написано:
SMARTEAM Shared Workspace - это не та функциональность, которую следовало бы внедрять для оптимальной совместной работы с CATIA.
Первоисточник: <noindex>http://www-1.ibm.com/support/docview.wss?r...f-8〈=en</noindex>
Полный текст:
HD58843: STCAI : IN SHARED WORKSPACE, PROBLEM DURING CHECK OUT OPERATION
APAR status
Closed as suggestion for future release.
Error description
STCAI : In Shared Workspace, problem during
check out operation
CATIA Smarteam Integration Issue reproducible
with SmDemo and a Shared Workspace.
Problem description
1. Create Shared Workspace.
2. In Smarteam Tools/Switch workspace, select the
new createed Shared workspace where the user is
the Integrator.
3. In CATIA, Integrator creates a CATPart.
4. Save in Smarteam Integration.
5. Check-in. (the Part is still in CATIA session).
6. In CATIA, Check out the loaded Part just
checked In in step 5.
The CATIA Part changes its current status to not
latest while the status must be Checked-out.
This problem only happens in Shared workspace.
Local fix
Problem summary
Problem conclusion
Temporary fix
Comments
THIS APAR IS CONSIDERED AS A SUGGESTION
FOR IMPROVEMENT WHICH CANNOT BE
INCORPORATED IN CATIA VERSION 5 RELEASE 18.
PLEASE CONTACT YOUR SUPPORT DEPARTMENT IN
ORDER TO OPEN A REQUIREMENT FORM.
SMARTEAM Shared Workspace has introduced new
rules for the management of documents:
- files are located in a shared area accessible by
mutliple users
- authorizations are not only based on SMARTEAM
life-cycle states but also on ownership
These new rules have a negative impact on CATIA
and CAI:
- CATIA has a "partial loading" mechanism. This
mechanism allow to load into memory the part of
the document which is required by CATIA; the
remaining part being automatically loaded when
requested by the CATIA session. This mechanism
require that the file on disk does not get changed
once it has been "partially" loaded in the CATIA
session
- CAI use SMARTEAM life-cycle states for the
definition of the user authorizations. Basically, user
can modify a document if it is in "checked-out"
state. This life-cycle state is reflected by
a "read&write" access to the file in the user "work"
folder. This rule is not respected by SMARTEAM
Shared Workspace: even if a document is
in "checked-out" state, it may be "read-only" for
the user in case he did not get "ownership"
Conclusion
CATIA.
code.
Share this post
Дим, ну судя по тому, что до 10-го релиза (вроде как) все презентации Смартима были на примере работы его с Solid Works... ну ты понял))
а из Дассо товарищ тебе и не ответит что есть на самом деле. статус не позволяет )
Share this post
2 ExtraRight
ладно тебе придираться :wink:
Share this post
